Contolling Mister System Water Feed
I am trying to control the on/off of the water flow for my mister system on my patio. My thinking was to get a Electronic Water shutoff valve and control it via an Insteon device such as either a IO Link or an On/Off Outdoor Module via my ISY. What I am having problems with is the wiring and controlling it. I have an Smarthome Select Electronic Water Shutoff Valve 3/4" DC.
With the IO Link, the wiring guide for the valve says
green from value to IO Link NC
red from valve to IO Link NO
black from valve to 1 wire of my DC adapter
2nd wire from DC adapter to COM on IO Link
When I do this, and I discover my IO Link and then configure it for:
- LED on TX
- Relay follow input
- Momentary B
and then turn the relay on or off, nothing happens on my valve. What am I missing here?
Do not use Relay follow Input. This option has the relay being controlled by the I/O Linc Sensor.
