KPL local on level
Is it possible to adjust the load (button A) local on level on a 6 button KPL dimmer based on the time of day using a scene or a program? The KPL is showing as a 5 button KPL in the ISY, not sure why
I was able to adjust the on level on a SwitchLinc dimmer but it doesn't seem to work on the KPL. Thank you.
Yes, the Local On Level can be adjusted on a 6 button KPL just as it was on the 8 button. The 6 button KPL has 5 nodes as the ON/OFF buttons function as a single node, the ON button turns the load On, the OFF button turns the load Off.
Instead of changing the Local On Level for button A (Main) set the Local On Level of ONOFF button. It is done with a Program that is time triggered just as with the 8 button KPL.
