Zwave remote to control insteon devices / scenes?
The $1 module is the firmware component required to use the $99 ISY ZWave radio hardware. Without the radio, the ISY does not do ZWave with or without the $1 module.
So, short answer is: No, you cannot.
If you do have the ZWave radio and firmware module, you still will not be able to do what you want (yet) since the ISY does not yet support multi-channel ZWave devices like remotes. I believe support for this is coming in the 5.X firmware series.
-Xathros
