Troubleshooting POST Request
Hello;
I have a device on my network that responds to REST requests.
Using the Advanced Rest Client Chrome Extention I'm able to get things working properly.
Using the ISY's interface, I can not get it to work.
In Chrome:
https://IP_Address
/config.php
Authorization: Basic randomeLETTERSandNUMBERS
Body: setsysload=9
Request headers
User-Agent: Mozilla/5.0 (Windows NT 6.3; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/35.0.1916.114 Safari/537.36
Origin: chrome-extension://hgmloofddffdnphfgcellkdfbfbjeloo
Content-Type: application/x-www-form-urlencoded
Accept: */*
DNT: 1
Accept-Encoding: gzip,deflate,sdch
Accept-Language: en-US,en;q=0.8
Cookie: PHPSESSID=o5tpeu6nsq6nfkqs3bl78ju854
headers
Expires: Thu, 19 Nov 1981 08:52:00 GMT
Cache-Control: no-store, no-cache, must-revalidate, post-check=0, pre-check=0
Pragma: no-cache
Content-type: text/html
Transfer-Encoding: chunked
Date: Wed, 04 Jun 2014 21:45:46 GMT
Server: lighttpd/1.4.34
Doing it in ISY I just get a request failed.
Now, if I change it to HTTP in isy I get a resource moved; which is correct as you get a permanent redirect to the HTTPS address.
Any idea on how to troubleshoot further?
Was the certificate on your lighttpd HTTPS server issued by a well known (paid) CA like Thawte or Verisign? If not, your probably running into a certificate trust issue.
You can relax the SSL client settings in ISY Dashboard, but it would be better to have a SSL cert on your Lighttpd server that's trusted by ISY. Either that, or exempt your ISY from the SSL redirect....
I'll have to look into this a bit more then. When I hit manage certificates on ISY it just brings me to PDF that I'll have to read later.
As for certificats I use CAcert.org for mine. But this particular piece of equipment does not have a very good interface.
Make sure you are using the Dashboard (correct version for your running code version) to manage certificates - not the admin console or the http interface.
I'm not sure that I fully understand the exchange in the OP but it looks like there may be a session cookie involved which I believe is not supported by the ISY.
-Xathros
