EZIO8 Comm issues
hello everyone,
xathros as that i start a new thread about my EZIO8 comm issues.
background: the ezio8 is located with some pool equipment that is fed from a breaker in the outside house panel. all other insteon devices not at the pool equipment location is on two other panels (inside house panel and emergency generator panel).
having comm issues with the ezio8 mostly (but the other insteon devices out there are fine).
attached is a log just generated with the system as is. i sent on and off commands to 4 of the relays (1 relay #1 did not return to off when it said it had) had to send another off command to getbit to work. then query the whole device to confirm. also when relay 3 output turns on, the device it triggers is supposed to send back a voltage to input relay 4 which never works unless i query it.
also attached is a pdf that shows all my insteon devices and what panels they're on.
Wed 09/03/2014 01:41:51 PM : [INST-TX-I1  ] 02 62 21 2D 92 0F 46 03
Wed 09/03/2014 01:41:51 PM : [INST-ACK    ] 02 62 21.2D.92 0F 46 03 06          IOOFF  (03)
Wed 09/03/2014 01:41:52 PM : [INST-SRX    ] 02 50 21.2D.92 2F.B8.09 23 46 00    IOOFF  (00)
Wed 09/03/2014 01:41:52 PM : [Std-Direct Ack] 21.2D.92-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Wed 09/03/2014 01:41:52 PM : [D2D EVENT   ] Event [21 2D 92 4] [ST] [0] uom=0 prec=-1
Wed 09/03/2014 01:41:52 PM : [  21 2D 92 4]       ST   0
Wed 09/03/2014 01:41:52 PM : [D2D-CMP 0054] STS [21 2D 92 4] ST op=1 Event(val=0 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> false
Wed 09/03/2014 01:41:52 PM : [D2D-CMP 0053] STS [21 2D 92 4] ST op=1 Event(val=0 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> false
Wed 09/03/2014 01:41:58 PM : [INST-TX-I1  ] 02 62 21 2D 92 0F 45 03
Wed 09/03/2014 01:41:58 PM : [INST-ACK    ] 02 62 21.2D.92 0F 45 03 06          IOON   (03)
Wed 09/03/2014 01:41:58 PM : [INST-SRX    ] 02 50 21.2D.92 2F.B8.09 27 45 08    IOON   (08)
Wed 09/03/2014 01:41:58 PM : [Std-Direct Ack] 21.2D.92-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Wed 09/03/2014 01:41:58 PM : [D2D EVENT   ] Event [21 2D 92 4] [ST] [255] uom=0 prec=-1
Wed 09/03/2014 01:41:58 PM : [  21 2D 92 4]       ST 255
Wed 09/03/2014 01:41:58 PM : [D2D-CMP 0054] STS [21 2D 92 4] ST op=1 Event(val=255 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> true
Wed 09/03/2014 01:41:58 PM : [D2D-CMP 0053] STS [21 2D 92 4] ST op=1 Event(val=255 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> true
Wed 09/03/2014 01:42:03 PM : [INST-TX-I1  ] 02 62 21 2D 92 0F 45 00
Wed 09/03/2014 01:42:03 PM : [INST-ACK    ] 02 62 21.2D.92 0F 45 00 06          IOON   (00)
Wed 09/03/2014 01:42:05 PM : [INST-SRX    ] 02 50 21.2D.92 2F.B8.09 27 45 09    IOON   (09)
Wed 09/03/2014 01:42:05 PM : [Std-Direct Ack] 21.2D.92-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Wed 09/03/2014 01:42:05 PM : [D2D EVENT   ] Event [21 2D 92 1] [ST] [255] uom=0 prec=-1
Wed 09/03/2014 01:42:05 PM : [  21 2D 92 1]       ST 255
Wed 09/03/2014 01:42:05 PM : [D2D-CMP 0051] STS [21 2D 92 1] ST op=1 Event(val=255 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> true
Wed 09/03/2014 01:42:05 PM : [D2D-CMP 0049] STS [21 2D 92 1] ST op=1 Event(val=255 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> true
Wed 09/03/2014 01:42:05 PM : [D2D-CMP 0027] STS [21 2D 92 1] ST op=1 Event(val=255 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> true
Wed 09/03/2014 01:42:05 PM : [D2D-CMP 0027] STS [21 2D 92 1] ST op=1 Event(val=255 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> false
Wed 09/03/2014 01:42:06 PM : [INST-TX-I1  ] 02 62 21 2D 92 0F 45 01
Wed 09/03/2014 01:42:06 PM : [INST-ACK    ] 02 62 21.2D.92 0F 45 01 06          IOON   (01)
Wed 09/03/2014 01:42:07 PM : [INST-SRX    ] 02 50 21.2D.92 2F.B8.09 27 45 0B    IOON   (0B)
Wed 09/03/2014 01:42:07 PM : [Std-Direct Ack] 21.2D.92-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Wed 09/03/2014 01:42:07 PM : [D2D EVENT   ] Event [21 2D 92 2] [ST] [255] uom=0 prec=-1
Wed 09/03/2014 01:42:07 PM : [  21 2D 92 2]       ST 255
Wed 09/03/2014 01:42:07 PM : [D2D-CMP 0052] STS [21 2D 92 2] ST op=1 Event(val=255 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> true
Wed 09/03/2014 01:42:07 PM : [D2D-CMP 0049] STS [21 2D 92 2] ST op=1 Event(val=255 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> true
Wed 09/03/2014 01:42:07 PM : [D2D-CMP 0027] STS [21 2D 92 2] ST op=1 Event(val=255 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> false
Wed 09/03/2014 01:42:07 PM : [D2D-CMP 0027] STS [21 2D 92 2] ST op=1 Event(val=255 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> true
Wed 09/03/2014 01:42:07 PM : [INST-SRX    ] 02 50 21.2D.92 2F.B8.09 23 45 0B    IOON   (0B)
Wed 09/03/2014 01:42:07 PM : [Std-Direct Ack] 21.2D.92-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Wed 09/03/2014 01:42:13 PM : [INST-TX-I1  ] 02 62 21 2D 92 0F 45 02
Wed 09/03/2014 01:42:13 PM : [INST-ACK    ] 02 62 21.2D.92 0F 45 02 06          IOON   (02)
Wed 09/03/2014 01:42:13 PM : [INST-SRX    ] 02 50 21.2D.92 2F.B8.09 27 45 0F    IOON   (0F)
Wed 09/03/2014 01:42:14 PM : [Std-Direct Ack] 21.2D.92-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Wed 09/03/2014 01:42:14 PM : [D2D EVENT   ] Event [21 2D 92 3] [ST] [255] uom=0 prec=-1
Wed 09/03/2014 01:42:14 PM : [  21 2D 92 3]       ST 255
Wed 09/03/2014 01:42:14 PM : [D2D-CMP 0048] STS [21 2D 92 3] ST op=1 Event(val=255 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> true
Wed 09/03/2014 01:42:14 PM : [D2D-CMP 001C] STS [21 2D 92 3] ST op=1 Event(val=255 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> true
Wed 09/03/2014 01:42:14 PM : [INST-TX-I1  ] 02 62 21 2D 92 0F 45 05
Wed 09/03/2014 01:42:14 PM : [INST-ACK    ] 02 62 21.2D.92 0F 45 05 06          IOON   (05)
Wed 09/03/2014 01:42:14 PM : [INST-SRX    ] 02 50 21.2D.92 2F.B8.09 27 45 2F    IOON   (2F)
Wed 09/03/2014 01:42:14 PM : [D2D EVENT   ] Event [21 2D 92 6] [ST] [255] uom=0 prec=-1
Wed 09/03/2014 01:42:14 PM : [  21 2D 92 6]       ST 255
Wed 09/03/2014 01:42:15 PM : [INST-SRX    ] 02 50 21.2D.92 2F.B8.09 23 45 2F    IOON   (2F)
Wed 09/03/2014 01:42:15 PM : [Std-Direct Ack] 21.2D.92-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Wed 09/03/2014 01:42:17 PM : [INST-TX-I1  ] 02 62 21 2D 92 0F 46 02
Wed 09/03/2014 01:42:17 PM : [INST-ACK    ] 02 62 21.2D.92 0F 46 02 06          IOOFF  (02)
Wed 09/03/2014 01:42:17 PM : [VAR  2    8 ]       347
Wed 09/03/2014 01:42:18 PM : [INST-SRX    ] 02 50 21.2D.92 2F.B8.09 27 46 2B    IOOFF  (2B)
Wed 09/03/2014 01:42:18 PM : [Std-Direct Ack] 21.2D.92-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Wed 09/03/2014 01:42:18 PM : [D2D EVENT   ] Event [21 2D 92 3] [ST] [0] uom=0 prec=-1
Wed 09/03/2014 01:42:18 PM : [  21 2D 92 3]       ST   0
Wed 09/03/2014 01:42:18 PM : [D2D-CMP 0048] STS [21 2D 92 3] ST op=1 Event(val=0 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> false
Wed 09/03/2014 01:42:18 PM : [D2D-CMP 001C] STS [21 2D 92 3] ST op=1 Event(val=0 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> false
Wed 09/03/2014 01:42:18 PM : [INST-TX-I1  ] 02 62 21 2D 92 0F 46 05
Wed 09/03/2014 01:42:18 PM : [INST-ACK    ] 02 62 21.2D.92 0F 46 05 06          IOOFF  (05)
Wed 09/03/2014 01:42:18 PM : [INST-SRX    ] 02 50 21.2D.92 2F.B8.09 27 46 0B    IOOFF  (0B)
Wed 09/03/2014 01:42:18 PM : [D2D EVENT   ] Event [21 2D 92 6] [ST] [0] uom=0 prec=-1
Wed 09/03/2014 01:42:18 PM : [  21 2D 92 6]       ST   0
Wed 09/03/2014 01:42:19 PM : [INST-SRX    ] 02 50 21.2D.92 2F.B8.09 23 46 0B    IOOFF  (0B)
Wed 09/03/2014 01:42:19 PM : [Std-Direct Ack] 21.2D.92-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Wed 09/03/2014 01:42:20 PM : [INST-TX-I1  ] 02 62 21 2D 92 0F 46 01
Wed 09/03/2014 01:42:20 PM : [INST-ACK    ] 02 62 21.2D.92 0F 46 01 06          IOOFF  (01)
Wed 09/03/2014 01:42:21 PM : [INST-SRX    ] 02 50 21.2D.92 2F.B8.09 27 46 09    IOOFF  (09)
Wed 09/03/2014 01:42:21 PM : [Std-Direct Ack] 21.2D.92-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Wed 09/03/2014 01:42:21 PM : [D2D EVENT   ] Event [21 2D 92 2] [ST] [0] uom=0 prec=-1
Wed 09/03/2014 01:42:21 PM : [  21 2D 92 2]       ST   0
Wed 09/03/2014 01:42:21 PM : [D2D-CMP 0052] STS [21 2D 92 2] ST op=1 Event(val=0 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> false
Wed 09/03/2014 01:42:21 PM : [D2D-CMP 0049] STS [21 2D 92 2] ST op=1 Event(val=0 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> false
Wed 09/03/2014 01:42:21 PM : [D2D-CMP 0027] STS [21 2D 92 2] ST op=1 Event(val=0 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true
Wed 09/03/2014 01:42:21 PM : [D2D-CMP 0027] STS [21 2D 92 2] ST op=1 Event(val=0 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> false
Wed 09/03/2014 01:42:22 PM : [INST-SRX    ] 02 50 21.2D.92 00.00.0C C7 13 00    LTOFFRR(00)
Wed 09/03/2014 01:42:22 PM : [Std-Group   ] 21.2D.92-->Group=12, Max Hops=3, Hops Left=1
Wed 09/03/2014 01:42:22 PM : [D2D EVENT   ] Event [21 2D 92 C] [DOF] [0] uom=0 prec=-1
Wed 09/03/2014 01:42:22 PM : [  21 2D 92 C]      DOF   0
Wed 09/03/2014 01:42:23 PM : [INST-SRX    ] 02 50 21.2D.92 2F.B8.09 41 13 0C    LTOFFRR(0C)
Wed 09/03/2014 01:42:23 PM : [Std-Cleanup ] 21.2D.92-->ISY/PLM Group=12, Max Hops=1, Hops Left=0
Wed 09/03/2014 01:42:23 PM : [INST-DUP    ] Previous message ignored.
