error message question
I am just starting to set up a system with Insteon modules. I linked a module on an outlet near my computer to make it easier. That worked fine. Then moved the module (lamplinc) to its permanent location.
When attempting some basic communication from the admin console - like on and off - got this message: Cannot determine insteon engine. Device cannot be added.
What does that mean and what did I do wrong?
Thanks for the help.
The message means the PLM is not able to talk to the LampLinc. There are various possibilities in a new Insteon install. Some areas to look at ....
No Access Points to couple the 2 120v legs.
PLM is plugged into a surge/noise power strip
Other electronics powered from the same outlet as PLM and not isolated with a FilterLinc
