Where can I find the Climate Module?
It is an add on firmware module
In the Administrative Console
Help Tab.
Purchase Modules.
It should open up a new browser page and tell you what you have and what you can purchase if it is not yet installed.
i bought this today
when i click in find and enter toronto, nothing is found.
i also tried new york and nothing came back again (not found)
suggestions?
Envirogreen
It's not you, there appears to be an issue with either the climate module or HamWeather.  My "find" is also not working today.
Update: it's now working, it's possible their server was offline for a while.
Edited by Techman
Still not getting anything back when entering in the Find
Techman - did you change anything to make it work?
Edited by Envirogreen
Envirogreen
No nothing changed other than closing the administrative console, reopening, clicking on find in the climate module, then typing in a city name.
Here is the error I get when I put Toronto in and try to save (figured I'd try that since nothing was coming back with Find)
Attached is the screen shot when I type in Toronto.  Are you running the latest version of the ISY firmware?
Is your UI also 4.2.8? (Help/About)
Entering toronto,on,ca into the location ID seems to have worked for me.
Find is still not working.
Seems that there is a defect in the Find part of the application.
I have exactly the same problem that Envirogreen.
When I entering "Terrebonne,qc,ca" into the location ID, I have 3 results, but when I choose an Areas = error
ISY994i - 4.2.8
UDI - took care of this this morning, took control of my computer and reloaded a java file, now I can search any city.
It works, they will help you, your not alone
