ISY994i/ir pro unresponsive after upgrade to latest firmware
Can't get it to show in the network.  Can't access it from this website.  Tried pulling the plug and restart to no avail, same for plm.
I have a single blue led.
Any suggestions?
What is the result if you browse to http://isy or, if you assigned a port, then http://isy:port_number
Edited by stusviews
OK, now I can access it from the website, maybe it wasn't done rebooting.
It still doesn't show up in "network" in internet explorer.  Do you know what causes that?
thanks,
Chris
I don't understand what that means.
If you're referring to the ISY no longer showing up in the network window it's because UDI  disabled UPnP due to security concerns.
If you would like the ISY to be visible in your network window then you need to go to Admin Console | Configuration | System | network and check UPnP.
Wow!  That's it!  Thank you both.  I believe that will take care of the problem and provide a nice end to the weekend.
Thanks again.
