Certificate Issue
As recently referred to in the ISY99 forum, I too have an issue on both of my home computers with certificate issues for my ISY994IR.
I ran the admin.jnlp that Michael loaded to the ISY99 forum and it worked well, but as with the ISY99 forum, it does not work from the normal log in. I must run the admin.jnlp to get in.
I have firmware 3.3.10 and was going to do a manual upgrade, but elected to write in first.
BTW: Could this have anything to do with my failure to be able to change over to the new weather system?
Glenn Hargett
Glenn
You should upgrade your ISY firmware, 3.3.10 is outdated. This assumes that you have a 994i and not the 99i which was discontinued.
The current weather provider, HamWeather, will not work unless you have the latest firmware
