TimerLinc Support in ISY firmware 2.6.7
When adding a TimerLinc to the ISY, it is detected by default as an "Unsupported Device". This will allow the ISY to use the TimerLinc in scenes, but only as a responder.
In order to use the TimerLinc as a controller, do a "New Insteon Device" and manually add the TimerLinc as a "SwitchLinc Relay". This will allow the ISY to use the TimerLinc as a controller and/or responder in scenes.
The ISY will be aware of state changes when controlling the TimerLinc (and any linked devices) with its ON/OFF button, located on the front of the unit, or through it's programmed timer events. However, the ISY will NOT be aware of state changes if the TimerLinc is turned on via its 'load sensing' feature.
