AT&T to end email-to-text ×
KeypadLinc Led a Status
I have a strange issue. I have 2 garage door sensors which are working perfectly with an 8 button KeypadLinc. I have 2- 8 button KeypadLincs in the table top enclosures which are a hit and miss. The led's will not work all the time. They will sometimes stay on or turn off. They do work sometimes. The strange thing is that the buttons will open and close the garage doors every single time they are pressed. I added 2 range extenders on different phases and did the test. This did not help. Anyone have any suggestions.
hum099,
The command from the keypad to the opener is it's own command separate from the command from the sensor to the buttons. You may have a half link. You can try doing a restore of the keypad and I/O Linc and see if the results improve.
Please send me an email at support@universal-devices.com if you want some one on one support.
