Program to Latch light on with motion dectector
I am trying to write a program to turn my Patio lights on with motion at night only, but also have the ability to override the lights On so that after the 1min 30secs the lights to do not turn off if i am outside for an extended period of time. I have most of this working, BUT, the lights will not turn off.
The Program 1 and 2 and 3 are working but not 4 (the off program) the program then statement will not run even though program 3 is true (i know its true because the light turns on, but when I go to the ISY after the light turns on, i should see the "then" running because of the wait 1min 30secs but its not running. any help why all parts of the then statement is not running would be great.
Program 1 - Patio Lights Disable
If And Control 'patio lights' is switched on
And Status 'patio lights' is not off
$ignore_motion_detection = 1
Program 2 - Patio Lights Enable
If Control 'patio lights' is switched off
$ignore_motion_detection = 0
I can see variable count go up and down so I know these 2 programs above are working
Program 3
If from sunset +30mins
to sunrise -30mins next day
And 'patio motion detector' = on
Set Scene "Patio Lights' On
Wait 1 min 30 secs
Run program 'patio lights off' (if)
for the above program the lights turn on, but i never see the "wait" happen in the isy, so i think maybe when the motion goes off the then statement stops? but i have other programs that once the then starts and if statement becomes falses it still keeps on running.....
Program 4 - patio lights off
If $ignore_motion_detection = 0
Set Scene 'Patio Lights' off
please help thanks!
Is the Variable an Integer or State Variable?
Also post the actual Programs. Two of them have invalid statements. Right click on Program name, select Copy to Clipboard. Paste to forum post.
Try this method instead:
If Control ON AND Status Off
Disable Program Motion Light
Turn Lights On
Wait 1 Hour
Enable Program Motion Light
If Control OFF And Status On
Turn Lights Off
If Time is Night And Status Motion Detected
Turn Lights On
Wait 1min 30sec
Turn Lights Off
Hi Lee attached below are exact from my programs, also I setup the variable using integer, should i have used state?
Disable program
Control 'Patio Lights Living Rm Right' is switched On
And Status 'Patio Lights Living Rm Right' is not Off
Or (
Control 'Patio Lights Kitchen Door' is switched On
And Status 'Patio Lights Kitchen Door' is not Off
$Ignore_Motion_Detection = 1
enable program
Control 'Patio Lights Living Rm Right' is switched Off
Or Control 'Patio Lights Kitchen Door' is switched Off
$Ignore_Motion_Detection = 0
lights on program
From Sunset + 30 minutes
To Sunrise - 30 minutes (next day)
And Status 'Exterior Patio-Sensor' is On
And Status 'Patio Lights Kitchen Door' is Off
And Status 'Patio Lights Living Rm Right' is Off
Set Scene 'Patio Lights' On
Wait 1 minute and 30 seconds
Run Program 'Patio Motion Lights OFF' (If)
lights off program
$Ignore_Motion_Detection is 0
Set Scene 'Patio Lights' Off
i am just puzzled why the lights will turn on, via the lights on program, but i never see the 1 min 30min wait happen is the isy programming, but integer moves up and down from 1 to 0 correctly.
The first thing to look at is how long the motion sensor reports On Status. If it turns Off before the 1 minute 30 second Wait expires the 'Patio Motion Lights OFF' Program will not be invoked because of the change in Sensor Status.
The second item to look at is what Scene 'Patio Lights' turns On. If this Scene changes the Status of 'Patio Lights Kitchen Door' or 'Patio Lights Living Rm Right' the 'Patio Motion Lights OFF' Program will not be invoked because of the change in Status of either of these devices.
The simple solution is to split the Program into two Programs.
Run Program 'xxxx'
Program 'xxxx'
That way when any of the Status changes occur the second Program will not be affected.
Thanks Lee G. I tried this last night and worked like a charm. Thanks for your advice! Brilliant solution!
