How to Bypass zone from Keypad
sanders2222
Somehow, someone in this household has managed to bypass a zone (my double car garage door). I suspect it happened while punching in a disarm code into the keypad. How do I un-bypass it?
EDIT: Anybody?
Bypass/zone number/bypass: This did not work
Also, the global bypass/000/bypass did not unbypass the zone either.
EDIT: Well, I must be the only one on this forum. But as for the ELK zone bypass....SOLVED IT!
Turns out it wasn't a program issue after all. Today I found part of a magnetic switch on the garage floor. The magnet was stuck to the garage door with double sticky tape. The tape finally gave up the sticky part. Tank Gwad that I don't have rats chewing on wires!
I reattached the magnet to the top of the door with screws and now system is responding properly.
I'll leave this post in case someone else runs into a zone bypass issue. Maybe this solution will help find a solution.
