single Zone Irrigation with switchLinc ?
for Irrigation most people seems to use an IO-Linc or EZFlora
For a single zone system, Is there any reason a On/Off module such as a switch Linc
(or 2443-222 Micro On/Off Module or InLineLinc Relay ) be wired to toggle power to the 24V Irrigation power supply.
The reason I am asking this is cause all I need control is a single zone sprinkler system and the above configuration is cheaper and will fit into a double gang box
If that meets your needs go ahead!
Teken
Encrypted By: Phoenix Security Solutions
Teken
I guess I was wondering if I should be concerned about "spikes" from the transformer ( etc )
The relay model Insteon Modules are designed to control inductive loads so it should not be a problem.
Though it may depend on the transformers characteristics when turned On and Off.
If there is one of the rare problems. I believe the users added a Snubber across the transformer.
I would strongly recommend NOT using any device that does not have a failsafe timer to turn itself off after some time period for Irrigation. I've seen too many horror stories...
