junglebell Posted August 27, 2014 Share Posted August 27, 2014 I am very new to Elk/ ISY and I posted this question in CocoonTech forums earlier - trying to see if we can find an answer here? While this rule turns the light on, it does not turn it off after 30 seconds: --- WHENEVER Door (Zn 10) BECOMES NOT SECURE THEN TURN Light [1 (A1)] ON, FADE RATE = 0 FOR 30 SECS --- I am using M1G (firmware 5.3.0) with ISY 994i (firmware 4.0.5) and INSTEON. The interesting part is that the following rule works perfectly: --- WHENEVER Door (Zn 10) BECOMES NOT SECURE THEN TURN Output 001 (Out 1) ON FOR 5 SECS --- Could this be an ISY issue or incorrect Elk rule programming? Any help is appreciated. Thanks so much. Link to comment Share on other sites More sharing options...
rahnee Posted August 27, 2014 Share Posted August 27, 2014 Since you have an ISY, and I am assuming that all devices are Insteon controlled, I suggest you take the rules out of the ELK and put them on the ISY. You can monitor for zones changing status etc. and then have the ISY do all the work. ISY is far more versatile and granular when it comes to the rules and controlling devices. This way you can also easily add/remove devices without having to import/export from ISY to ELK. I have similar rules (see below) The only thing I use ELK rules for are for turning on/off outputs. I have the ISY looking for output changes and then do something. If From Sunset + 10 minutes To Sunrise + 10 minutes (next day) And Elk Zone 'Garage Side Door' is Violated Then Set Scene 'Scenes / Outside Lights / Deck and Flood Lights' On Wait 10 minutes Set Scene 'Scenes / Outside Lights / Deck and Flood Lights' Off Else - No Actions - (To add one, press 'Action') Link to comment Share on other sites More sharing options...
junglebell Posted August 27, 2014 Author Share Posted August 27, 2014 Thanks rahnee, you are right - all devices are Insteon controlled. Would I need to purchase the optional Elk add-on module or could I do this as part of standard ISY programs? thanks so much for your help. Link to comment Share on other sites More sharing options...
rahnee Posted August 27, 2014 Share Posted August 27, 2014 You would need the ELK module to do this. It isn't inexpensive but the possibilities are then endless! Link to comment Share on other sites More sharing options...
