Mobilinc and the New Ham Climate Module
Hi Wes,
The ISY has switched to HAM weather from WeatherBug, and as a result Mobilinc seems to need a little attention.
'Temperature Rate' no longer exists, but Mobilic displays a value that appears to be the new 'Average Temperature'
'Humidity Rate' no longer exists, Mobilinc display a '-'
'Pressure Rate' no longer exists, Mobilinc display a '-'
'Average Wind Speed' no longer exists, Mobilinc display a '-'
'Gust Direction' no longer exists? Mobilinc display a '-'
'Rain Rate' no longer exists, Mobilinc display a '-'
'Light Rate' no longer exists, Mobilinc display a '-'
There are lots and lots of new fields in the new HAM Weather that Mobilinc does not display.
I did figure you were already working on it. But I thought I should drop a post in case you were not aware. Thanks for all the support and a fantastic app.
Thanks Wes,
Just got the new update. Under 'today's forecast', 'snow forecast' has a typo it's spelled "snow forecase"
I appreciate the lightning quick update. It's great to have MobiLinc as a top supported app.
