VENSTAR T1800 - Fan Control
Hi Guys, I just installed a Venstar Thermostat and I don't know if Im doing something wrong or this device is missing an important feature. I need to trigger things as the fan goes ON.
My Fan shows its Off all the time, even when the system is working.
The fan is set to Auto because I don't want it running 24/7.
I tried to reinstall it, making sure everything was OFF when linking.
Am I missing something here ?
Thank you all !
Hi
"Fan On" is set when someone opens the door of the thermostat and manually presses the fan On button (or you send "Fan On" from the ISY). However, it does not show "Fan On" if your HVAC unit turns on the fan in response to heating or cooling.  The HVAC unit physically turns the fan on locally in the unit itself.
There might be other ways to get the results you are looking for. Could you provide more information on what you want to do, eg measure run time?
  • 1 month later...
Hi
Hey Paulbates,
Thanks for the answer.
I have a booster fan inside my air duct for my master bedroom.
I want every time the fan for the HVAC goes ON to turn my booster ON as well.
Thats the solution Im using right now:
If        Status  'Thermostat - Cool Ctl' is On
        Set 'Booster Fan' Fast On
        Set 'Booster Fan' Fast Off
Its working ... :)
Thanks a lot !
Thiago
You may want to add an "Or" when heat is called for.
