PLM Cable Link?
Is there a maximum length for the cable between the ISY & PLM? I'm using a 2413S, the ISY has its own power supply. Thanks!
The PLM guide says 10' max with 6' or less recommended.
From the guide "Do not use a serial cable longer than 10’ (6’ or less is recommended)"
Edited by LeeG
I've got mine going through about 15' of cat6 cable, 2 keystone jacks, and a 12" patch cable on each end. Hasn't been a problem.
