Chris Jahn Posted July 23, 2014 Share Posted July 23, 2014 ... If Elk Area 'Home' 'Alarm State' is Fire Alarm Or Elk Area 'Home' 'Alarm State' is Medical Alarm Or Elk Area 'Home' 'Alarm State' is Police Alarm Or Elk Area 'Home' 'Alarm State' is Burglar Alarm Or Elk Area 'Home' 'Alarm State' is Carbon Monoxide Alarm Or Elk Area 'Home' 'Alarm State' is Emergency Alarm Or Elk Area 'Home' 'Alarm State' is Freezer Alarm Or Elk Area 'Home' 'Alarm State' is Gas Alarm Or Elk Area 'Home' 'Alarm State' is Heat Alarm Or Elk Area 'Home' 'Alarm State' is Water Alarm And $Active_Alarm is 0 Then Send Notification to 'Phone' content 'Alarm' ... Here is the notification. I tried both methods without luck. ACTIVE ALARM. ${sys.time12} ${alert.date} ${alert.control} : ${alert.action} ${elk.zone.#.name}. ${elk.zone.#.status}. ${elk.area.1.alarmState} Hi NHWA, The conditions you are testing for are Area conditions, not Zone conditions. Therefore, the ${elk.zone.....} variables will evaluate to nothing. In this case, I think you are looking for ${elk.area.#.alarmState}. In fact, you wouldn't even need to use the '#', you could just specify the area number for 'Home' e.g. ${elk.area.1.alarmState} Link to comment Share on other sites More sharing options...
tandar Posted July 23, 2014 Share Posted July 23, 2014 To answer Michel and to echo what NHWA is saying; When I use # in the notification and an alarm trips, the message returns a blank Eg. ${elk.zone.#.name} = null When I substitute the # with an appropriate number, the message returns the correct zone name Eg. ${elk.zone.1.name} = "Frt Door" Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
LeeG Posted July 24, 2014 Share Posted July 24, 2014 tandar The post immediately before yours from UDI indicates why NHWA Program is not working. The Program is triggered by Area alarms rather than a Zone alarms. This is why a Zone number of # is not resolved. an you post the Program that is not working. Link to comment Share on other sites More sharing options...
tandar Posted July 24, 2014 Share Posted July 24, 2014 Thanks Lee and Chris. That makes more sense. What's throwing me (and I think NHWA) is that WayneW posted a reply on 28 April that shows a program that passes the zone based on an area alarm. WayneW - if you are still monitoring this, would you mind confirming that the program you posted actually passes the alarmed zone? Thanks, Tandar Link to comment Share on other sites More sharing options...
WayneW Posted July 24, 2014 Share Posted July 24, 2014 I apoligize for the confusion folks. In post #3, I posted what I have. Unfortunately, I don't recall where I got it and apparently I never tested it. I also get alarm notifications via HomeSeer & NextAlarm, so I never noticed that the resulting message from the ISY was NOT what I was expecting. I have edited post #3 to avoid further confusion. shannong sort-of confirmed my post in #4. Then we got sidetracked with ISY version differences as a possibility. In my post #17, I ruled out the ISY firmware version as a difference. In my post #14, I tried to clarify that I wasn't 100% sure of my original post #3, but I wasn't in a position to test it then. I did post some specific samples of glass break zone reporting, but I now realize that is like apples and oranges as the trigger programs are totally different. JSchumann then mentioned the use of ${alert.control} : ${alert.action}, which is apparently undocumented? Does anybody know more about those? So, my known working program (for zones that are 24/7) is If Elk Zone 'GlassBrk-Family' is not Normal Or Elk Zone 'GlassBrk-Guest1' is not Normal Or Elk Zone 'GlassBrk-Guest2' is not Normal Or Elk Zone 'GlassBrk-Living' is not Normal Or Elk Zone 'GlassBrk-MastBed' is not Normal Or Elk Zone 'GlassBrk-Office' is not Normal Then Send Notification to 'email & cell' content 'Elk Glass Break' Else - No Actions - (To add one, press 'Action') if we tweak that to something like *** UNTESTED PSEUDOCODE *** If (Elk Zone 'GlassBrk-Family' is not Normal Or Elk Zone 'GlassBrk-Guest1' is not Normal Or Elk Zone 'GlassBrk-Guest2' is not Normal Or Elk Zone 'GlassBrk-Living' is not Normal Or Elk Zone 'GlassBrk-MastBed' is not Normal Or Elk Zone 'GlassBrk-Office' is not Normal Or etc, etc for each zone) - a PITA to setup, but it only requires one program instead of 50 programs AND (Elk Area 'Home' 'Alarm State' is Fire Alarm Or Elk Area 'Home' 'Alarm State' is Medical Alarm Or Elk Area 'Home' 'Alarm State' is Police Alarm Or Elk Area 'Home' 'Alarm State' is Burglar Alarm Or Elk Area 'Home' 'Alarm State' is Carbon Monoxide Alarm Or Elk Area 'Home' 'Alarm State' is Emergency Alarm Or Elk Area 'Home' 'Alarm State' is Freezer Alarm Or Elk Area 'Home' 'Alarm State' is Gas Alarm Or Elk Area 'Home' 'Alarm State' is Heat Alarm Or Elk Area 'Home' 'Alarm State' is Water Alarm) Then Send Notification to 'email & cell' content 'Elk ALARM' Else - No Actions - (To add one, press 'Action') will that pass the zone number? Link to comment Share on other sites More sharing options...
