Keypad
Vipola
Okay So I have a few keypad that I have setup a few years ago.. everything worked great for a while.. and now here and There.. a Button would stop doing what it been doing for months.. other button would work.. For the First Time Today I tried to do a Restore Device.. and it end with a Cannot Communicate With X Please Check connections.. I still can trigger the keypad ON/OFF from ISY Admin.. but don't seems I can program it... I went through this forum, and Activated the Event Viewer Level 3.. I didn't touch my Insteon/ISY setup for 1-2 Years, and never needed debuging in the past..
Device is 13.84.0D - 2486D KeypadLinc Dimmer 6 Buttons v.35
It used to work.. is my keypad defective?  how can I test it or try to RESET it ?.. Thanks for the help :)
This is what I got when I tried to do a Write to Device
Fri 09/19/2014 08:38:38 PM : [13 84 D 1   ] Link    0 : 0FF8 [A2431322FFFF1F04] Writing [A2431322FFFF1F04]
Fri 09/19/2014 08:38:38 PM : [iNST-TX-I1  ] 02 62 13 84 0D 0F 28 0F
Fri 09/19/2014 08:38:38 PM : [iNST-ACK    ] 02 62 13.84.0D 0F 28 0F 06          SET-MSB(0F)
Fri 09/19/2014 08:38:38 PM : [iNST-SRX    ] 02 50 13.84.0D 13.22.FF 27 28 0F    SET-MSB(0F)
Fri 09/19/2014 08:38:38 PM : [standard-Direct Ack][13.84.0D-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Fri 09/19/2014 08:38:38 PM : [iNST-TX-I1  ] 02 62 13 84 0D 0F 2B F8
Fri 09/19/2014 08:38:38 PM : [iNST-ACK    ] 02 62 13.84.0D 0F 2B F8 06          PEEK   (F8)
Fri 09/19/2014 08:38:47 PM : [iNST-TX-I1  ] 02 62 13 84 0D 0F 28 0F
Fri 09/19/2014 08:38:47 PM : [iNST-ACK    ] 02 62 13.84.0D 0F 28 0F 06          SET-MSB(0F)
Fri 09/19/2014 08:38:47 PM : [iNST-SRX    ] 02 50 13.84.0D 13.22.FF 27 28 0F    SET-MSB(0F)
Fri 09/19/2014 08:38:47 PM : [standard-Direct Ack][13.84.0D-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Fri 09/19/2014 08:38:47 PM : [iNST-TX-I1  ] 02 62 13 84 0D 0F 2B F8
Fri 09/19/2014 08:38:47 PM : [iNST-ACK    ] 02 62 13.84.0D 0F 2B F8 06          PEEK   (F8)
Fri 09/19/2014 08:38:56 PM : [iNST-TX-I1  ] 02 62 13 84 0D 0F 28 0F
Fri 09/19/2014 08:38:56 PM : [iNST-ACK    ] 02 62 13.84.0D 0F 28 0F 06          SET-MSB(0F)
Fri 09/19/2014 08:38:57 PM : [iNST-SRX    ] 02 50 13.84.0D 13.22.FF 23 28 0F    SET-MSB(0F)
Fri 09/19/2014 08:38:57 PM : [standard-Direct Ack][13.84.0D-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Fri 09/19/2014 08:38:57 PM : [iNST-TX-I1  ] 02 62 13 84 0D 0F 2B F8
Fri 09/19/2014 08:38:57 PM : [iNST-ACK    ] 02 62 13.84.0D 0F 2B F8 06          PEEK   (F8)
Fri 09/19/2014 08:38:58 PM : [          IR]     014A Press
Fri 09/19/2014 08:39:01 PM : [13 84 D 1   ] Link    0 : 0FF8 [A2431322FFFF1F04] *Failed Writing [A2431322FFFF1F04]
Fri 09/19/2014 08:39:33 PM : [          IR]     0155 Press