Wed 09/03/2014 01:42:23 PM : [INST-TX-I1  ] 02 62 21 2D 92 0F 46 00
Wed 09/03/2014 01:42:23 PM : [INST-ACK    ] 02 62 21.2D.92 0F 46 00 06          IOOFF  (00)
Wed 09/03/2014 01:42:23 PM : [INST-SRX    ] 02 50 21.2D.92 2F.B8.09 27 46 08    IOOFF  (08)
Wed 09/03/2014 01:42:23 PM : [Std-Direct Ack] 21.2D.92-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Wed 09/03/2014 01:42:23 PM : [D2D EVENT   ] Event [21 2D 92 1] [ST] [0] uom=0 prec=-1
Wed 09/03/2014 01:42:23 PM : [  21 2D 92 1]       ST   0
Wed 09/03/2014 01:42:23 PM : [D2D-CMP 0051] STS [21 2D 92 1] ST op=1 Event(val=0 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> false
Wed 09/03/2014 01:42:23 PM : [D2D-CMP 0049] STS [21 2D 92 1] ST op=1 Event(val=0 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> false
Wed 09/03/2014 01:42:23 PM : [D2D-CMP 0027] STS [21 2D 92 1] ST op=1 Event(val=0 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> false
Wed 09/03/2014 01:42:24 PM : [D2D-CMP 0027] STS [21 2D 92 1] ST op=1 Event(val=0 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true
Wed 09/03/2014 01:42:24 PM : [INST-SRX    ] 02 50 21.2D.92 2F.B8.09 23 46 08    IOOFF  (08)
Wed 09/03/2014 01:42:24 PM : [Std-Direct Ack] 21.2D.92-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Wed 09/03/2014 01:42:40 PM : [INST-TX-I1  ] 02 62 19 86 B5 0F 82 00
Wed 09/03/2014 01:42:40 PM : [INST-ACK    ] 02 62 19.86.B5 0F 82 00 06                 (00)
Wed 09/03/2014 01:42:40 PM : [INST-SRX    ] 02 50 19.86.B5 2F.B8.09 2B 82 00           (00)
Wed 09/03/2014 01:42:40 PM : [Std-Direct Ack] 19.86.B5-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 09/03/2014 01:42:41 PM : [INST-ERX    ] 02 51 19 86 B5 2F B8 09 1B 82 00 00 02 01 0C 00 81 00 02 00 08 8E 5E A5 8A
Wed 09/03/2014 01:42:41 PM : [Ext-Direct  ] 19.86.B5-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
electrical panel.pdf
I see lots of Hops=3, Left=0 and Left=1.  This indicates marginal comms from top to bottom of this trace.
Lets do the extension cord test next.
-Xathros
Next up in the hour I will try removing the plm and extended it away with an extension cord and try the test again and post results here.
Ironically all the equipment back there has hops left of 1 or 0. It's just that the EZIO8 is the one that fails to deliver. The rest work.
Every Relay On or Off sent to EZIO8SA was received and the correct response was sent from the EZIO8SA back to the ISY/PLM.
If relays are not functioning as expected check the wiring connections to the relays.
Wed 09/03/2014 01:41:51 PM : [iNST-TX-I1  ] 02 62 21 2D 92 0F 46 03 -- Relay 4 Off
Wed 09/03/2014 01:41:58 PM : [iNST-TX-I1  ] 02 62 21 2D 92 0F 45 03 -- Relay 4 On
Wed 09/03/2014 01:41:58 PM : [iNST-SRX    ] 02 50 21.2D.92 2F.B8.09 27 45 08    IOON   (08) -- relay 4 On response
Wed 09/03/2014 01:42:03 PM : [iNST-TX-I1  ] 02 62 21 2D 92 0F 45 00 -- Relay 1 On
Wed 09/03/2014 01:42:05 PM : [iNST-SRX    ] 02 50 21.2D.92 2F.B8.09 27 45 09    IOON   (09) -- relay 1 and 4 On response
Wed 09/03/2014 01:42:06 PM : [iNST-TX-I1  ] 02 62 21 2D 92 0F 45 01 -- Relay 2 On
Wed 09/03/2014 01:42:07 PM : [iNST-SRX    ] 02 50 21.2D.92 2F.B8.09 27 45 0B    IOON   (0B) -- relay 1,2,4 On response
Wed 09/03/2014 01:42:13 PM : [iNST-TX-I1  ] 02 62 21 2D 92 0F 45 02 -- Relay 3 On
Wed 09/03/2014 01:42:13 PM : [iNST-SRX    ] 02 50 21.2D.92 2F.B8.09 27 45 0F    IOON   (0F) -- relay 1,2,3,4 On response
Wed 09/03/2014 01:42:14 PM : [iNST-TX-I1  ] 02 62 21 2D 92 0F 45 05 -- Relay 6 On
Wed 09/03/2014 01:42:14 PM : [iNST-SRX    ] 02 50 21.2D.92 2F.B8.09 27 45 2F    IOON   (2F) -- relay 1,2,3,4,6 On response
Wed 09/03/2014 01:42:17 PM : [iNST-TX-I1  ] 02 62 21 2D 92 0F 46 02 -- Relay 3 Off
Wed 09/03/2014 01:42:18 PM : [iNST-SRX    ] 02 50 21.2D.92 2F.B8.09 27 46 2B    IOOFF  (2B) -- relay 1,2,4,6 On response
Wed 09/03/2014 01:42:18 PM : [iNST-TX-I1  ] 02 62 21 2D 92 0F 46 05 - Relay 6 Off
Wed 09/03/2014 01:42:18 PM : [iNST-SRX    ] 02 50 21.2D.92 2F.B8.09 27 46 0B    IOOFF  (0B) -- relay 1,2,4 On response
Wed 09/03/2014 01:42:20 PM : [iNST-TX-I1  ] 02 62 21 2D 92 0F 46 01 -- Relay 2 Off
Wed 09/03/2014 01:42:21 PM : [iNST-SRX    ] 02 50 21.2D.92 2F.B8.09 27 46 09    IOOFF  (09) -- relay 1,4 On response
Wed 09/03/2014 01:42:22 PM : [iNST-SRX    ] 02 50 21.2D.92 00.00.0C C7 13 00    LTOFFRR(00) -- Input 4 Off
Wed 09/03/2014 01:42:23 PM : [iNST-TX-I1  ] 02 62 21 2D 92 0F 46 00 -- Relay 1 Off
Wed 09/03/2014 01:42:23 PM : [iNST-SRX    ] 02 50 21.2D.92 2F.B8.09 27 46 08    IOOFF  (08) -- relay 4 On response
Edited by LeeG
Did you see saying in the log that represents input 1 or 4 of the EZIO? 1 seems to get thru to the ISY but 4 never does without a query. I have spoken with the Smartenit guys several times thinking I had a bad device but they eventually said it was comm.
Did you see anything in the log for output 2? During the test that generated the log, I sent an on and off to outputs 1-4 but all but the off to output 3 worked. It showed that it was off, but a query showed it on and I had to resend an off. This is the problem. ISY thinks things are in one state, then a query forces it to truly show what's going on.
Edited by ravedog
I'm going to turn off all the programs that deal with the ezio8 and do the test again for the log, I'm sure there are other things in the log that are popping up that are merely happening based on states changes.
Input 4 turned Off ...
The Inputs 1-7 are numbered 9,A,B,C,D,E,F.   The message from C is for Input 4 with the 0x13 being the Off command.
Relay 2 turned On
and Relay 2 turned Off
All Relay commands traced from PLM reached the EZIO8SA and the EZIO8SA responded with the expected cmd2 value (bit map of relays, from right to left relay 1-8, bit On indicates relay On)
Edited by LeeG
Input 4 seems to always turn off without a query but turning on never shows unless I force the query. Output 2 as you said shows on and off. Reality was that 2 did not go off.
This unit was flaky from the start. When I first added it, none of the inputs were dynamic. Hooking 12v to any if the inputs directly never was reported to the ISY. Only a query worked. Smartenit had be factory reset the unit, delete it from the ISY then re-add it by using the insteon address. Then inputs were working when I state changed. But not reliably after that.
"Output 2 as you said shows on and off. Reality was that 2 did not go off. "
That is not a comm issue.  The response from the EZIO8SA indicates the EZIO8SA turned the relay Off.   If it did not actually turn Off (which I have to question) it indicates a failure in the EZIO8SA itself.
I think there is another issue to be worked out.   Having a relay change the state of one of the Inputs can be a problem.  The EZIO8SA is in the process of generating a response to the relay command at the same time the EZIO8SA is trying to generate a message about the change in Input state.   Have not seen that combination in some time but memory of that combination was always an issue.   Its like pressing multiple KPL buttons at same time.   The KPL will usually lose the change in state of one of the buttons.   .
I'll be specific about the inputs and outputs.
Output 4 close a contact to the heater to trigger it turn start heating. No voltage per se, just close the contact. Heater turns on and lights up an led on the front of its panel indicating active heating (turns off again when temp reaches it's set point on the manual dial.). I have wires from that led (24vac coming back to my box and run into a 24vac to 12vdc converter. Output of converter (12v) runs into the input 4 of the ezio8.
The ISY has a program that looks for state change on input 4. If turned on it tells an output relay to turn on an Led light I built that's off in the landscape that glows red to indicate heating. (Always wanted visual feedback of the heaters active state). Right now only the input is just watched. It doesn't trigger anything right now. Just looking for an on and off state change.
Even though technically the output to turn on the heater and the input back received from the heater is very short, it should not be missed by the EZIO. How can anyone control timing of any input or output in the sense that yiu can't have inks happen simultaneously or the notification might be lost. Seems inconvenient at best. I could send a command to turn on the heater wait 1 second, then force a query (querying an EZIO is all or nothing ... U can't just query input 4 you have to query the entire device which is a lot of traffic). Then check the input state then have the program do something.
This can and does work... But seems not intuitive to the nature of inputs. The inputs should inform the ISY. They ISY shouldn't have to ask.
Plus there's input 1 which takes its input from the heaters power led. And that works and that reports to the ISY both on and off.
Edit: by the way Lee, thank you for helping me understand some of this, can't thank you enough.
Edited by ravedog
A Query of the EZIO8SA takes two commands.   One command returns the state of all relays and one command returns the state of all Inputs.
I was told by the smartenit guy that in order to query it - i had to query output 1 and that tells it to trigger all ins and outs and that is the only way to query it. doing this worked. I got input responding as well.
That is correct.   Query EZIO8SA relay 1, two commands are issued.
The first command, 0x4F 0x02, returns the state of all relays as a single byte bit map (0x10).
 Thu 09/04/2014 03:13:22 AM : [iNST-TX-I1  ] 02 62 0D FC 71 0F 4F 02
Thu 09/04/2014 03:13:22 AM : [iNST-ACK    ] 02 62 0D.FC.71 0F 4F 02 06          IOCTL  (QUERY)
Thu 09/04/2014 03:13:22 AM : [iNST-SRX    ] 02 50 0D.FC.71 22.80.0B 2B 4F 10    IOCTL  (10)
Thu 09/04/2014 03:13:22 AM : [std-Direct Ack] 0D.FC.71-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Thu 09/04/2014 03:13:22 AM : [D2D EVENT   ] Event [D FC 71 1] [sT] [0] uom=0 prec=-1
Thu 09/04/2014 03:13:22 AM : [   D FC 71 1]       ST   0
Thu 09/04/2014 03:13:22 AM : [D2D-CMP 0059] STS [D FC 71 1] ST op=1 Event(val=0 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true
The second command, 0x49 0x00, returns the state of all Inputs as a single byte bit map (0x30
Thu 09/04/2014 03:13:22 AM : [iNST-TX-I1  ] 02 62 0D FC 71 0F 49 00
Thu 09/04/2014 03:13:22 AM : [iNST-ACK    ] 02 62 0D.FC.71 0F 49 00 06          RINPUT (00)
Thu 09/04/2014 03:13:22 AM : [iNST-SRX    ] 02 50 0D.FC.71 22.80.0B 2B 49 30    RINPUT (30)
That good to know. Thanks for the clarification. Any more thoughts on the input relay 4 being triggered by the heater component, since I clarified the process?
If you have a scope check the level and form of the converted AC to DC signal.   The circuits in the EZIO8SA will have problems if the  converted AC signal is not clean, steady DC.
Apply the 12 DC line from the EZIO8SA to Input 4 + (- should be connected to EZIO8SA Gnd). .   Does that cause the Input to signal On and Off to the ISY?   If that works but the Input is not reliable when an EZIO8SA relay is being controlled at the same time the relay messages and the Input state change messages are likely interfering with each other.
Will check the signal tonight at work.
Smartenit is overnighting me a new plm and ezio8 today. Will be doing some tests over the weekend.
Also got 2 new voltage converters shipped as well. JIC
Hey LeeG:
Latest update: yesterday I got the replacement PLM & EZIO8SA bundle from Smartenit.
  1. I first hooked AN1 & AN2 to ground terminal before I even plugged it in.
  2. I've added it to the ISY (by selecting Link Management > New Insteon Device... I entered it's Address, a Name and Device Type: [07.04] Compacta EZIO8SA: Insteon I/O Controller. I captured the event log at Level 3 (see below).
I then ran some tests and captured to log (see below).
  1. Sent On and Off of all 8 relays (thru my MobiLinc App so I could watch the ISY Interface separately) and tested every relay terminal with an ohm meter. All matched the ISY's understanding of it's state.
  2. I then took the 12VDC from the EZIO8 and tested inputs 1-4. Each one dynamically changed their state in the ISY. All worked.
  3. I chose Diagnostics > Query Insteon Engine and captured to a log (see below)
Everything appears to be good. Going to run a duplicate test this morning from the same outlet. Then move to replace the old one and repeat the tests with new captured data.
Also... came across Advanced > PLM Communication: And saw each of the input relays have settings to change the retry count (they are still set at 1 retry. Just curious what this was for.
