Range Extender 2992-222
I am trying to add a new Range Extender 2992-222 device, but I get an error "Unsupported Device:0.29".  I tried adding it manually but that fails as well.  I did search the forums and didn't see anyone mention trying to actually add this device.  I am using the latest 4.2.10 Firmware and UI.  Is there anything I can do until it's officially supported?
Jim
There is no adding range extenders, nor no need to add range extenders.  Plug them in, they start extending.
You can use the four Set Button Tap sequence to start the Beacon Communications test.
The Full Users Manual link is not on the sales page but is on the manuals page of Insteon.com
Seems the Quick Start Guide is now published in English and a English, French-Canadian version.
The Full Users Manual has a nice chart in it. On how the LEDs on other Dual Band Modules display communications information. Including the original Access Points with a White LED only and not the Red/Green ones in present modules.
http://support.insteon.com/customer/portal/articles/1595203
Edited by Brian H