This is what I get when I try to send ON / OFF from ISY ADMIN
Fri 09/19/2014 09:20:32 PM : [iNST-TX-I1  ] 02 62 13 84 0D 0F 13 00
Fri 09/19/2014 09:20:32 PM : [iNST-ACK    ] 02 62 13.84.0D 0F 13 00 06          LTOFFRR(00)
Fri 09/19/2014 09:20:33 PM : [iNST-SRX    ] 02 50 13.84.0D 13.22.FF 23 13 00    LTOFFRR(00)
Fri 09/19/2014 09:20:33 PM : [standard-Direct Ack][13.84.0D-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Fri 09/19/2014 09:20:33 PM : [   13 84 D 1]      ERR   0
Fri 09/19/2014 09:20:33 PM : [   13 84 D 1]       ST   0
Fri 09/19/2014 09:20:33 PM : [iNST-TX-I1  ] 02 62 00 00 3A CF 11 00
Fri 09/19/2014 09:20:33 PM : [iNST-ACK    ] 02 62 00.00.3A CF 11 00 06          LTONRR (00)
Fri 09/19/2014 09:20:37 PM : [iNST-TX-I1  ] 02 62 13 84 0D 0F 11 FF
Fri 09/19/2014 09:20:37 PM : [iNST-ACK    ] 02 62 13.84.0D 0F 11 FF 06          LTONRR (FF)
Fri 09/19/2014 09:20:37 PM : [iNST-SRX    ] 02 50 13.84.0D 13.22.FF 23 11 FF    LTONRR (FF)
Fri 09/19/2014 09:20:37 PM : [standard-Direct Ack][13.84.0D-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Fri 09/19/2014 09:20:37 PM : [   13 84 D 1]       ST 255
Fri 09/19/2014 09:20:38 PM : [iNST-TX-I1  ] 02 62 00 00 3A CF 11 00
Fri 09/19/2014 09:20:38 PM : [iNST-ACK    ] 02 62 00.00.3A CF 11 00 06          LTONRR (00)
Fri 09/19/2014 09:20:45 PM : [          IR]     02AA Press
Fri 09/19/2014 09:20:51 PM : [iNST-TX-I1  ] 02 62 13 84 0D 0F 13 00
Fri 09/19/2014 09:20:51 PM : [iNST-ACK    ] 02 62 13.84.0D 0F 13 00 06          LTOFFRR(00)
Fri 09/19/2014 09:20:54 PM : [          IR]     016A Press
Fri 09/19/2014 09:20:55 PM : [   13 84 D 1]      ERR   1
Fri 09/19/2014 09:20:58 PM : [          IR]     016A Press
This is what I get when I ON/OFF a Scene from ISY Admin, that D Button is actually still working well and opening and closing 13.5C.FF
Fri 09/19/2014 09:30:48 PM : [          IR]     02B5 Press
Fri 09/19/2014 09:30:57 PM : [iNST-TX-I1  ] 02 62 00 00 14 CF 13 00
Fri 09/19/2014 09:30:57 PM : [iNST-ACK    ] 02 62 00.00.14 CF 13 00 06          LTOFFRR(00)
Fri 09/19/2014 09:30:57 PM : [   13 84 D 1]      ERR   0
Fri 09/19/2014 09:31:01 PM : [iNST-TX-I1  ] 02 62 00 00 14 CF 11 00
Fri 09/19/2014 09:31:01 PM : [iNST-ACK    ] 02 62 00.00.14 CF 11 00 06          LTONRR (00)
Fri 09/19/2014 09:31:01 PM : [   13 84 D 4]       ST 255
Fri 09/19/2014 09:31:01 PM : [  13 5C FF 1]       ST 255
Fri 09/19/2014 09:31:02 PM : [iNST-TX-I1  ] 02 62 00 00 3A CF 11 00
Fri 09/19/2014 09:31:02 PM : [iNST-ACK    ] 02 62 00.00.3A CF 11 00 06          LTONRR (00)
Fri 09/19/2014 09:31:02 PM : [  13 80 A0 1]      ERR   0
Fri 09/19/2014 09:31:11 PM : [          IR]     0155 Press
And This is from a Restore Device:
Fri 09/19/2014 09:25:17 PM : [   13 84 D 1] Preparing Device 'Cuisine A' for Restore