Log (adding new EZIO):
Sun 09/07/2014 02:10:24 AM : [21 1F E2    ] Added to list of devices to link to ISY
Sun 09/07/2014 02:10:24 AM : [INST-TX-I1  ] 02 62 21 1F E2 0F 0D 00
Sun 09/07/2014 02:10:24 AM : [INST-ACK    ] 02 62 21.1F.E2 0F 0D 00 06                 (00)
Sun 09/07/2014 02:10:24 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 0D 02           (02)
Sun 09/07/2014 02:10:24 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:10:24 AM : [INST-TX-I1  ] 02 62 21 1F E2 0F 10 00
Sun 09/07/2014 02:10:24 AM : [INST-ACK    ] 02 62 21.1F.E2 0F 10 00 06          ID-REQ (00)
Sun 09/07/2014 02:10:25 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 10 00    ID-REQ (00)
Sun 09/07/2014 02:10:25 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:10:25 AM : [INST-SRX    ] 02 50 21.1F.E2 07.04.FF 87 01 00           (00)
Sun 09/07/2014 02:10:25 AM : [Std-Broadcast] 21.1F.E2-->07.04.FF, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:10:25 AM : [21 1F E2 0  ] Calibrating engine version
Sun 09/07/2014 02:10:25 AM : [INST-TX-I2CS] 02 62 21 1F E2 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0
Sun 09/07/2014 02:10:25 AM : [INST-ACK    ] 02 62 21.1F.E2 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0 06        (00)
Sun 09/07/2014 02:10:25 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 2F 00           (00)
Sun 09/07/2014 02:10:26 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 23 2F 00           (00)
Sun 09/07/2014 02:10:26 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sun 09/07/2014 02:10:26 AM : [INST-ERX    ] 02 51 21 1F E2 2F B8 09 11 2F 00 00 01 1F FF 00 62 09 2F B8 09 01 00 09 4D
Sun 09/07/2014 02:10:26 AM : [Ext-Direct  ] 21.1F.E2-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Sun 09/07/2014 02:10:26 AM : [21 1F E2 0  ] Using Database Link Table offset 0x1FF8 (reported 0x1FF8)
Sun 09/07/2014 02:10:26 AM : [21 1F E2 1  ] Start : Adding device to ISY
Sun 09/07/2014 02:10:26 AM : [21 1F E2 1  ] Finish : Adding device to ISY was Successful
Sun 09/07/2014 02:10:26 AM : [INST-TX-I1  ] 02 62 21 1F E2 0F 4D 44
Sun 09/07/2014 02:10:26 AM : [INST-ACK    ] 02 62 21.1F.E2 0F 4D 44 06                 (44)
Sun 09/07/2014 02:10:26 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 4D 44           (44)
Sun 09/07/2014 02:10:26 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:10:26 AM : [21 1F E2 2  ] Start : Adding device to ISY
Sun 09/07/2014 02:10:26 AM : [21 1F E2 2  ] Finish : Adding device to ISY was Successful
Sun 09/07/2014 02:10:26 AM : [21 1F E2 3  ] Start : Adding device to ISY
Sun 09/07/2014 02:10:26 AM : [21 1F E2 3  ] Finish : Adding device to ISY was Successful
Sun 09/07/2014 02:10:26 AM : [21 1F E2 4  ] Start : Adding device to ISY
Sun 09/07/2014 02:10:26 AM : [21 1F E2 4  ] Finish : Adding device to ISY was Successful
Sun 09/07/2014 02:10:26 AM : [21 1F E2 5  ] Start : Adding device to ISY
Sun 09/07/2014 02:10:26 AM : [21 1F E2 5  ] Finish : Adding device to ISY was Successful
Sun 09/07/2014 02:10:26 AM : [21 1F E2 6  ] Start : Adding device to ISY
Sun 09/07/2014 02:10:26 AM : [21 1F E2 6  ] Finish : Adding device to ISY was Successful
Sun 09/07/2014 02:10:26 AM : [21 1F E2 7  ] Start : Adding device to ISY
Sun 09/07/2014 02:10:27 AM : [21 1F E2 7  ] Finish : Adding device to ISY was Successful
Sun 09/07/2014 02:10:27 AM : [21 1F E2 8  ] Start : Adding device to ISY
Sun 09/07/2014 02:10:27 AM : [21 1F E2 8  ] Finish : Adding device to ISY was Successful
Sun 09/07/2014 02:10:27 AM : [21 1F E2 9  ] Start : Adding device to ISY
Sun 09/07/2014 02:10:27 AM : [21 1F E2 9  ] Finish : Adding device to ISY was Successful
Sun 09/07/2014 02:10:27 AM : [21 1F E2 9  ] Link    0 : 1FF8 [E2092FB809010009] Saving  [E2092FB809010009]
Sun 09/07/2014 02:10:27 AM : [21 1F E2 A  ] Start : Adding device to ISY
Sun 09/07/2014 02:10:27 AM : [21 1F E2 A  ] Finish : Adding device to ISY was Successful
Sun 09/07/2014 02:10:27 AM : [21 1F E2 A  ] Link    1 : 1FF0 [E20A2FB80901000A] Saving  [E20A2FB80901000A]
Sun 09/07/2014 02:10:27 AM : [21 1F E2 B  ] Start : Adding device to ISY
Sun 09/07/2014 02:10:27 AM : [21 1F E2 B  ] Finish : Adding device to ISY was Successful
Sun 09/07/2014 02:10:27 AM : [21 1F E2 B  ] Link    2 : 1FE8 [E20B2FB80901000B] Saving  [E20B2FB80901000B]
Sun 09/07/2014 02:10:27 AM : [21 1F E2 C  ] Start : Adding device to ISY
Sun 09/07/2014 02:10:27 AM : [21 1F E2 C  ] Finish : Adding device to ISY was Successful
Sun 09/07/2014 02:10:27 AM : [21 1F E2 C  ] Link    3 : 1FE0 [E20C2FB80901000C] Saving  [E20C2FB80901000C]
Sun 09/07/2014 02:10:27 AM : [21 1F E2 D  ] Start : Adding device to ISY
Sun 09/07/2014 02:10:27 AM : [21 1F E2 D  ] Finish : Adding device to ISY was Successful
Sun 09/07/2014 02:10:27 AM : [21 1F E2 D  ] Link    4 : 1FD8 [E20D2FB80901000D] Saving  [E20D2FB80901000D]
Sun 09/07/2014 02:10:27 AM : [21 1F E2 E  ] Start : Adding device to ISY
Sun 09/07/2014 02:10:27 AM : [21 1F E2 E  ] Finish : Adding device to ISY was Successful
Sun 09/07/2014 02:10:27 AM : [21 1F E2 E  ] Link    5 : 1FD0 [E20E2FB80901000E] Saving  [E20E2FB80901000E]
Sun 09/07/2014 02:10:27 AM : [21 1F E2 F  ] Start : Adding device to ISY
Sun 09/07/2014 02:10:27 AM : [21 1F E2 F  ] Finish : Adding device to ISY was Successful
Sun 09/07/2014 02:10:27 AM : [21 1F E2 F  ] Link    6 : 1FC8 [E20F2FB80901000F] Saving  [E20F2FB80901000F]
Sun 09/07/2014 02:10:27 AM : [INST-TX-I1  ] 02 62 21 1F E2 0F 4F 02
Sun 09/07/2014 02:10:27 AM : [INST-ACK    ] 02 62 21.1F.E2 0F 4F 02 06          IOCTL  (QUERY)
Sun 09/07/2014 02:10:28 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 4F 00    IOCTL  (00)
Sun 09/07/2014 02:10:28 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:10:28 AM : [D2D EVENT   ] Event [21 1F E2 1] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 02:10:28 AM : [  21 1F E2 1]       ST   0
Sun 09/07/2014 02:10:28 AM : [D2D EVENT   ] Event [21 1F E2 2] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 02:10:28 AM : [  21 1F E2 2]       ST   0
Sun 09/07/2014 02:10:28 AM : [D2D EVENT   ] Event [21 1F E2 3] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 02:10:28 AM : [  21 1F E2 3]       ST   0
Sun 09/07/2014 02:10:28 AM : [D2D EVENT   ] Event [21 1F E2 4] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 02:10:28 AM : [  21 1F E2 4]       ST   0
Sun 09/07/2014 02:10:28 AM : [D2D EVENT   ] Event [21 1F E2 5] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 02:10:28 AM : [  21 1F E2 5]       ST   0
Sun 09/07/2014 02:10:28 AM : [D2D EVENT   ] Event [21 1F E2 6] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 02:10:28 AM : [  21 1F E2 6]       ST   0
Sun 09/07/2014 02:10:28 AM : [D2D EVENT   ] Event [21 1F E2 7] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 02:10:28 AM : [  21 1F E2 7]       ST   0
Sun 09/07/2014 02:10:28 AM : [D2D EVENT   ] Event [21 1F E2 8] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 02:10:28 AM : [  21 1F E2 8]       ST   0
Sun 09/07/2014 02:10:28 AM : [INST-TX-I1  ] 02 62 21 1F E2 0F 49 00
Sun 09/07/2014 02:10:28 AM : [INST-ACK    ] 02 62 21.1F.E2 0F 49 00 06          RINPUT (00)
Sun 09/07/2014 02:10:28 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 49 30    RINPUT (30)
Sun 09/07/2014 02:10:28 AM : [D2D EVENT   ] Event [21 1F E2 9] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 02:10:28 AM : [  21 1F E2 9]       ST   0
Sun 09/07/2014 02:10:28 AM : [D2D EVENT   ] Event [21 1F E2 A] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 02:10:28 AM : [  21 1F E2 A]       ST   0
Sun 09/07/2014 02:10:28 AM : [D2D EVENT   ] Event [21 1F E2 B] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 02:10:28 AM : [  21 1F E2 B]       ST   0
Sun 09/07/2014 02:10:29 AM : [D2D EVENT   ] Event [21 1F E2 C] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 02:10:29 AM : [  21 1F E2 C]       ST   0
Sun 09/07/2014 02:10:29 AM : [D2D EVENT   ] Event [21 1F E2 D] [ST] [255] uom=0 prec=-1
Sun 09/07/2014 02:10:29 AM : [  21 1F E2 D]       ST 255
Sun 09/07/2014 02:10:29 AM : [D2D EVENT   ] Event [21 1F E2 E] [ST] [255] uom=0 prec=-1
Sun 09/07/2014 02:10:29 AM : [  21 1F E2 E]       ST 255
Sun 09/07/2014 02:10:29 AM : [21 1F E2 0  ] Successfully added device
Sun 09/07/2014 02:10:30 AM : [All         ] Writing 64 bytes to devices
Sun 09/07/2014 02:10:30 AM : [21 1F E2 1  ] Link    0 : 1FF8 [E2092FB809010009] Writing [E2092FB809010009]
Sun 09/07/2014 02:10:30 AM : [INST-TX-I2CS] 02 62 21 1F E2 1F 2F 00 00 02 1F FF 08 E2 09 2F B8 09 01 00 09 C4
Sun 09/07/2014 02:10:30 AM : [INST-ACK    ] 02 62 21.1F.E2 1F 2F 00 00 02 1F FF 08 E2 09 2F B8 09 01 00 09 C4 06        (00)
Sun 09/07/2014 02:10:31 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 2F 00           (00)
Sun 09/07/2014 02:10:31 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:10:31 AM : [MNG-LNK-RSP ] 02 6F 41 A2 09 21 1F E2 07 04 FF 06
Sun 09/07/2014 02:10:31 AM : [PLM         ] Group   9 : Writing Responder Link matching [21 1F E2 1  ] Link    0 : 1FF8 [E2092FB809010009]
Sun 09/07/2014 02:10:31 AM : [21 1F E2 1  ] Link    1 : 1FF0 [E20A2FB80901000A] Writing [E20A2FB80901000A]
Sun 09/07/2014 02:10:31 AM : [INST-TX-I2CS] 02 62 21 1F E2 1F 2F 00 00 02 1F F7 08 E2 0A 2F B8 09 01 00 0A CA
Sun 09/07/2014 02:10:31 AM : [INST-ACK    ] 02 62 21.1F.E2 1F 2F 00 00 02 1F F7 08 E2 0A 2F B8 09 01 00 0A CA 06        (00)
Sun 09/07/2014 02:10:32 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 2F 00           (00)
Sun 09/07/2014 02:10:32 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:10:32 AM : [MNG-LNK-RSP ] 02 6F 41 A2 0A 21 1F E2 07 04 FF 06
Sun 09/07/2014 02:10:32 AM : [PLM         ] Group  10 : Writing Responder Link matching [21 1F E2 1  ] Link    1 : 1FF0 [E20A2FB80901000A]
Sun 09/07/2014 02:10:32 AM : [21 1F E2 1  ] Link    2 : 1FE8 [E20B2FB80901000B] Writing [E20B2FB80901000B]
Sun 09/07/2014 02:10:32 AM : [INST-TX-I2CS] 02 62 21 1F E2 1F 2F 00 00 02 1F EF 08 E2 0B 2F B8 09 01 00 0B D0
Sun 09/07/2014 02:10:32 AM : [INST-ACK    ] 02 62 21.1F.E2 1F 2F 00 00 02 1F EF 08 E2 0B 2F B8 09 01 00 0B D0 06        (00)
Sun 09/07/2014 02:10:33 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 2F 00           (00)
Sun 09/07/2014 02:10:33 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:10:33 AM : [MNG-LNK-RSP ] 02 6F 41 A2 0B 21 1F E2 07 04 FF 06
Sun 09/07/2014 02:10:33 AM : [PLM         ] Group  11 : Writing Responder Link matching [21 1F E2 1  ] Link    2 : 1FE8 [E20B2FB80901000B]
Sun 09/07/2014 02:10:33 AM : [21 1F E2 1  ] Link    3 : 1FE0 [E20C2FB80901000C] Writing [E20C2FB80901000C]
Sun 09/07/2014 02:10:33 AM : [INST-TX-I2CS] 02 62 21 1F E2 1F 2F 00 00 02 1F E7 08 E2 0C 2F B8 09 01 00 0C D6
Sun 09/07/2014 02:10:34 AM : [INST-ACK    ] 02 62 21.1F.E2 1F 2F 00 00 02 1F E7 08 E2 0C 2F B8 09 01 00 0C D6 06        (00)
Sun 09/07/2014 02:10:34 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 2F 00           (00)
Sun 09/07/2014 02:10:34 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:10:34 AM : [MNG-LNK-RSP ] 02 6F 41 A2 0C 21 1F E2 07 04 FF 06
Sun 09/07/2014 02:10:34 AM : [PLM         ] Group  12 : Writing Responder Link matching [21 1F E2 1  ] Link    3 : 1FE0 [E20C2FB80901000C]
Sun 09/07/2014 02:10:34 AM : [21 1F E2 1  ] Link    4 : 1FD8 [E20D2FB80901000D] Writing [E20D2FB80901000D]
Sun 09/07/2014 02:10:34 AM : [INST-TX-I2CS] 02 62 21 1F E2 1F 2F 00 00 02 1F DF 08 E2 0D 2F B8 09 01 00 0D DC
Sun 09/07/2014 02:10:35 AM : [INST-ACK    ] 02 62 21.1F.E2 1F 2F 00 00 02 1F DF 08 E2 0D 2F B8 09 01 00 0D DC 06        (00)
Sun 09/07/2014 02:10:35 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 2F 00           (00)
Sun 09/07/2014 02:10:35 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:10:35 AM : [MNG-LNK-RSP ] 02 6F 41 A2 0D 21 1F E2 07 04 FF 06
Sun 09/07/2014 02:10:35 AM : [PLM         ] Group  13 : Writing Responder Link matching [21 1F E2 1  ] Link    4 : 1FD8 [E20D2FB80901000D]
Sun 09/07/2014 02:10:36 AM : [21 1F E2 1  ] Link    5 : 1FD0 [E20E2FB80901000E] Writing [E20E2FB80901000E]
Sun 09/07/2014 02:10:36 AM : [INST-TX-I2CS] 02 62 21 1F E2 1F 2F 00 00 02 1F D7 08 E2 0E 2F B8 09 01 00 0E E2
Sun 09/07/2014 02:10:36 AM : [INST-ACK    ] 02 62 21.1F.E2 1F 2F 00 00 02 1F D7 08 E2 0E 2F B8 09 01 00 0E E2 06        (00)
Sun 09/07/2014 02:10:36 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 2F 00           (00)
Sun 09/07/2014 02:10:36 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:10:37 AM : [MNG-LNK-RSP ] 02 6F 41 A2 0E 21 1F E2 07 04 FF 06
Sun 09/07/2014 02:10:37 AM : [PLM         ] Group  14 : Writing Responder Link matching [21 1F E2 1  ] Link    5 : 1FD0 [E20E2FB80901000E]
Sun 09/07/2014 02:10:37 AM : [21 1F E2 1  ] Link    6 : 1FC8 [E20F2FB80901000F] Writing [E20F2FB80901000F]
Sun 09/07/2014 02:10:37 AM : [INST-TX-I2CS] 02 62 21 1F E2 1F 2F 00 00 02 1F CF 08 E2 0F 2F B8 09 01 00 0F E8
Sun 09/07/2014 02:10:37 AM : [INST-ACK    ] 02 62 21.1F.E2 1F 2F 00 00 02 1F CF 08 E2 0F 2F B8 09 01 00 0F E8 06        (00)
Sun 09/07/2014 02:10:38 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 23 2F 00           (00)
Sun 09/07/2014 02:10:38 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sun 09/07/2014 02:10:38 AM : [MNG-LNK-RSP ] 02 6F 41 A2 0F 21 1F E2 07 04 FF 15
Sun 09/07/2014 02:10:38 AM : [PLM         ] Group  15 : Writing Responder Link matching [21 1F E2 1  ] Link    6 : 1FC8 [E20F2FB80901000F]
Sun 09/07/2014 02:10:38 AM : [21 1F E2 1  ] Link    7 : 1FC0 [0000000000000000] Writing [00..............]
