Properly Sync Keypad to Light?
I have a Keypad Link 6-button On/Off not connected to any load and a Fan Link with the light hooked up. I created a scene with the Fan Light as a responder and the Keypad-1 as a Controller/Responder. The On/Off buttons are linked to the Fan Link light and work as expected: when quickly pressed and released they turn on/off, and when the fan light is controlled from another source they correctly reflect the status. Further when pressing and holding the on or off buttons I am able to dim or brighten the fan light.
However if the fan light is already on and I press and hold the Keypad off button to dim the fan light, the Keypad suddenly shows the light as being off even if it is turned on. How can I dim the light from the Keypad and have it continue to reflect a correct status for the light?