Fri 09/19/2014 09:25:17 PM : [   13 84 D 1] Device 'Cuisine A' ready for Full Restore
Fri 09/19/2014 09:25:17 PM : [All         ] Writing 104 bytes to devices
Fri 09/19/2014 09:25:17 PM : [13 80 A0 1  ] Link   45 : 0E90 [E207173781FF1F07] Writing [E207173781FF1F07]
Fri 09/19/2014 09:25:17 PM : [iNST-TX-I1  ] 02 62 13 80 A0 0F 28 0E
Fri 09/19/2014 09:25:17 PM : [iNST-ACK    ] 02 62 13.80.A0 0F 28 0E 06          SET-MSB(0E)
Fri 09/19/2014 09:25:18 PM : [iNST-SRX    ] 02 50 13.80.A0 13.22.FF 27 28 0E    SET-MSB(0E)
Fri 09/19/2014 09:25:18 PM : [standard-Direct Ack][13.80.A0-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Fri 09/19/2014 09:25:18 PM : [iNST-TX-I1  ] 02 62 13 80 A0 0F 2B 90
Fri 09/19/2014 09:25:18 PM : [iNST-ACK    ] 02 62 13.80.A0 0F 2B 90 06          PEEK   (90)
Fri 09/19/2014 09:25:18 PM : [iNST-SRX    ] 02 50 13.80.A0 13.22.FF 27 2B E2    PEEK   (E2)
Fri 09/19/2014 09:25:18 PM : [iNST-TX-I1  ] 02 62 13 80 A0 0F 28 0E
Fri 09/19/2014 09:25:18 PM : [iNST-ACK    ] 02 62 13.80.A0 0F 28 0E 06          SET-MSB(0E)
Fri 09/19/2014 09:25:19 PM : [iNST-SRX    ] 02 50 13.80.A0 13.22.FF 27 28 0E    SET-MSB(0E)
Fri 09/19/2014 09:25:19 PM : [standard-Direct Ack][13.80.A0-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Fri 09/19/2014 09:25:19 PM : [iNST-TX-I1  ] 02 62 13 80 A0 0F 2B 91
Fri 09/19/2014 09:25:19 PM : [iNST-ACK    ] 02 62 13.80.A0 0F 2B 91 06          PEEK   (91)
Fri 09/19/2014 09:25:21 PM : [iNST-SRX    ] 02 50 13.80.A0 13.22.FF 23 2B 07    PEEK   (07)
Fri 09/19/2014 09:25:21 PM : [standard-Direct Ack][13.80.A0-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Fri 09/19/2014 09:25:21 PM : [iNST-TX-I1  ] 02 62 13 80 A0 0F 28 0E
Fri 09/19/2014 09:25:21 PM : [iNST-ACK    ] 02 62 13.80.A0 0F 28 0E 06          SET-MSB(0E)
Fri 09/19/2014 09:25:21 PM : [iNST-ERX    ] 02 51 13 80 A0 13 22 FF 72 6B CE 12 23 BD 40 00 00 00 00 00 00 00 00 00 B0
Fri 09/19/2014 09:25:21 PM : [standard-Cleanup Ack][13.80.A0-->ISY/PLM Group=0] Max Hops=2, Hops Left=0
Fri 09/19/2014 09:25:21 PM : [iNST-SRX    ] 02 50 13.80.A0 13.22.FF 23 28 0E    SET-MSB(0E)
Fri 09/19/2014 09:25:21 PM : [iNST-TX-I1  ] 02 62 13 80 A0 0F 2B 92
Fri 09/19/2014 09:25:21 PM : [iNST-ACK    ] 02 62 13.80.A0 0F 2B 92 06          PEEK   (92)
Fri 09/19/2014 09:25:22 PM : [iNST-SRX    ] 02 50 13.80.A0 13.22.FF 27 2B 17    PEEK   (17)
Fri 09/19/2014 09:25:22 PM : [standard-Direct Ack][13.80.A0-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Fri 09/19/2014 09:25:22 PM : [iNST-TX-I1  ] 02 62 13 80 A0 0F 28 0E
Fri 09/19/2014 09:25:22 PM : [iNST-ACK    ] 02 62 13.80.A0 0F 28 0E 06          SET-MSB(0E)
Fri 09/19/2014 09:25:23 PM : [iNST-ERX    ] 02 51 13 80 A0 13 22 FF 15 41 B5 71 13 BD 40 00 00 00 00 00 00 00 00 00 B0
Fri 09/19/2014 09:25:23 PM : [Extended-Direct][13.80.A0-->ISY/PLM Group=0] Max Hops=1, Hops Left=1