Sun 09/07/2014 02:10:38 AM : [INST-TX-I2CS] 02 62 21 1F E2 1F 2F 00 00 02 1F C7 08 00 00 00 00 00 00 00 00 E1
Sun 09/07/2014 02:10:38 AM : [INST-ACK    ] 02 62 21.1F.E2 1F 2F 00 00 02 1F C7 08 00 00 00 00 00 00 00 00 E1 06        (00)
Sun 09/07/2014 02:10:39 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 2F 00           (00)
Sun 09/07/2014 02:10:39 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:10:39 AM : [21 1F E2 1  ] Link    8 : 1FB8 : Writing High Water Byte
Sun 09/07/2014 02:10:39 AM : [INST-TX-I2CS] 02 62 21 1F E2 1F 2F 00 00 00 1F BF 01 00 00 00 00 00 00 00 00 F2
Sun 09/07/2014 02:10:39 AM : [INST-ACK    ] 02 62 21.1F.E2 1F 2F 00 00 00 1F BF 01 00 00 00 00 00 00 00 00 F2 06        (00)
Sun 09/07/2014 02:10:40 AM : [INST-ERX    ] 02 51 21 1F E2 2F B8 09 11 2F 00 00 01 1F BF 00 00 00 00 00 00 00 00 00 F2
Sun 09/07/2014 02:10:40 AM : [Ext-Direct  ] 21.1F.E2-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Sun 09/07/2014 02:10:40 AM : [INST-TX-I2CS] 02 62 21 1F E2 1F 2F 00 00 00 1F BF 01 00 00 00 00 00 00 00 00 F2
Sun 09/07/2014 02:10:40 AM : [INST-ACK    ] 02 62 21.1F.E2 1F 2F 00 00 00 1F BF 01 00 00 00 00 00 00 00 00 F2 06        (00)
Sun 09/07/2014 02:10:40 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 2F 00           (00)
Sun 09/07/2014 02:10:40 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:10:41 AM : [INST-ERX    ] 02 51 21 1F E2 2F B8 09 11 2F 00 00 01 1F BF 00 00 00 00 00 00 00 00 00 F2
Sun 09/07/2014 02:10:41 AM : [Ext-Direct  ] 21.1F.E2-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Sun 09/07/2014 02:10:41 AM : [INST-TX-I2CS] 02 62 21 1F E2 1F 2F 00 00 02 1F BF 08 00 00 00 00 00 00 00 00 E9
Sun 09/07/2014 02:10:41 AM : [INST-ACK    ] 02 62 21.1F.E2 1F 2F 00 00 02 1F BF 08 00 00 00 00 00 00 00 00 E9 06        (00)
Sun 09/07/2014 02:10:43 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 2F 00           (00)
Sun 09/07/2014 02:10:43 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:10:43 AM : [21 1F E2 1  ] Memory : Write dbAddr=0x0046 [0F] cmd1=0x00 cmd2=0x00
Sun 09/07/2014 02:10:43 AM : [INST-TX-I1  ] 02 62 21 1F E2 0F 28 00
Sun 09/07/2014 02:10:43 AM : [INST-ACK    ] 02 62 21.1F.E2 0F 28 00 06          SET-MSB(00)
Sun 09/07/2014 02:10:44 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 28 00    SET-MSB(00)
Sun 09/07/2014 02:10:44 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:10:44 AM : [INST-TX-I1  ] 02 62 21 1F E2 0F 2B 46
Sun 09/07/2014 02:10:44 AM : [INST-ACK    ] 02 62 21.1F.E2 0F 2B 46 06          PEEK   (46)
Sun 09/07/2014 02:10:44 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 2B 0F    PEEK   (0F)
Sun 09/07/2014 02:10:44 AM : [21 1F E2 1  ] Memory : Write dbAddr=0x0045 [0E] cmd1=0x00 cmd2=0x00
Sun 09/07/2014 02:10:44 AM : [INST-TX-I1  ] 02 62 21 1F E2 0F 28 00
Sun 09/07/2014 02:10:44 AM : [INST-ACK    ] 02 62 21.1F.E2 0F 28 00 06          SET-MSB(00)
Sun 09/07/2014 02:10:45 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 28 00    SET-MSB(00)
Sun 09/07/2014 02:10:45 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:10:45 AM : [INST-TX-I1  ] 02 62 21 1F E2 0F 2B 45
Sun 09/07/2014 02:10:45 AM : [INST-ACK    ] 02 62 21.1F.E2 0F 2B 45 06          PEEK   (45)
Sun 09/07/2014 02:10:45 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 2B 0E    PEEK   (0E)
Sun 09/07/2014 02:10:45 AM : [21 1F E2 1  ] Memory : Write dbAddr=0x0044 [0D] cmd1=0x00 cmd2=0x00
Sun 09/07/2014 02:10:45 AM : [INST-TX-I1  ] 02 62 21 1F E2 0F 28 00
Sun 09/07/2014 02:10:45 AM : [INST-ACK    ] 02 62 21.1F.E2 0F 00 45 06                 (45)
Sun 09/07/2014 02:10:46 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 00 45           (45)
Sun 09/07/2014 02:10:46 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:10:46 AM : [D2D EVENT   ] Event [21 1F E2 1] [ST] [255] uom=0 prec=-1
Sun 09/07/2014 02:10:46 AM : [  21 1F E2 1]       ST 255
Sun 09/07/2014 02:10:46 AM : [D2D EVENT   ] Event [21 1F E2 3] [ST] [255] uom=0 prec=-1
Sun 09/07/2014 02:10:46 AM : [  21 1F E2 3]       ST 255
Sun 09/07/2014 02:10:46 AM : [D2D EVENT   ] Event [21 1F E2 7] [ST] [255] uom=0 prec=-1
Sun 09/07/2014 02:10:46 AM : [  21 1F E2 7]       ST 255
Sun 09/07/2014 02:10:51 AM : CLI-HAMW: Connecting to api.aerisapi.com
Sun 09/07/2014 02:10:51 AM : CLI-HAMW: Successfully Processed HAMW Response
Sun 09/07/2014 02:10:52 AM : CLI-HAMW: Successfully Processed HAMW Response
Sun 09/07/2014 02:10:52 AM : CLI-HAMW: Connecting to api.aerisapi.com
Sun 09/07/2014 02:10:55 AM : [INST-TX-I1  ] 02 62 21 1F E2 0F 28 00
Sun 09/07/2014 02:10:55 AM : [INST-ACK    ] 02 62 21.1F.E2 0F 28 00 06          SET-MSB(00)
Sun 09/07/2014 02:10:55 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 28 00    SET-MSB(00)
Sun 09/07/2014 02:10:55 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:10:55 AM : [INST-TX-I1  ] 02 62 21 1F E2 0F 2B 44
Sun 09/07/2014 02:10:55 AM : [INST-ACK    ] 02 62 21.1F.E2 0F 2B 44 06          PEEK   (44)
Sun 09/07/2014 02:10:55 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 23 28 00    SET-MSB(00)
Sun 09/07/2014 02:10:55 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sun 09/07/2014 02:10:55 AM : [D2D EVENT   ] Event [21 1F E2 1] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 02:10:55 AM : [  21 1F E2 1]       ST   0
Sun 09/07/2014 02:10:55 AM : [D2D EVENT   ] Event [21 1F E2 3] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 02:10:55 AM : [  21 1F E2 3]       ST   0
Sun 09/07/2014 02:10:55 AM : [D2D EVENT   ] Event [21 1F E2 7] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 02:10:55 AM : [  21 1F E2 7]       ST   0
Sun 09/07/2014 02:10:56 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 2B 0D    PEEK   (0D)
Sun 09/07/2014 02:10:56 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:10:56 AM : [21 1F E2 1  ] Memory : Write dbAddr=0x0043 [0C] cmd1=0x00 cmd2=0x00
Sun 09/07/2014 02:10:56 AM : [INST-TX-I1  ] 02 62 21 1F E2 0F 28 00
Sun 09/07/2014 02:10:56 AM : [INST-ACK    ] 02 62 21.1F.E2 0F 28 00 06          SET-MSB(00)
Sun 09/07/2014 02:10:56 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 28 00    SET-MSB(00)
Sun 09/07/2014 02:10:56 AM : [INST-TX-I1  ] 02 62 21 1F E2 0F 2B 43
Sun 09/07/2014 02:10:56 AM : [INST-ACK    ] 02 62 21.1F.E2 0F 2B 43 06          PEEK   (43)
Sun 09/07/2014 02:10:57 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 2B 0C    PEEK   (0C)
Sun 09/07/2014 02:10:57 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:10:57 AM : [21 1F E2 1  ] Memory : Write dbAddr=0x0042 [0B] cmd1=0x00 cmd2=0x00
Sun 09/07/2014 02:10:57 AM : [INST-TX-I1  ] 02 62 21 1F E2 0F 28 00
Sun 09/07/2014 02:10:57 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 23 2B 0C    PEEK   (0C)
Sun 09/07/2014 02:10:57 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sun 09/07/2014 02:10:57 AM : [INST-ACK    ] 02 62 21.1F.E2 0F 28 00 06          SET-MSB(00)
Sun 09/07/2014 02:10:57 AM : [D2D EVENT   ] Event [21 1F E2 3] [ST] [255] uom=0 prec=-1
Sun 09/07/2014 02:10:57 AM : [  21 1F E2 3]       ST 255
Sun 09/07/2014 02:10:57 AM : [D2D EVENT   ] Event [21 1F E2 4] [ST] [255] uom=0 prec=-1
Sun 09/07/2014 02:10:57 AM : [  21 1F E2 4]       ST 255
Sun 09/07/2014 02:10:57 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 28 00    SET-MSB(00)
Sun 09/07/2014 02:10:57 AM : [INST-TX-I1  ] 02 62 21 1F E2 0F 2B 42
Sun 09/07/2014 02:10:57 AM : [INST-ACK    ] 02 62 21.1F.E2 0F 2B 42 06          PEEK   (42)
Sun 09/07/2014 02:10:58 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 2B 0B    PEEK   (0B)
Sun 09/07/2014 02:10:58 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:10:58 AM : [21 1F E2 1  ] Memory : Write dbAddr=0x0041 [0A] cmd1=0x00 cmd2=0x00
Sun 09/07/2014 02:10:58 AM : [INST-TX-I1  ] 02 62 21 1F E2 0F 28 00
Sun 09/07/2014 02:10:58 AM : [INST-ACK    ] 02 62 21.1F.E2 0F 28 00 06          SET-MSB(00)
Sun 09/07/2014 02:10:58 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 28 00    SET-MSB(00)
Sun 09/07/2014 02:10:58 AM : [INST-TX-I1  ] 02 62 21 1F E2 0F 2B 41
Sun 09/07/2014 02:10:58 AM : [INST-ACK    ] 02 62 21.1F.E2 0F 2B 41 06          PEEK   (41)
Sun 09/07/2014 02:10:59 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 2B 0A    PEEK   (0A)
Sun 09/07/2014 02:10:59 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:10:59 AM : [21 1F E2 1  ] Memory : Write dbAddr=0x0040 [09] cmd1=0x00 cmd2=0x00
Sun 09/07/2014 02:10:59 AM : [INST-TX-I1  ] 02 62 21 1F E2 0F 28 00
Sun 09/07/2014 02:10:59 AM : [INST-ACK    ] 02 62 21.1F.E2 0F 28 00 06          SET-MSB(00)
Sun 09/07/2014 02:10:59 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 28 00    SET-MSB(00)
Sun 09/07/2014 02:10:59 AM : [INST-TX-I1  ] 02 62 21 1F E2 0F 2B 40
Sun 09/07/2014 02:10:59 AM : [INST-ACK    ] 02 62 21.1F.E2 0F 2B 40 06          PEEK   (40)
Sun 09/07/2014 02:11:00 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 2B 09    PEEK   (09)
Sun 09/07/2014 02:11:00 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:11:00 AM : [INST-TX-I1  ] 02 62 21 1F E2 0F 4F 01
Sun 09/07/2014 02:11:00 AM : [INST-ACK    ] 02 62 21.1F.E2 0F 4F 01 06          IOCTL  (01)
Sun 09/07/2014 02:11:00 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 4F 01    IOCTL  (01)
Sun 09/07/2014 02:11:00 AM : [21 1F E2 1  ] Memory : EPROM Refreshed
Log (Testing relays):
Sun 09/07/2014 02:14:49 AM : [INST-TX-I1  ] 02 62 21 1F E2 0F 45 00
Sun 09/07/2014 02:14:49 AM : [INST-ACK    ] 02 62 21.1F.E2 0F 45 00 06          IOON   (00)
Sun 09/07/2014 02:14:49 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 2B 45 01    IOON   (01)
Sun 09/07/2014 02:14:49 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sun 09/07/2014 02:14:49 AM : [D2D EVENT   ] Event [21 1F E2 1] [ST] [255] uom=0 prec=-1
Sun 09/07/2014 02:14:49 AM : [  21 1F E2 1]       ST 255
Sun 09/07/2014 02:14:49 AM : [D2D EVENT   ] Event [21 1F E2 3] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 02:14:49 AM : [  21 1F E2 3]       ST   0
Sun 09/07/2014 02:14:49 AM : [D2D EVENT   ] Event [21 1F E2 4] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 02:14:49 AM : [  21 1F E2 4]       ST   0
Sun 09/07/2014 02:14:50 AM : [INST-TX-I1  ] 02 62 21 1F E2 0F 46 00
Sun 09/07/2014 02:14:50 AM : [INST-ACK    ] 02 62 21.1F.E2 0F 46 00 06          IOOFF  (00)
Sun 09/07/2014 02:14:50 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 46 00    IOOFF  (00)
