Monitor for loss of power on an outlet
I have a sump high level alarm (hooked up to ELK M1) that plugs in an outlet....recently the breaker tripped and I didn't get a high level alarm.  Is there a module that I can rig to tell me if the alarm circuit lost power?
John
An I/O Linc with the NC contacts connected to the external contacts of an  INSTEON wireless Open/Close sensor (2843-222). Use latching mode and turn the I/O Linc relay On.
Thanks....I can probably use the I/O link and connect directly to ELK M1, when relay drops out NO contacts will close.....
