Aeon MultiSensor
Wes, just saw the support for this in MobiLinc. Couple of things:
What I call the "environment" node really doesn't have a status. You populate status with the temperature.
The Temperature & Luminance needs to be divided by 100 to get the values the ISY uses. I think the values you are using are the raw values retrieved from the sensor.
Hi Andy,
That's correct, if the node doesn't explicitly send a "ST" (Status) update to MobiLinc, then MobiLinc will use the first received status-like update for the node in place of the status field in MobiLinc. In this case, temperature.
Can you send me a screenshot of MobiLinc and the ISY's Admin Console to show me what you are seeing in terms of numbers and the differences? Please send to support@mobilinc.com
Wes
Pictures sent.