Sun 09/07/2014 02:14:50 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:14:50 AM : [D2D EVENT   ] Event [21 1F E2 1] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 02:14:50 AM : [  21 1F E2 1]       ST   0
Sun 09/07/2014 02:14:58 AM : [INST-TX-I1  ] 02 62 21 1F E2 0F 45 01
Sun 09/07/2014 02:14:58 AM : [INST-ACK    ] 02 62 21.1F.E2 0F 45 01 06          IOON   (01)
Sun 09/07/2014 02:14:58 AM : [        Time] 02:15:00 4(0)
Sun 09/07/2014 02:14:58 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 45 02    IOON   (02)
Sun 09/07/2014 02:14:58 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:14:59 AM : [INST-TX-I1  ] 02 62 1D 5D 46 0F 11 FF
Sun 09/07/2014 02:14:59 AM : [INST-ACK    ] 02 62 1D.5D.46 0F 11 FF 06          LTONRR (FF)
Sun 09/07/2014 02:14:59 AM : [D2D EVENT   ] Event [21 1F E2 2] [ST] [255] uom=0 prec=-1
Sun 09/07/2014 02:14:59 AM : [  21 1F E2 2]       ST 255
Sun 09/07/2014 02:14:59 AM : [INST-SRX    ] 02 50 1D.5D.46 2F.B8.09 2B 11 FF    LTONRR (FF)
Sun 09/07/2014 02:14:59 AM : [Std-Direct Ack] 1D.5D.46-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sun 09/07/2014 02:14:59 AM : [D2D EVENT   ] Event [1D 5D 46 1] [ST] [255] uom=0 prec=-1
Sun 09/07/2014 02:14:59 AM : [  1D 5D 46 1]       ST 255
Sun 09/07/2014 02:14:59 AM : [D2D-CMP 005E] STS [1D 5D 46 1] ST op=1 Event(val=255 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> true
Sun 09/07/2014 02:15:00 AM : [INST-TX-I1  ] 02 62 21 1F E2 0F 46 01
Sun 09/07/2014 02:15:00 AM : [INST-TX-I1  ] 02 62 00 00 19 CF 11 00
Sun 09/07/2014 02:15:00 AM : [INST-ACK    ] 02 62 21.1F.E2 0F 46 01 06          IOOFF  (01)
Sun 09/07/2014 02:15:00 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 46 00    IOOFF  (00)
Sun 09/07/2014 02:15:00 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:15:00 AM : [D2D EVENT   ] Event [21 1F E2 2] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 02:15:00 AM : [  21 1F E2 2]       ST   0
Sun 09/07/2014 02:15:00 AM : [INST-ACK    ] 02 62 00.00.19 CF 11 00 06          LTONRR (00)
Sun 09/07/2014 02:15:00 AM : [D2D EVENT   ] Event [2A 11 F4 8] [ST] [255] uom=0 prec=-1
Sun 09/07/2014 02:15:00 AM : [  2A 11 F4 8]       ST 255
Sun 09/07/2014 02:15:14 AM : [INST-TX-I1  ] 02 62 21 1F E2 0F 45 02
Sun 09/07/2014 02:15:14 AM : [INST-ACK    ] 02 62 21.1F.E2 0F 45 02 06          IOON   (02)
Sun 09/07/2014 02:15:14 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 45 04    IOON   (04)
Sun 09/07/2014 02:15:14 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:15:14 AM : [D2D EVENT   ] Event [21 1F E2 3] [ST] [255] uom=0 prec=-1
Sun 09/07/2014 02:15:14 AM : [  21 1F E2 3]       ST 255
Sun 09/07/2014 02:15:15 AM : [INST-TX-I1  ] 02 62 21 1F E2 0F 46 02
Sun 09/07/2014 02:15:15 AM : [INST-ACK    ] 02 62 21.1F.E2 0F 46 02 06          IOOFF  (02)
Sun 09/07/2014 02:15:15 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 46 00    IOOFF  (00)
Sun 09/07/2014 02:15:15 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:15:15 AM : [D2D EVENT   ] Event [21 1F E2 3] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 02:15:15 AM : [  21 1F E2 3]       ST   0
Sun 09/07/2014 02:15:15 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 23 46 00    IOOFF  (00)
Sun 09/07/2014 02:15:15 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sun 09/07/2014 02:15:26 AM : [INST-TX-I1  ] 02 62 21 1F E2 0F 45 03
Sun 09/07/2014 02:15:26 AM : [INST-ACK    ] 02 62 21.1F.E2 0F 45 03 06          IOON   (03)
Sun 09/07/2014 02:15:26 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 45 08    IOON   (08)
Sun 09/07/2014 02:15:26 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:15:26 AM : [D2D EVENT   ] Event [21 1F E2 4] [ST] [255] uom=0 prec=-1
Sun 09/07/2014 02:15:26 AM : [  21 1F E2 4]       ST 255
Sun 09/07/2014 02:15:28 AM : [INST-TX-I1  ] 02 62 21 1F E2 0F 46 03
Sun 09/07/2014 02:15:28 AM : [INST-ACK    ] 02 62 21.1F.E2 0F 46 03 06          IOOFF  (03)
Sun 09/07/2014 02:15:29 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 46 00    IOOFF  (00)
Sun 09/07/2014 02:15:29 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:15:29 AM : [D2D EVENT   ] Event [21 1F E2 4] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 02:15:29 AM : [  21 1F E2 4]       ST   0
Sun 09/07/2014 02:15:29 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 23 46 00    IOOFF  (00)
Sun 09/07/2014 02:15:29 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sun 09/07/2014 02:15:37 AM : [INST-TX-I1  ] 02 62 21 1F E2 0F 45 04
Sun 09/07/2014 02:15:37 AM : [INST-ACK    ] 02 62 21.1F.E2 0F 45 04 06          IOON   (04)
Sun 09/07/2014 02:15:37 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 45 10    IOON   (10)
Sun 09/07/2014 02:15:37 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:15:37 AM : [D2D EVENT   ] Event [21 1F E2 5] [ST] [255] uom=0 prec=-1
Sun 09/07/2014 02:15:37 AM : [  21 1F E2 5]       ST 255
Sun 09/07/2014 02:15:42 AM : [INST-TX-I1  ] 02 62 21 1F E2 0F 46 04
Sun 09/07/2014 02:15:42 AM : [INST-ACK    ] 02 62 21.1F.E2 0F 46 04 06          IOOFF  (04)
Sun 09/07/2014 02:15:42 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 46 00    IOOFF  (00)
Sun 09/07/2014 02:15:42 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:15:42 AM : [D2D EVENT   ] Event [21 1F E2 5] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 02:15:42 AM : [  21 1F E2 5]       ST   0
Sun 09/07/2014 02:15:45 AM : [INST-TX-I1  ] 02 62 21 1F E2 0F 45 07
Sun 09/07/2014 02:15:45 AM : [INST-ACK    ] 02 62 21.1F.E2 0F 45 07 06          IOON   (07)
Sun 09/07/2014 02:15:45 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 45 80    IOON   (80)
Sun 09/07/2014 02:15:45 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:15:45 AM : [D2D EVENT   ] Event [21 1F E2 8] [ST] [255] uom=0 prec=-1
Sun 09/07/2014 02:15:45 AM : [  21 1F E2 8]       ST 255
Sun 09/07/2014 02:15:51 AM : CLI-HAMW: Connecting to api.aerisapi.com
Sun 09/07/2014 02:15:51 AM : CLI-HAMW: Successfully Processed HAMW Response
Sun 09/07/2014 02:15:52 AM : CLI-HAMW: Connecting to api.aerisapi.com
Sun 09/07/2014 02:15:52 AM : CLI-HAMW: Successfully Processed HAMW Response
Sun 09/07/2014 02:16:15 AM : [INST-TX-I1  ] 02 62 21 1F E2 0F 46 07
Sun 09/07/2014 02:16:15 AM : [INST-ACK    ] 02 62 21.1F.E2 0F 46 07 06          IOOFF  (07)
Sun 09/07/2014 02:16:15 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 46 00    IOOFF  (00)
Sun 09/07/2014 02:16:15 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:16:15 AM : [D2D EVENT   ] Event [21 1F E2 8] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 02:16:15 AM : [  21 1F E2 8]       ST   0
Sun 09/07/2014 02:16:21 AM : [INST-TX-I1  ] 02 62 21 1F E2 0F 45 06
Sun 09/07/2014 02:16:21 AM : [INST-ACK    ] 02 62 21.1F.E2 0F 45 06 06          IOON   (06)
Sun 09/07/2014 02:16:22 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 45 40    IOON   (40)
Sun 09/07/2014 02:16:22 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:16:22 AM : [D2D EVENT   ] Event [21 1F E2 7] [ST] [255] uom=0 prec=-1
Sun 09/07/2014 02:16:22 AM : [  21 1F E2 7]       ST 255
Sun 09/07/2014 02:16:30 AM : [INST-TX-I1  ] 02 62 21 1F E2 0F 46 06
Sun 09/07/2014 02:16:30 AM : [INST-ACK    ] 02 62 21.1F.E2 0F 46 06 06          IOOFF  (06)
Sun 09/07/2014 02:16:31 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 2B 46 00    IOOFF  (00)
Sun 09/07/2014 02:16:31 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sun 09/07/2014 02:16:31 AM : [D2D EVENT   ] Event [21 1F E2 7] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 02:16:31 AM : [  21 1F E2 7]       ST   0
Sun 09/07/2014 02:16:39 AM : [INST-TX-I1  ] 02 62 21 1F E2 0F 45 04
Sun 09/07/2014 02:16:39 AM : [INST-ACK    ] 02 62 21.1F.E2 0F 45 04 06          IOON   (04)
Sun 09/07/2014 02:16:40 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 45 10    IOON   (10)
Sun 09/07/2014 02:16:40 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:16:40 AM : [D2D EVENT   ] Event [21 1F E2 5] [ST] [255] uom=0 prec=-1
Sun 09/07/2014 02:16:40 AM : [  21 1F E2 5]       ST 255
Sun 09/07/2014 02:17:27 AM : [INST-TX-I1  ] 02 62 21 1F E2 0F 46 04
Sun 09/07/2014 02:17:27 AM : [INST-ACK    ] 02 62 21.1F.E2 0F 46 04 06          IOOFF  (04)
Sun 09/07/2014 02:17:27 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 46 00    IOOFF  (00)
Sun 09/07/2014 02:17:27 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:17:27 AM : [D2D EVENT   ] Event [21 1F E2 5] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 02:17:27 AM : [  21 1F E2 5]       ST   0
Sun 09/07/2014 02:17:36 AM : [INST-TX-I1  ] 02 62 21 1F E2 0F 45 05
Sun 09/07/2014 02:17:36 AM : [INST-ACK    ] 02 62 21.1F.E2 0F 45 05 06          IOON   (05)
Sun 09/07/2014 02:17:37 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 45 20    IOON   (20)
Sun 09/07/2014 02:17:37 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:17:37 AM : [D2D EVENT   ] Event [21 1F E2 6] [ST] [255] uom=0 prec=-1
Sun 09/07/2014 02:17:37 AM : [  21 1F E2 6]       ST 255
Sun 09/07/2014 02:17:38 AM : [INST-TX-I1  ] 02 62 21 1F E2 0F 46 05
Sun 09/07/2014 02:17:38 AM : [INST-ACK    ] 02 62 21.1F.E2 0F 46 05 06          IOOFF  (05)
Sun 09/07/2014 02:17:38 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 46 00    IOOFF  (00)
Sun 09/07/2014 02:17:38 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:17:38 AM : [D2D EVENT   ] Event [21 1F E2 6] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 02:17:38 AM : [  21 1F E2 6]       ST   0
Sun 09/07/2014 02:17:38 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 23 46 00    IOOFF  (00)
Sun 09/07/2014 02:17:38 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sun 09/07/2014 02:18:01 AM : [INST-SRX    ] 02 50 21.1F.E2 00.00.09 C7 11 00    LTONRR (00)
Sun 09/07/2014 02:18:01 AM : [Std-Group   ] 21.1F.E2-->Group=9, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:18:01 AM : [D2D EVENT   ] Event [21 1F E2 9] [DON] [0] uom=0 prec=-1
Sun 09/07/2014 02:18:01 AM : [  21 1F E2 9]      DON   0
Sun 09/07/2014 02:18:01 AM : [D2D EVENT   ] Event [21 1F E2 9] [ST] [255] uom=0 prec=-1
Sun 09/07/2014 02:18:01 AM : [  21 1F E2 9]       ST 255
Sun 09/07/2014 02:18:01 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 41 11 09    LTONRR (09)
Sun 09/07/2014 02:18:01 AM : [Std-Cleanup ] 21.1F.E2-->ISY/PLM Group=9, Max Hops=1, Hops Left=0
Sun 09/07/2014 02:18:01 AM : [INST-DUP    ] Previous message ignored.