Fri 09/19/2014 09:25:32 PM : [iNST-TX-I1  ] 02 62 13 80 A0 0F 28 0E
Fri 09/19/2014 09:25:32 PM : [iNST-ACK    ] 02 62 13.80.A0 0F 28 0E 06          SET-MSB(0E)
Fri 09/19/2014 09:25:32 PM : [iNST-SRX    ] 02 50 13.80.A0 13.22.FF 27 28 0E    SET-MSB(0E)
Fri 09/19/2014 09:25:32 PM : [standard-Direct Ack][13.80.A0-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Fri 09/19/2014 09:25:32 PM : [iNST-TX-I1  ] 02 62 13 80 A0 0F 2B 93
Fri 09/19/2014 09:25:32 PM : [iNST-ACK    ] 02 62 13.80.A0 0F 2B 93 06          PEEK   (93)
Fri 09/19/2014 09:25:32 PM : [iNST-SRX    ] 02 50 13.80.A0 13.22.FF 27 2B 37    PEEK   (37)
Fri 09/19/2014 09:25:33 PM : [iNST-ACK    ] 02 62 13.80.A0 0F 28 0E 06          SET-MSB(0E)
Fri 09/19/2014 09:25:33 PM : [iNST-SRX    ] 02 50 13.80.A0 13.22.FF 27 28 0E    SET-MSB(0E)
Fri 09/19/2014 09:25:33 PM : [standard-Direct Ack][13.80.A0-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Fri 09/19/2014 09:25:33 PM : [iNST-TX-I1  ] 02 62 13 80 A0 0F 2B 94
Fri 09/19/2014 09:25:33 PM : [iNST-ACK    ] 02 62 13.80.A0 0F 2B 94 06          PEEK   (94)
Fri 09/19/2014 09:25:33 PM : [iNST-SRX    ] 02 50 13.80.A0 13.22.FF 27 2B 81    PEEK   (81)
Fri 09/19/2014 09:25:33 PM : [iNST-TX-I1  ] 02 62 13 80 A0 0F 28 0E
Fri 09/19/2014 09:25:34 PM : [iNST-ACK    ] 02 62 13.80.A0 0F 28 0E 06          SET-MSB(0E)
Fri 09/19/2014 09:25:34 PM : [iNST-SRX    ] 02 50 13.80.A0 13.22.FF 23 28 0E    SET-MSB(0E)
Fri 09/19/2014 09:25:34 PM : [standard-Direct Ack][13.80.A0-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Fri 09/19/2014 09:25:34 PM : [iNST-TX-I1  ] 02 62 13 80 A0 0F 2B 95
Fri 09/19/2014 09:25:34 PM : [iNST-ACK    ] 02 62 13.80.A0 0F 2B 95 06          PEEK   (95)
Fri 09/19/2014 09:25:35 PM : [iNST-SRX    ] 02 50 13.80.A0 13.22.FF 23 2B FF    PEEK   (FF)
Fri 09/19/2014 09:25:35 PM : [standard-Direct Ack][13.80.A0-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Fri 09/19/2014 09:25:35 PM : [iNST-TX-I1  ] 02 62 13 80 A0 0F 28 0E
Fri 09/19/2014 09:25:35 PM : [iNST-ACK    ] 02 62 13.80.A0 0F 28 0E 06          SET-MSB(0E)
Fri 09/19/2014 09:25:35 PM : [iNST-SRX    ] 02 50 13.80.A0 13.22.FF 27 28 0E    SET-MSB(0E)
Fri 09/19/2014 09:25:35 PM : [standard-Direct Ack][13.80.A0-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Fri 09/19/2014 09:25:35 PM : [iNST-TX-I1  ] 02 62 13 80 A0 0F 2B 96
Fri 09/19/2014 09:25:35 PM : [iNST-ACK    ] 02 62 13.80.A0 0F 2B 96 06          PEEK   (96)
Fri 09/19/2014 09:25:35 PM : [iNST-SRX    ] 02 50 13.80.A0 13.22.FF 27 2B 1F    PEEK   (1F)
Fri 09/19/2014 09:25:36 PM : [iNST-ACK    ] 02 62 13.80.A0 0F 28 0E 06          SET-MSB(0E)
Fri 09/19/2014 09:25:36 PM : [iNST-SRX    ] 02 50 13.80.A0 13.22.FF 27 28 0E    SET-MSB(0E)
