Motion Sensor with light
I have a light(insteon bulb) that gets turned on by motion(insteon) but I have the light turn on to a different level depending on the time of day.
My issue is that it when the light turns on for the 3 minutes then it turns off. But what I would like is for the timer to reset if again motion is detected in those three minutes.
Here is the code for the scheduled program:
        From     5:30:01AM
        To      10:29:59PM (same day)
    And Control 'Motion Sensor-Sensor' is switched On
    And Control 'Motion Sensor-Sensor' is not switched Off
        Set 'Light Bulb' Fast On
        Wait  3 minutes
        Set 'Light Bulb' Off
The Sensor is switched On indicates motion.   A Wait 3 minutes should be in the Then.  Also the motion sensor should be in On Only mode so the motion Off does not conflict with what the program is doing.
        From     5:30:01AM
        Wait  3 minutes
        Wait  3 minutes
Failed to copy the full Program
Edited by LeeG
Also note that LeeG's suggestion has nothing in the "Else" section?
 At 10:29:59PM the "else" is going to execute due to being triggered by the time end and the whole "if" logic  evaluating to  false.
At the end of the "Then" section you can add
 "run Program_name (else)"
if you want the folder icons to show colours reflecting their last Light Bulb control states. The MS will always show "On" after adjusting that setting.
  • 3 months later...
The light is still turning off after the 3 minutes goes by. I would like it to stay on if motion is detected in that 3 minutes and for it to start the 3min countdown again. This is the exact code that I have in my isy program. Do I need to have the jumpers at the back of the motion set up in some kind of arrangement?
        From     5:30:01AM
        Set Scene 'Light Bulb Scene (day)' On
        Wait  3 minutes
        Set Scene 'Light Bulb Scene (day)' Off
        Wait  3 minutes
What is the configuration of your motion sensor.  Is it possible it is not sending ON commands before the 3 minute timer?  The program, to me looks fine.
Yes you need jumpers set in a specific way.  Instructions will describe purpose of each.  Check out jumper 5...I believe this allows software control, allowing ISY to set parameters.  Once enabled, make sure you sensor is in occupancy mode (triggering ON command at every sensed motion, no time-out periods.)
Another possibility...is the light and sensor part of a scene together?
I had jumper 1,4,5 on I took 1,4 off and kept 5 as you suggested. Still turns off after 3 minutes time elapsed with motion present. then
I took 1,4 and 5 off and still turns off after 3 minutes time elapsed with motion present.
I put only jumper 4 on and the issue continues
I put only jumpers 4 and 5 still nothing.
It seems to me that it is detecting motion because during those three minutes the red led light blinks.
The motion is not in a scene with the light bulb. however the bulb is in its own scene. so the motion is controlling a scene.
I have downloaded the sensor manual to know what jumpers I am switching and it seems to me there must be something else to it.
Jumper 5 should be the only jumper in use.
Put the Motion Sensor into linking mode and set these Options
EDIT:  note that MS Options display is from 4.2.22.   The MS Options display looks different on 4.2.18 but the options work the same.  UDI changed the format of the display, not the underlying MS Options themselves.
Edited by LeeG
problem seems to be solved. Thanks LeeG!