Sun 09/07/2014 02:18:04 AM : [INST-SRX    ] 02 50 21.1F.E2 00.00.09 C7 13 00    LTOFFRR(00)
Sun 09/07/2014 02:18:04 AM : [Std-Group   ] 21.1F.E2-->Group=9, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:18:04 AM : [D2D EVENT   ] Event [21 1F E2 9] [DOF] [0] uom=0 prec=-1
Sun 09/07/2014 02:18:04 AM : [  21 1F E2 9]      DOF   0
Sun 09/07/2014 02:18:04 AM : [D2D EVENT   ] Event [21 1F E2 9] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 02:18:04 AM : [  21 1F E2 9]       ST   0
Sun 09/07/2014 02:18:05 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 41 13 09    LTOFFRR(09)
Sun 09/07/2014 02:18:05 AM : [Std-Cleanup ] 21.1F.E2-->ISY/PLM Group=9, Max Hops=1, Hops Left=0
Sun 09/07/2014 02:18:05 AM : [INST-DUP    ] Previous message ignored.
Sun 09/07/2014 02:18:11 AM : [INST-SRX    ] 02 50 21.1F.E2 00.00.0A C7 11 00    LTONRR (00)
Sun 09/07/2014 02:18:11 AM : [Std-Group   ] 21.1F.E2-->Group=10, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:18:11 AM : [D2D EVENT   ] Event [21 1F E2 A] [DON] [0] uom=0 prec=-1
Sun 09/07/2014 02:18:11 AM : [  21 1F E2 A]      DON   0
Sun 09/07/2014 02:18:11 AM : [D2D EVENT   ] Event [21 1F E2 A] [ST] [255] uom=0 prec=-1
Sun 09/07/2014 02:18:11 AM : [  21 1F E2 A]       ST 255
Sun 09/07/2014 02:18:11 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 41 11 0A    LTONRR (0A)
Sun 09/07/2014 02:18:11 AM : [Std-Cleanup ] 21.1F.E2-->ISY/PLM Group=10, Max Hops=1, Hops Left=0
Sun 09/07/2014 02:18:11 AM : [INST-DUP    ] Previous message ignored.
Sun 09/07/2014 02:18:13 AM : [INST-SRX    ] 02 50 21.1F.E2 00.00.0A C7 13 00    LTOFFRR(00)
Sun 09/07/2014 02:18:13 AM : [Std-Group   ] 21.1F.E2-->Group=10, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:18:13 AM : [D2D EVENT   ] Event [21 1F E2 A] [DOF] [0] uom=0 prec=-1
Sun 09/07/2014 02:18:13 AM : [  21 1F E2 A]      DOF   0
Sun 09/07/2014 02:18:13 AM : [D2D EVENT   ] Event [21 1F E2 A] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 02:18:13 AM : [  21 1F E2 A]       ST   0
Sun 09/07/2014 02:18:13 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 41 13 0A    LTOFFRR(0A)
Sun 09/07/2014 02:18:13 AM : [Std-Cleanup ] 21.1F.E2-->ISY/PLM Group=10, Max Hops=1, Hops Left=0
Sun 09/07/2014 02:18:13 AM : [INST-DUP    ] Previous message ignored.
Sun 09/07/2014 02:18:25 AM : [INST-SRX    ] 02 50 21.1F.E2 00.00.0B C7 11 00    LTONRR (00)
Sun 09/07/2014 02:18:25 AM : [Std-Group   ] 21.1F.E2-->Group=11, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:18:25 AM : [D2D EVENT   ] Event [21 1F E2 B] [DON] [0] uom=0 prec=-1
Sun 09/07/2014 02:18:25 AM : [  21 1F E2 B]      DON   0
Sun 09/07/2014 02:18:25 AM : [D2D EVENT   ] Event [21 1F E2 B] [ST] [255] uom=0 prec=-1
Sun 09/07/2014 02:18:25 AM : [  21 1F E2 B]       ST 255
Sun 09/07/2014 02:18:26 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 41 11 0B    LTONRR (0B)
Sun 09/07/2014 02:18:26 AM : [Std-Cleanup ] 21.1F.E2-->ISY/PLM Group=11, Max Hops=1, Hops Left=0
Sun 09/07/2014 02:18:26 AM : [INST-DUP    ] Previous message ignored.
Sun 09/07/2014 02:18:27 AM : [INST-SRX    ] 02 50 21.1F.E2 00.00.0B C7 13 00    LTOFFRR(00)
Sun 09/07/2014 02:18:27 AM : [Std-Group   ] 21.1F.E2-->Group=11, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:18:27 AM : [D2D EVENT   ] Event [21 1F E2 B] [DOF] [0] uom=0 prec=-1
Sun 09/07/2014 02:18:27 AM : [  21 1F E2 B]      DOF   0
Sun 09/07/2014 02:18:27 AM : [D2D EVENT   ] Event [21 1F E2 B] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 02:18:27 AM : [  21 1F E2 B]       ST   0
Sun 09/07/2014 02:18:27 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 41 13 0B    LTOFFRR(0B)
Sun 09/07/2014 02:18:27 AM : [Std-Cleanup ] 21.1F.E2-->ISY/PLM Group=11, Max Hops=1, Hops Left=0
Sun 09/07/2014 02:18:27 AM : [INST-DUP    ] Previous message ignored.
Sun 09/07/2014 02:18:47 AM : [INST-SRX    ] 02 50 21.1F.E2 00.00.0C C7 11 00    LTONRR (00)
Sun 09/07/2014 02:18:47 AM : [Std-Group   ] 21.1F.E2-->Group=12, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:18:48 AM : [D2D EVENT   ] Event [21 1F E2 C] [DON] [0] uom=0 prec=-1
Sun 09/07/2014 02:18:48 AM : [  21 1F E2 C]      DON   0
Sun 09/07/2014 02:18:48 AM : [D2D EVENT   ] Event [21 1F E2 C] [ST] [255] uom=0 prec=-1
Sun 09/07/2014 02:18:48 AM : [  21 1F E2 C]       ST 255
Sun 09/07/2014 02:18:48 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 41 11 0C    LTONRR (0C)
Sun 09/07/2014 02:18:48 AM : [Std-Cleanup ] 21.1F.E2-->ISY/PLM Group=12, Max Hops=1, Hops Left=0
Sun 09/07/2014 02:18:48 AM : [INST-DUP    ] Previous message ignored.
Sun 09/07/2014 02:18:49 AM : [INST-SRX    ] 02 50 21.1F.E2 00.00.0C C7 13 00    LTOFFRR(00)
Sun 09/07/2014 02:18:49 AM : [Std-Group   ] 21.1F.E2-->Group=12, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:18:49 AM : [D2D EVENT   ] Event [21 1F E2 C] [DOF] [0] uom=0 prec=-1
Sun 09/07/2014 02:18:49 AM : [  21 1F E2 C]      DOF   0
Sun 09/07/2014 02:18:49 AM : [D2D EVENT   ] Event [21 1F E2 C] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 02:18:49 AM : [  21 1F E2 C]       ST   0
Sun 09/07/2014 02:18:49 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 41 13 0C    LTOFFRR(0C)
Sun 09/07/2014 02:18:49 AM : [Std-Cleanup ] 21.1F.E2-->ISY/PLM Group=12, Max Hops=1, Hops Left=0
Sun 09/07/2014 02:18:49 AM : [INST-DUP    ] Previous message ignored.
Log (Query):
Sun 09/07/2014 02:24:52 AM : [All         ] Writing 1 bytes to devices
Sun 09/07/2014 02:24:52 AM : [INST-TX-I1  ] 02 62 21 1F E2 0F 0D 00
Sun 09/07/2014 02:24:52 AM : [INST-ACK    ] 02 62 21.1F.E2 0F 0D 00 06                 (00)
Sun 09/07/2014 02:24:52 AM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 0D 02           (02)
Sun 09/07/2014 02:24:52 AM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 02:24:52 AM : [21 1F E2 0  ] Calibrating engine version
The new EZIO8SA PLM is an I2CS device.   The Advanced | PLM Communication allows the retry count for Input state change messages to be controlled because the PLM is I2CS.  Before I2CS the Input state change messages would have a retry count of 3.  With I2CS the retry count can be adjusted.
I set the retry count to 2, then set the retry count to 3.
Sun 09/07/2014 03:50:10 PM : [17 6F 77 9  ] Link    0 : 1FF8 [E20922800B021F09] Saving  [..........02....]
Sun 09/07/2014 03:50:10 PM : [All         ] Writing 1 bytes to devices
Sun 09/07/2014 03:50:11 PM : [17 6F 77 1  ] Link    0 : 1FF8 [E20922800B021F09] Writing [..........02....]
Sun 09/07/2014 03:50:11 PM : [iNST-TX-I2CS] 02 62 17 6F 77 1F 2F 00 00 02 1F FF 08 E2 09 22 80 0B 02 1F 09 E7
Sun 09/07/2014 03:50:11 PM : [iNST-ACK    ] 02 62 17.6F.77 1F 2F 00 00 02 1F FF 08 E2 09 22 80 0B 02 1F 09 E7 06        (00)
Sun 09/07/2014 03:50:11 PM : [iNST-SRX    ] 02 50 17.6F.77 22.80.0B 2B 2F 00           (00)
Sun 09/07/2014 03:50:11 PM : [std-Direct Ack] 17.6F.77-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sun 09/07/2014 03:51:50 PM : [17 6F 77 9  ] Link    0 : 1FF8 [E20922800B031F09] Saving  [..........03....]
Sun 09/07/2014 03:51:51 PM : [All         ] Writing 1 bytes to devices
Sun 09/07/2014 03:51:51 PM : [17 6F 77 1  ] Link    0 : 1FF8 [E20922800B031F09] Writing [..........03....]