Fri 09/19/2014 09:25:36 PM : [standard-Direct Ack][13.80.A0-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Fri 09/19/2014 09:25:36 PM : [iNST-TX-I1  ] 02 62 13 80 A0 0F 2B 97
Fri 09/19/2014 09:25:36 PM : [iNST-ACK    ] 02 62 13.80.A0 0F 2B 97 06          PEEK   (97)
Fri 09/19/2014 09:25:37 PM : [iNST-SRX    ] 02 50 13.80.A0 13.22.FF 23 2B 07    PEEK   (07)
Fri 09/19/2014 09:25:37 PM : [standard-Direct Ack][13.80.A0-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Fri 09/19/2014 09:25:37 PM : [13 80 A0 1  ] Link   46 : 0E88 [E20717386EFF1F07] Writing [E20717386EFF1F07]
Fri 09/19/2014 09:25:37 PM : [iNST-TX-I1  ] 02 62 13 80 A0 0F 28 0E
Fri 09/19/2014 09:25:37 PM : [iNST-ACK    ] 02 62 13.80.A0 0F 28 0E 06          SET-MSB(0E)
Fri 09/19/2014 09:25:37 PM : [iNST-SRX    ] 02 50 13.80.A0 13.22.FF 27 28 0E    SET-MSB(0E)
Fri 09/19/2014 09:25:37 PM : [standard-Direct Ack][13.80.A0-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Fri 09/19/2014 09:25:37 PM : [iNST-TX-I1  ] 02 62 13 80 A0 0F 2B 88
Fri 09/19/2014 09:25:37 PM : [iNST-ACK    ] 02 62 13.80.A0 0F 2B 88 06          PEEK   (88)
Fri 09/19/2014 09:25:38 PM : [iNST-SRX    ] 02 50 13.80.A0 13.22.FF 23 2B E2    PEEK   (E2)
Fri 09/19/2014 09:25:38 PM : [standard-Direct Ack][13.80.A0-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Fri 09/19/2014 09:25:38 PM : [iNST-TX-I1  ] 02 62 13 80 A0 0F 28 0E
Fri 09/19/2014 09:25:38 PM : [iNST-ACK    ] 02 62 13.80.A0 0F 28 0E 06          SET-MSB(0E)
Fri 09/19/2014 09:25:38 PM : [iNST-SRX    ] 02 50 13.80.A0 13.22.FF 27 28 0E    SET-MSB(0E)
Fri 09/19/2014 09:25:38 PM : [standard-Direct Ack][13.80.A0-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Fri 09/19/2014 09:25:38 PM : [iNST-TX-I1  ] 02 62 13 80 A0 0F 2B 89
Fri 09/19/2014 09:25:38 PM : [iNST-ACK    ] 02 62 13.80.A0 0F 2B 89 06          PEEK   (89)
Fri 09/19/2014 09:25:38 PM : [iNST-SRX    ] 02 50 13.80.A0 13.22.FF 27 2B 07    PEEK   (07)
Fri 09/19/2014 09:25:39 PM : [iNST-ACK    ] 02 62 13.80.A0 0F 28 0E 06          SET-MSB(0E)
Fri 09/19/2014 09:25:39 PM : [iNST-SRX    ] 02 50 13.80.A0 13.22.FF 27 28 0E    SET-MSB(0E)
Fri 09/19/2014 09:25:39 PM : [standard-Direct Ack][13.80.A0-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Fri 09/19/2014 09:25:39 PM : [iNST-TX-I1  ] 02 62 13 80 A0 0F 2B 8A
Fri 09/19/2014 09:25:39 PM : [iNST-ACK    ] 02 62 13.80.A0 0F 2B 8A 06          PEEK   (8A)
Fri 09/19/2014 09:25:40 PM : [iNST-SRX    ] 02 50 13.80.A0 13.22.FF 23 2B 17    PEEK   (17)
Fri 09/19/2014 09:25:40 PM : [standard-Direct Ack][13.80.A0-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Fri 09/19/2014 09:25:40 PM : [iNST-TX-I1  ] 02 62 13 80 A0 0F 28 0E
Fri 09/19/2014 09:25:40 PM : [iNST-ACK    ] 02 62 13.80.A0 0F 28 0E 06          SET-MSB(0E)
