IR Control not working as expected
clarkes71
I copied the programs from this forum or wiki and they don't work as I expected them too.
The first program works great - it turns on the lamp when I press the associated button on my Harmony remote:
        IR 'IR_002' is Pressed
    And Status  'Family Room / Table Lamps' is Off
        Set Scene 'Family Room / Family Room Table Lamps' On
Second program works, but then the issue:
        IR 'IR_002' is Double Pressed
    And Status  'Family Room / Table Lamps' is not Off
        Set Scene 'Family Room / Family Room Table Lamps' Off
What happens is that the lamp goes off, but then 1-2 seconds later, the lamp light comes back on?  Hoping someone could tell me why that is so?
I've not had good luck trying to use the Double Press, not sure why, but I use "Hold" instead.
Try changing your second program to:
        IR 'IR_002' is Held
(etc)
then trigger the program by Holding (Long Press) the button for about 2 seconds.
Does that work reliably for you?
I have changed the program to 'held' and removed-  And Status  'Family Room / Table Lamps' is not Off
After that, I was able to get things to work correctly....  Thanks!
      38.2k
      381k
