ToggleLinc won't won't install
Jgdavis14
I just tried to install a ToggleLinc Relay Model # 2466SI V6.1
ISY won't install and I get an error of: Devices could not be added: Cannot determine Insteon Engine.
I've tried the Auto discover, and several different ToggleLinc setting in the Device Type.
The switch does work properly on site.
Any ideas??
ISY99i or ISY994i?
What firmware is running on the controller?
If you are using an ISY99i the last firmware may not support the module.
Run Tools | Diagnostics | Event Viewer at LEVEL 3 while adding ToggleLinc using Auto Discover. Post the event trace. That message normally indicates a comm problem with the device. Double check Insteon address to be sure an 8 or B and 5 or 6 have not been read incorrectly.
That is the only format for a detail Insteon trace. They get easier to read over time. The comm looks good in this trace. No way to determine from the trace what was wrong before as everything worked as expected this time.
      378.7k
