Motion Sensor & SwitchLinc
MyHome
I have an Insteon motion sensor linked to a light switch. Even though I am in the room, the light goes off at the appropriate time, and I have to wave my hands to turn the light on. If set properly, should the sensor detect my presence and reset the timeout counter? If yes, then I suspect i need to increase the sensitivity of the sensor...is that right? Thanks.
The motion sensor options likely need some adjustment.
Sensing mode: checked
On Only mode: unchecked
Night mode: checked
Use a Program to turn the SwitchLinc Off
If Control 'motion sensor - Sensor' is switched On
   Wait xx seconds
   Set 'switchlinc' Off
The Program turns the switchlinc Off xx seconds after the last motion is sensed.   All motions will be detected with these options.
      378.6k