Fri 09/19/2014 09:25:40 PM : [iNST-SRX    ] 02 50 13.80.A0 13.22.FF 27 28 0E    SET-MSB(0E)
Fri 09/19/2014 09:25:40 PM : [standard-Direct Ack][13.80.A0-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Fri 09/19/2014 09:25:40 PM : [iNST-TX-I1  ] 02 62 13 80 A0 0F 2B 8B
Fri 09/19/2014 09:25:40 PM : [iNST-ACK    ] 02 62 13.80.A0 0F 2B 8B 06          PEEK   (8B)
Fri 09/19/2014 09:25:40 PM : [iNST-SRX    ] 02 50 13.80.A0 13.22.FF 27 2B 80    PEEK   (80)
Fri 09/19/2014 09:25:40 PM : [iNST-TX-I1  ] 02 62 13 80 A0 0F 29 38
Fri 09/19/2014 09:25:41 PM : [iNST-ACK    ] 02 62 13.80.A0 0F 29 38 06          POKE   (38)
Fri 09/19/2014 09:25:41 PM : [iNST-SRX    ] 02 50 13.80.A0 13.22.FF 27 29 38    POKE   (38)
Fri 09/19/2014 09:25:41 PM : [standard-Direct Ack][13.80.A0-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Fri 09/19/2014 09:25:41 PM : [iNST-TX-I1  ] 02 62 13 80 A0 0F 2B 8C
Fri 09/19/2014 09:25:41 PM : [iNST-ACK    ] 02 62 13.80.A0 0F 2B 8C 06          PEEK   (8C)
Fri 09/19/2014 09:25:41 PM : [iNST-SRX    ] 02 50 13.80.A0 13.22.FF 27 2B A7    PEEK   (A7)
Fri 09/19/2014 09:25:41 PM : [iNST-TX-I1  ] 02 62 13 80 A0 0F 29 6E
Fri 09/19/2014 09:25:42 PM : [iNST-ACK    ] 02 62 13.80.A0 0F 29 6E 06          POKE   (6E)
Fri 09/19/2014 09:25:43 PM : [iNST-SRX    ] 02 50 13.80.A0 13.22.FF 23 29 6E    POKE   (6E)
Fri 09/19/2014 09:25:43 PM : [standard-Direct Ack][13.80.A0-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Fri 09/19/2014 09:25:43 PM : [iNST-TX-I1  ] 02 62 13 80 A0 0F 2B 8D
Fri 09/19/2014 09:25:43 PM : [iNST-ACK    ] 02 62 13.80.A0 0F 2B 8D 06          PEEK   (8D)
Fri 09/19/2014 09:25:44 PM : [iNST-ERX    ] 02 51 13 80 A0 13 22 FF 57 2B FF EA B3 BD 40 00 00 00 00 00 00 00 00 00 B0
Fri 09/19/2014 09:25:44 PM : [standard-Cleanup][13.80.A0-->ISY/PLM Group=255] Max Hops=3, Hops Left=1
Fri 09/19/2014 09:25:44 PM : [standard Msg. Handler] Unexpected Response: ignored
Fri 09/19/2014 09:25:53 PM : [iNST-TX-I1  ] 02 62 13 80 A0 0F 28 0E
Fri 09/19/2014 09:25:53 PM : [iNST-ACK    ] 02 62 13.80.A0 0F 28 0E 06          SET-MSB(0E)
Fri 09/19/2014 09:25:53 PM : [iNST-ERX    ] 02 51 13 80 A0 13 22 FF 52 81 30 97 E3 BD 40 00 00 00 00 00 00 00 00 00 B0
Fri 09/19/2014 09:25:53 PM : [standard-Cleanup][13.80.A0-->ISY/PLM Group=48] Max Hops=2, Hops Left=0
Fri 09/19/2014 09:26:02 PM : [iNST-TX-I1  ] 02 62 13 80 A0 0F 28 0E
Fri 09/19/2014 09:26:02 PM : [iNST-ACK    ] 02 62 13.80.A0 0F 28 0E 06          SET-MSB(0E)
Fri 09/19/2014 09:26:03 PM : [iNST-SRX    ] 02 50 13.80.A0 13.22.FF 23 28 0E    SET-MSB(0E)
Fri 09/19/2014 09:26:03 PM : [standard-Direct Ack][13.80.A0-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Fri 09/19/2014 09:26:03 PM : [iNST-TX-I1  ] 02 62 13 80 A0 0F 2B 8D
Fri 09/19/2014 09:26:03 PM : [iNST-ACK    ] 02 62 13.80.A0 0F 2B 8D 06          PEEK   (8D)