Sun 09/07/2014 03:51:51 PM : [iNST-TX-I2CS] 02 62 17 6F 77 1F 2F 00 00 02 1F FF 08 E2 09 22 80 0B 03 1F 09 E6
Sun 09/07/2014 03:51:51 PM : [iNST-ACK    ] 02 62 17.6F.77 1F 2F 00 00 02 1F FF 08 E2 09 22 80 0B 03 1F 09 E6 06        (00)
Sun 09/07/2014 03:51:51 PM : [iNST-SRX    ] 02 50 17.6F.77 22.80.0B 2B 2F 00           (00)
Sun 09/07/2014 03:51:51 PM : [std-Direct Ack] 17.6F.77-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Edited by LeeG
I installed the new unit into its box and hooked everything to it. Here are the results. Can you see any difference in reliability in terms of comm between the first post results and the ones below? All the devices turned on and off physically when I did the tests... so not only did the commands get there but they actually turned on the items connected.
Query:
Sun 09/07/2014 12:29:21 PM : [INST-TX-I1  ] 02 62 21 1F E2 0F 4F 02
Sun 09/07/2014 12:29:21 PM : [INST-ACK    ] 02 62 21.1F.E2 0F 4F 02 06          IOCTL  (QUERY)
Sun 09/07/2014 12:29:22 PM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 4F 00    IOCTL  (00)
Sun 09/07/2014 12:29:22 PM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 12:29:22 PM : [D2D EVENT   ] Event [21 1F E2 1] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 12:29:22 PM : [  21 1F E2 1]       ST   0
Sun 09/07/2014 12:29:22 PM : [INST-TX-I1  ] 02 62 21 1F E2 0F 49 00
Sun 09/07/2014 12:29:22 PM : [INST-ACK    ] 02 62 21.1F.E2 0F 49 00 06          RINPUT (00)
Sun 09/07/2014 12:29:22 PM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 49 31    RINPUT (31)
Sun 09/07/2014 12:29:22 PM : [D2D EVENT   ] Event [21 1F E2 9] [ST] [255] uom=0 prec=-1
Sun 09/07/2014 12:29:22 PM : [  21 1F E2 9]       ST 255
Sun 09/07/2014 12:29:46 PM : [VAR  2    8 ]       253
Relay Test:
Sun 09/07/2014 01:19:36 PM : [INST-TX-I1  ] 02 62 21 1F E2 0F 45 00
Sun 09/07/2014 01:19:36 PM : [INST-ACK    ] 02 62 21.1F.E2 0F 45 00 06          IOON   (00)
Sun 09/07/2014 01:19:36 PM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 45 01    IOON   (01)
Sun 09/07/2014 01:19:36 PM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 01:19:36 PM : [D2D EVENT   ] Event [21 1F E2 1] [ST] [255] uom=0 prec=-1
Sun 09/07/2014 01:19:36 PM : [  21 1F E2 1]       ST 255
Sun 09/07/2014 01:19:41 PM : [INST-TX-I1  ] 02 62 21 1F E2 0F 46 00
Sun 09/07/2014 01:19:41 PM : [INST-ACK    ] 02 62 21.1F.E2 0F 46 00 06          IOOFF  (00)
Sun 09/07/2014 01:19:42 PM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 46 00    IOOFF  (00)
Sun 09/07/2014 01:19:42 PM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 01:19:42 PM : [D2D EVENT   ] Event [21 1F E2 1] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 01:19:42 PM : [  21 1F E2 1]       ST   0
Sun 09/07/2014 01:19:45 PM : [INST-TX-I1  ] 02 62 21 1F E2 0F 45 01
Sun 09/07/2014 01:19:45 PM : [INST-ACK    ] 02 62 21.1F.E2 0F 45 01 06          IOON   (01)
Sun 09/07/2014 01:19:46 PM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 45 02    IOON   (02)
Sun 09/07/2014 01:19:46 PM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 01:19:46 PM : [D2D EVENT   ] Event [21 1F E2 2] [ST] [255] uom=0 prec=-1
Sun 09/07/2014 01:19:46 PM : [  21 1F E2 2]       ST 255
Sun 09/07/2014 01:19:50 PM : [INST-TX-I1  ] 02 62 21 1F E2 0F 46 01
Sun 09/07/2014 01:19:50 PM : [INST-ACK    ] 02 62 21.1F.E2 0F 46 01 06          IOOFF  (01)
Sun 09/07/2014 01:19:50 PM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 46 00    IOOFF  (00)
Sun 09/07/2014 01:19:50 PM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 01:19:50 PM : [D2D EVENT   ] Event [21 1F E2 2] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 01:19:50 PM : [  21 1F E2 2]       ST   0
Sun 09/07/2014 01:19:53 PM : [INST-TX-I1  ] 02 62 21 1F E2 0F 45 02
Sun 09/07/2014 01:19:53 PM : [INST-ACK    ] 02 62 21.1F.E2 0F 45 02 06          IOON   (02)
Sun 09/07/2014 01:19:54 PM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 23 45 04    IOON   (04)
Sun 09/07/2014 01:19:54 PM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sun 09/07/2014 01:19:54 PM : [D2D EVENT   ] Event [21 1F E2 3] [ST] [255] uom=0 prec=-1
Sun 09/07/2014 01:19:54 PM : [  21 1F E2 3]       ST 255
Sun 09/07/2014 01:19:54 PM : [D2D-CMP 007A] STS [21 1F E2 3] ST op=1 Event(val=255 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> true
Sun 09/07/2014 01:19:54 PM : [D2D-CMP 007A] STS [21 1F E2 3] ST op=1 Event(val=255 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> false
Sun 09/07/2014 01:19:56 PM : [VAR  2    8 ]       295
Sun 09/07/2014 01:19:57 PM : [INST-TX-I1  ] 02 62 21 1F E2 0F 46 02
Sun 09/07/2014 01:19:57 PM : [INST-ACK    ] 02 62 21.1F.E2 0F 46 02 06          IOOFF  (02)
Sun 09/07/2014 01:19:57 PM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 46 00    IOOFF  (00)
Sun 09/07/2014 01:19:57 PM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 01:19:57 PM : [D2D EVENT   ] Event [21 1F E2 3] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 01:19:57 PM : [  21 1F E2 3]       ST   0
Sun 09/07/2014 01:19:57 PM : [D2D-CMP 007A] STS [21 1F E2 3] ST op=1 Event(val=0 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> false
Sun 09/07/2014 01:19:57 PM : [D2D-CMP 007A] STS [21 1F E2 3] ST op=1 Event(val=0 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true
Sun 09/07/2014 01:20:01 PM : [INST-TX-I1  ] 02 62 21 1F E2 0F 45 03
Sun 09/07/2014 01:20:01 PM : [INST-ACK    ] 02 62 21.1F.E2 0F 45 03 06          IOON   (03)
Sun 09/07/2014 01:20:01 PM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 23 45 08    IOON   (08)
Sun 09/07/2014 01:20:01 PM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sun 09/07/2014 01:20:01 PM : [D2D EVENT   ] Event [21 1F E2 4] [ST] [255] uom=0 prec=-1
Sun 09/07/2014 01:20:01 PM : [  21 1F E2 4]       ST 255
Sun 09/07/2014 01:20:02 PM : [INST-SRX    ] 02 50 21.1F.E2 00.00.0A C7 13 00    LTOFFRR(00)
Sun 09/07/2014 01:20:02 PM : [Std-Group   ] 21.1F.E2-->Group=10, Max Hops=3, Hops Left=1
Sun 09/07/2014 01:20:02 PM : [D2D EVENT   ] Event [21 1F E2 A] [DOF] [0] uom=0 prec=-1
Sun 09/07/2014 01:20:02 PM : [  21 1F E2 A]      DOF   0
Sun 09/07/2014 01:20:02 PM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 41 13 0A    LTOFFRR(0A)
Sun 09/07/2014 01:20:02 PM : [Std-Cleanup ] 21.1F.E2-->ISY/PLM Group=10, Max Hops=1, Hops Left=0
Sun 09/07/2014 01:20:02 PM : [INST-DUP    ] Previous message ignored.
Sun 09/07/2014 01:20:05 PM : [INST-TX-I1  ] 02 62 21 1F E2 0F 46 03
Sun 09/07/2014 01:20:05 PM : [INST-ACK    ] 02 62 21.1F.E2 0F 46 03 06          IOOFF  (03)
Sun 09/07/2014 01:20:05 PM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 46 00    IOOFF  (00)
Sun 09/07/2014 01:20:05 PM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 01:20:05 PM : [D2D EVENT   ] Event [21 1F E2 4] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 01:20:05 PM : [  21 1F E2 4]       ST   0
Sun 09/07/2014 01:20:07 PM : [INST-TX-I1  ] 02 62 21 1F E2 0F 45 04
Sun 09/07/2014 01:20:07 PM : [INST-ACK    ] 02 62 21.1F.E2 0F 45 04 06          IOON   (04)
Sun 09/07/2014 01:20:08 PM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 45 10    IOON   (10)
Sun 09/07/2014 01:20:08 PM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 01:20:08 PM : [D2D EVENT   ] Event [21 1F E2 5] [ST] [255] uom=0 prec=-1
Sun 09/07/2014 01:20:08 PM : [  21 1F E2 5]       ST 255
Sun 09/07/2014 01:20:08 PM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 23 45 10    IOON   (10)
Sun 09/07/2014 01:20:08 PM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sun 09/07/2014 01:20:11 PM : [INST-TX-I1  ] 02 62 21 1F E2 0F 46 04
Sun 09/07/2014 01:20:11 PM : [INST-ACK    ] 02 62 21.1F.E2 0F 46 04 06          IOOFF  (04)
Sun 09/07/2014 01:20:11 PM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 46 00    IOOFF  (00)
Sun 09/07/2014 01:20:11 PM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 01:20:11 PM : [D2D EVENT   ] Event [21 1F E2 5] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 01:20:11 PM : [  21 1F E2 5]       ST   0
Sun 09/07/2014 01:20:13 PM : [INST-TX-I1  ] 02 62 21 1F E2 0F 45 05
Sun 09/07/2014 01:20:13 PM : [INST-ACK    ] 02 62 21.1F.E2 0F 45 05 06          IOON   (05)
Sun 09/07/2014 01:20:14 PM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 45 20    IOON   (20)
Sun 09/07/2014 01:20:14 PM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 01:20:14 PM : [D2D EVENT   ] Event [21 1F E2 6] [ST] [255] uom=0 prec=-1
Sun 09/07/2014 01:20:14 PM : [  21 1F E2 6]       ST 255
Sun 09/07/2014 01:20:16 PM : [INST-TX-I1  ] 02 62 21 1F E2 0F 46 05
Sun 09/07/2014 01:20:16 PM : [INST-ACK    ] 02 62 21.1F.E2 0F 46 05 06          IOOFF  (05)
Sun 09/07/2014 01:20:17 PM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 23 46 00    IOOFF  (00)
Sun 09/07/2014 01:20:17 PM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sun 09/07/2014 01:20:17 PM : [D2D EVENT   ] Event [21 1F E2 6] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 01:20:17 PM : [  21 1F E2 6]       ST   0
Sun 09/07/2014 01:20:46 PM : CLI-HAMW: Connecting to api.aerisapi.com
Sun 09/07/2014 01:20:48 PM : CLI-HAMW: Successfully Processed HAMW Response
Sun 09/07/2014 01:20:48 PM : CLI-HAMW: Connecting to api.aerisapi.com
Sun 09/07/2014 01:20:49 PM : CLI-HAMW: Successfully Processed HAMW Response
Relay Test (Door Closed)
Sun 09/07/2014 01:24:57 PM : [INST-TX-I1  ] 02 62 21 1F E2 0F 45 00
Sun 09/07/2014 01:24:57 PM : [INST-ACK    ] 02 62 21.1F.E2 0F 45 00 06          IOON   (00)
Sun 09/07/2014 01:24:58 PM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 45 01    IOON   (01)
Sun 09/07/2014 01:24:58 PM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 01:24:58 PM : [D2D EVENT   ] Event [21 1F E2 1] [ST] [255] uom=0 prec=-1
Sun 09/07/2014 01:24:58 PM : [  21 1F E2 1]       ST 255
Sun 09/07/2014 01:25:03 PM : [INST-TX-I1  ] 02 62 21 1F E2 0F 46 00
Sun 09/07/2014 01:25:03 PM : [INST-ACK    ] 02 62 21.1F.E2 0F 46 00 06          IOOFF  (00)
Sun 09/07/2014 01:25:04 PM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 46 00    IOOFF  (00)
Sun 09/07/2014 01:25:04 PM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 01:25:04 PM : [D2D EVENT   ] Event [21 1F E2 1] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 01:25:04 PM : [  21 1F E2 1]       ST   0
Sun 09/07/2014 01:25:04 PM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 23 46 00    IOOFF  (00)
Sun 09/07/2014 01:25:04 PM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sun 09/07/2014 01:25:08 PM : [INST-TX-I1  ] 02 62 21 1F E2 0F 45 01
Sun 09/07/2014 01:25:08 PM : [INST-ACK    ] 02 62 21.1F.E2 0F 45 01 06          IOON   (01)
Sun 09/07/2014 01:25:08 PM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 45 02    IOON   (02)
Sun 09/07/2014 01:25:08 PM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 01:25:08 PM : [D2D EVENT   ] Event [21 1F E2 2] [ST] [255] uom=0 prec=-1
Sun 09/07/2014 01:25:08 PM : [  21 1F E2 2]       ST 255
Sun 09/07/2014 01:25:12 PM : [INST-TX-I1  ] 02 62 21 1F E2 0F 46 01
Sun 09/07/2014 01:25:12 PM : [INST-ACK    ] 02 62 21.1F.E2 0F 46 01 06          IOOFF  (01)
Sun 09/07/2014 01:25:12 PM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 46 00    IOOFF  (00)
Sun 09/07/2014 01:25:12 PM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 01:25:12 PM : [D2D EVENT   ] Event [21 1F E2 2] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 01:25:12 PM : [  21 1F E2 2]       ST   0
Sun 09/07/2014 01:25:14 PM : [INST-TX-I1  ] 02 62 21 1F E2 0F 45 02
Sun 09/07/2014 01:25:14 PM : [INST-ACK    ] 02 62 21.1F.E2 0F 45 02 06          IOON   (02)
Sun 09/07/2014 01:25:14 PM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 45 04    IOON   (04)
Sun 09/07/2014 01:25:14 PM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 01:25:14 PM : [D2D EVENT   ] Event [21 1F E2 3] [ST] [255] uom=0 prec=-1
Sun 09/07/2014 01:25:14 PM : [  21 1F E2 3]       ST 255
Sun 09/07/2014 01:25:14 PM : [D2D-CMP 007A] STS [21 1F E2 3] ST op=1 Event(val=255 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> true
Sun 09/07/2014 01:25:14 PM : [D2D-CMP 007A] STS [21 1F E2 3] ST op=1 Event(val=255 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> false
Sun 09/07/2014 01:25:17 PM : [INST-TX-I1  ] 02 62 21 1F E2 0F 46 02
Sun 09/07/2014 01:25:17 PM : [INST-ACK    ] 02 62 21.1F.E2 0F 46 02 06          IOOFF  (02)
Sun 09/07/2014 01:25:17 PM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 23 46 00    IOOFF  (00)
Sun 09/07/2014 01:25:17 PM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sun 09/07/2014 01:25:17 PM : [D2D EVENT   ] Event [21 1F E2 3] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 01:25:17 PM : [  21 1F E2 3]       ST   0
Sun 09/07/2014 01:25:17 PM : [D2D-CMP 007A] STS [21 1F E2 3] ST op=1 Event(val=0 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> false
Sun 09/07/2014 01:25:17 PM : [D2D-CMP 007A] STS [21 1F E2 3] ST op=1 Event(val=0 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true
Sun 09/07/2014 01:25:19 PM : [INST-TX-I1  ] 02 62 21 1F E2 0F 45 03
Sun 09/07/2014 01:25:19 PM : [INST-ACK    ] 02 62 21.1F.E2 0F 45 03 06          IOON   (03)
Sun 09/07/2014 01:25:20 PM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 45 08    IOON   (08)
Sun 09/07/2014 01:25:20 PM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 01:25:20 PM : [D2D EVENT   ] Event [21 1F E2 4] [ST] [255] uom=0 prec=-1
Sun 09/07/2014 01:25:20 PM : [  21 1F E2 4]       ST 255
Sun 09/07/2014 01:25:22 PM : [INST-SRX    ] 02 50 21.1F.E2 00.00.0A C7 13 00    LTOFFRR(00)
Sun 09/07/2014 01:25:22 PM : [Std-Group   ] 21.1F.E2-->Group=10, Max Hops=3, Hops Left=1
Sun 09/07/2014 01:25:22 PM : [D2D EVENT   ] Event [21 1F E2 A] [DOF] [0] uom=0 prec=-1
Sun 09/07/2014 01:25:22 PM : [  21 1F E2 A]      DOF   0
Sun 09/07/2014 01:25:22 PM : [VAR  2    8 ]       298
Sun 09/07/2014 01:25:22 PM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 41 13 0A    LTOFFRR(0A)
Sun 09/07/2014 01:25:22 PM : [Std-Cleanup ] 21.1F.E2-->ISY/PLM Group=10, Max Hops=1, Hops Left=0
Sun 09/07/2014 01:25:22 PM : [INST-DUP    ] Previous message ignored.