tandar Posted July 25, 2014 Share Posted July 25, 2014 Wayne, Thanks for clearing this up. I just have to dig in now and learn the difference between the status: "is not Normal", "Violated", "Trouble", etc Link to comment Share on other sites More sharing options...
JSchumann Posted August 2, 2014 Share Posted August 2, 2014 I am not familiar with that syntax and cannot find it in the wiki. Can you provide more details please? What would the pros & cons be versus ${elk.zone.#.name}. ${elk.zone.#.status}. I found them in the WIKI during a search, but can't find them anymore. Michael says they are documented in the WIKI variables area, but I don't see them. I think they got overwritten. Anyway, after more extensive testing, they only work to identify the area (not the zone in the area). What I ended up doing was putting this into my e-mail customization: ${sys.time12} ${elk.zone.2.name} - ${elk.zone.2.status} ${elk.zone.3.name} - ${elk.zone.3.status} ${elk.zone.4.name} - ${elk.zone.4.status} ${elk.zone.5.name} - ${elk.zone.5.status} ${elk.zone.6.name} - ${elk.zone.6.status} ${elk.zone.7.name} - ${elk.zone.7.status} ${elk.zone.9.name} - ${elk.zone.9.status} ${elk.zone.10.name} - ${elk.zone.10.status} ${elk.zone.11.name} - ${elk.zone.11.status} ${elk.zone.193.name} - ${elk.zone.193.status} And looking for the tripped zone status on the e-mail. I know, brute force, but until we can figure out how to pass the parameter we are stuck. Link to comment Share on other sites More sharing options...
JSchumann Posted August 2, 2014 Share Posted August 2, 2014 You can have the ISY insert the violated zone with a variable, and I do it almost exactly the same as WayneW instead of writing a program for each zone. It's working for me. OK, send an example program, thanks! Link to comment Share on other sites More sharing options...
WayneW Posted August 15, 2014 Share Posted August 15, 2014 if we tweak that to something like *** UNTESTED PSEUDOCODE *** If (Elk Zone 'GlassBrk-Family' is not Normal Or Elk Zone 'GlassBrk-Guest1' is not Normal Or Elk Zone 'GlassBrk-Guest2' is not Normal Or Elk Zone 'GlassBrk-Living' is not Normal Or Elk Zone 'GlassBrk-MastBed' is not Normal Or Elk Zone 'GlassBrk-Office' is not Normal Or etc, etc for each zone) - a PITA to setup, but it only requires one program instead of 50 programs AND (Elk Area 'Home' 'Alarm State' is Fire Alarm Or Elk Area 'Home' 'Alarm State' is Medical Alarm Or Elk Area 'Home' 'Alarm State' is Police Alarm Or Elk Area 'Home' 'Alarm State' is Burglar Alarm Or Elk Area 'Home' 'Alarm State' is Carbon Monoxide Alarm Or Elk Area 'Home' 'Alarm State' is Emergency Alarm Or Elk Area 'Home' 'Alarm State' is Freezer Alarm Or Elk Area 'Home' 'Alarm State' is Gas Alarm Or Elk Area 'Home' 'Alarm State' is Heat Alarm Or Elk Area 'Home' 'Alarm State' is Water Alarm) Then Send Notification to 'email & cell' content 'Elk ALARM' Else - No Actions - (To add one, press 'Action') will that pass the zone number? the example program at the bottom of http://wiki.universal-devices.com/index.php?title=ISY-99i_Series_INSTEON:ELK_Security_Module#Program_Examples implies that this can be done. I will try to get time to test it soon. It has to be when I am home and the dog is not as the siren or a smoke alarm drives him crazy. Link to comment Share on other sites More sharing options...