Fri 09/19/2014 09:26:03 PM : [iNST-ERX    ] 02 51 13 80 A0 13 22 FF 31 2B FF EA B3 BD 40 00 00 00 00 00 00 00 00 00 B0
Fri 09/19/2014 09:26:03 PM : [standard-Direct Ack][13.80.A0-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Fri 09/19/2014 09:26:03 PM : [standard Msg. Handler] Unexpected Response: ignored
Fri 09/19/2014 09:26:07 PM : [13 80 A0 1  ] Link   46 : 0E88 [E20717386EFF1F07] *Failed Writing [E20717386EFF1F07]
Fri 09/19/2014 09:26:07 PM : [  13 80 A0 1]      ERR   1
P.S. by the way.. what are all those IR Press event?.. I'm not aware of any IR going on in the house at this time..
Fri 09/19/2014 09:21:28 PM : [          IR]     0155 Press
Fri 09/19/2014 09:21:49 PM : [          IR]     0155 Press
Fri 09/19/2014 09:22:07 PM : [          IR]     02AA Press
Fri 09/19/2014 09:22:17 PM : [          IR]     0155 Press
Fri 09/19/2014 09:22:20 PM : [          IR]     0155 Press
Fri 09/19/2014 09:22:58 PM : [          IR]     0155 Press
You now have comm issues.  Some commands had to be retried and worked.  Others commands were retried and failed the retry.  Some new device on the powerline that is generating noise?   Perhaps a new power strip that is causing powerline issues?
The IR events are received through the IR port on the ISY.   Any new audio/video installed that is sending IR activity?
So you are saying it's not the KeyPad itself that is buggy it's the communication between the ISY and the Keypad?
I just did multiple Restore Device on bunch of KeyPad and Switch on the same circuit (and in the same electric box) without any problem.. that's why I think it would be the Keypad.. but I have the same kind of issues with two different keypad installed at different places in the house.. It's not new.. they been acting funny for few months I just didn't had time to look into them..
is there anyway I can test the Device Itself.. or try to Reset them or something?
Is there any documentation for reading those Insteon Event (inst-tx inst-ack inst-srx) ? where do you see that it retry and sometime succeed?..
This command failed (no 02 50 ....) to get a Response and was retried.
The retry worked but has a Hops Left=0 which is as bad as it gets and still work.
This command failed.
You can try a Factory Reset of the KPL which will require another Restore Device.  If other devices on the same circuit work well then I would think the KPL may be in trouble.  If you have a spare KPL replace this KPL.   if the new one works problem solved.  If not then comm issues need to be looked at.
There is an insteondetails.pdf document at insteon.com that covers Insteon details.
There is a Wiki section that covers some of what you are asking about.
Cover the IR port opening with opaque tape to see if IR events stop.