Sun 09/07/2014 01:25:23 PM : [INST-TX-I1  ] 02 62 21 1F E2 0F 46 03
Sun 09/07/2014 01:25:23 PM : [INST-ACK    ] 02 62 21.1F.E2 0F 46 03 06          IOOFF  (03)
Sun 09/07/2014 01:25:23 PM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 46 00    IOOFF  (00)
Sun 09/07/2014 01:25:23 PM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 01:25:23 PM : [D2D EVENT   ] Event [21 1F E2 4] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 01:25:23 PM : [  21 1F E2 4]       ST   0
Sun 09/07/2014 01:25:27 PM : [INST-TX-I1  ] 02 62 21 1F E2 0F 45 04
Sun 09/07/2014 01:25:27 PM : [INST-ACK    ] 02 62 21.1F.E2 0F 45 04 06          IOON   (04)
Sun 09/07/2014 01:25:27 PM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 45 10    IOON   (10)
Sun 09/07/2014 01:25:27 PM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 01:25:27 PM : [D2D EVENT   ] Event [21 1F E2 5] [ST] [255] uom=0 prec=-1
Sun 09/07/2014 01:25:27 PM : [  21 1F E2 5]       ST 255
Sun 09/07/2014 01:25:29 PM : [INST-TX-I1  ] 02 62 21 1F E2 0F 46 04
Sun 09/07/2014 01:25:29 PM : [INST-ACK    ] 02 62 21.1F.E2 0F 46 04 06          IOOFF  (04)
Sun 09/07/2014 01:25:29 PM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 46 00    IOOFF  (00)
Sun 09/07/2014 01:25:29 PM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 01:25:29 PM : [D2D EVENT   ] Event [21 1F E2 5] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 01:25:29 PM : [  21 1F E2 5]       ST   0
Sun 09/07/2014 01:25:31 PM : [INST-TX-I1  ] 02 62 21 1F E2 0F 45 05
Sun 09/07/2014 01:25:31 PM : [INST-ACK    ] 02 62 21.1F.E2 0F 45 05 06          IOON   (05)
Sun 09/07/2014 01:25:31 PM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 45 20    IOON   (20)
Sun 09/07/2014 01:25:31 PM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 01:25:31 PM : [D2D EVENT   ] Event [21 1F E2 6] [ST] [255] uom=0 prec=-1
Sun 09/07/2014 01:25:31 PM : [  21 1F E2 6]       ST 255
Sun 09/07/2014 01:25:32 PM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 23 45 20    IOON   (20)
Sun 09/07/2014 01:25:32 PM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sun 09/07/2014 01:25:34 PM : [INST-TX-I1  ] 02 62 21 1F E2 0F 46 05
Sun 09/07/2014 01:25:34 PM : [INST-ACK    ] 02 62 21.1F.E2 0F 46 05 06          IOOFF  (05)
Sun 09/07/2014 01:25:34 PM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 27 46 00    IOOFF  (00)
Sun 09/07/2014 01:25:34 PM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 01:25:34 PM : [D2D EVENT   ] Event [21 1F E2 6] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 01:25:34 PM : [  21 1F E2 6]       ST   0
Sun 09/07/2014 01:25:34 PM : [INST-SRX    ] 02 50 21.1F.E2 2F.B8.09 23 46 00    IOOFF  (00)
Sun 09/07/2014 01:25:34 PM : [Std-Direct Ack] 21.1F.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sun 09/07/2014 01:25:46 PM : CLI-HAMW: Connecting to api.aerisapi.com
Sun 09/07/2014 01:25:46 PM : CLI-HAMW: Successfully Processed HAMW Response
Sun 09/07/2014 01:25:47 PM : CLI-HAMW: Successfully Processed HAMW Response
Sun 09/07/2014 01:25:47 PM : CLI-HAMW: Connecting to api.aerisapi.com
Test of the other 2 devices out at the pool equipment but opposite phase:
Sun 09/07/2014 01:27:22 PM : [VAR  2    8 ]       300
Sun 09/07/2014 01:27:33 PM : [INST-TX-I1  ] 02 62 2A A5 5B 0F 11 FF
Sun 09/07/2014 01:27:33 PM : [INST-ACK    ] 02 62 2A.A5.5B 0F 11 FF 06          LTONRR (FF)
Sun 09/07/2014 01:27:33 PM : [INST-SRX    ] 02 50 2A.A5.5B 2F.B8.09 27 11 FF    LTONRR (FF)
Sun 09/07/2014 01:27:33 PM : [Std-Direct Ack] 2A.A5.5B-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 01:27:33 PM : [D2D EVENT   ] Event [2A A5 5B 1] [ST] [255] uom=0 prec=-1
Sun 09/07/2014 01:27:33 PM : [  2A A5 5B 1]       ST 255
Sun 09/07/2014 01:27:35 PM : [INST-TX-I1  ] 02 62 2A A5 5B 0F 13 00
Sun 09/07/2014 01:27:35 PM : [INST-ACK    ] 02 62 2A.A5.5B 0F 13 00 06          LTOFFRR(00)
Sun 09/07/2014 01:27:35 PM : [INST-SRX    ] 02 50 2A.A5.5B 2F.B8.09 27 13 00    LTOFFRR(00)
Sun 09/07/2014 01:27:35 PM : [Std-Direct Ack] 2A.A5.5B-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 09/07/2014 01:27:35 PM : [D2D EVENT   ] Event [2A A5 5B 1] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 01:27:35 PM : [  2A A5 5B 1]       ST   0
Sun 09/07/2014 01:27:38 PM : [INST-TX-I1  ] 02 62 28 33 FE 0F 11 FF
Sun 09/07/2014 01:27:38 PM : [INST-ACK    ] 02 62 28.33.FE 0F 11 FF 06          LTONRR (FF)
Sun 09/07/2014 01:27:39 PM : [INST-SRX    ] 02 50 28.33.FE 2F.B8.09 2B 11 FF    LTONRR (FF)
Sun 09/07/2014 01:27:39 PM : [Std-Direct Ack] 28.33.FE-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sun 09/07/2014 01:27:39 PM : [D2D EVENT   ] Event [28 33 FE 1] [ST] [255] uom=0 prec=-1
Sun 09/07/2014 01:27:39 PM : [  28 33 FE 1]       ST 255
Sun 09/07/2014 01:27:39 PM : [INST-SRX    ] 02 50 28.33.FE 2F.B8.09 23 11 FF    LTONRR (FF)
Sun 09/07/2014 01:27:39 PM : [Std-Direct Ack] 28.33.FE-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sun 09/07/2014 01:27:41 PM : [INST-TX-I1  ] 02 62 28 33 FE 0F 13 00
Sun 09/07/2014 01:27:41 PM : [INST-ACK    ] 02 62 28.33.FE 0F 13 00 06          LTOFFRR(00)
Sun 09/07/2014 01:27:41 PM : [INST-SRX    ] 02 50 28.33.FE 2F.B8.09 2B 13 00    LTOFFRR(00)
Sun 09/07/2014 01:27:41 PM : [Std-Direct Ack] 28.33.FE-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sun 09/07/2014 01:27:41 PM : [D2D EVENT   ] Event [28 33 FE 1] [ST] [0] uom=0 prec=-1
Sun 09/07/2014 01:27:41 PM : [  28 33 FE 1]       ST   0
Sun 09/07/2014 01:27:41 PM : [INST-SRX    ] 02 50 28.33.FE 2F.B8.09 23 13 00    LTOFFRR(00)
Sun 09/07/2014 01:27:41 PM : [Std-Direct Ack] 28.33.FE-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
The only difference I see is Relay 4 turning On is followed by Input 2 turning Off.
The previous device trace shows Relay 4 turning On followed by Input 4 turning Off.
Yes I moved it to input 2
Edited by ravedog
So some observations. It seems that all outputs are responding well.
Input 1 works because the source is triggered by the heater power itself going hot by turning on the pool pump (the pool pump provides power to the heater for safety so it can't be activated without water flow).
However. Even though input 2 works when it gets dc voltage applied to it, it's not working in how I'm doing it.
Something you said earlier about having an output triggering an input. While not directly triggering it it kind of is. Output 3 triggers the heater. The heater turns on it's led. The led power gets sent back and converted to DC and into input 2. It's fairly instantaneous. Problem is that even though there's voltage on input 2, it's not telling the isy. Ever. Only a query forces the isy to update. Ironically turning off relay 3 does trigger input 2 to send an off. Off always works. On never works.
While I think it should work maybe there's too much traffic and it tries and sends but it gets lost.
I tried changing input 2s retries to 2 then 3 and no change. Still not getting thru.
To compensate I wrote a program that merely listens to any output relay state change (on or off) THEN waits 2 seconds and queries output 1 (the whole device). Input 2 then reports it's true state and my program that need that input state work.
I really would like to fix the input or get an official statement that the input will not report it's change while other comms are going on. This workaround defeats the purpose of having dynamic self reporting inputs.
I hate the idea of forcing queries. It works but oh yay here comes a lot of traffic. It's not like these relays are being used constantly. Only when someone wants to use the spa.
What do you think lee?
Edited by ravedog
In general Insteon allows only one Scene to communicate.  Insteon does not permit multiple Scene traffic to interleave on the Insteon network nor does a device hold its traffic for what could be several seconds for another Scene to complete.  A device seeing Insteon traffic will abort its Scene communication.   That is explained in the insteondetails.pdf doc at insteon.com.  Press two KPL buttons at the same time, only one  Scene will complete.
Not the exact situation with the activity going on with the EZIO8SA Relays and Inputs but I believe it applies.   An earlier post indicated applying +12 to each Input caused it to turn On and report that to the ISY so the necessary link records exist and the Inputs work.  Official confirmation would have to come from the device owner, Smartenit.
