Programmind Question
        Status  'ROG Other KPL / ROG Other KPL A (Bedtime)' is On
        Set 'Chandelier (Upstairs)' On
        Set 'Mom's Bedroom KPL / Mom's Bedroom KPL 1 (Light)' On
        Wait  5 minutes
        Set 'Chandelier (Upstairs)' Off
The foregoing program allows my wife to press KPL A in the ROG and turn the upstairs chandelier and her bedroom light on. After 5 minutes, the chandelier cuts off. The program works as designed, however, the KPL A button remains lit following execution of the program and must be pressed twice for the program to run next time. What do I need to do to have KPL return to its OFF state, ready to run with a single tap next time?
The brute-force method would simply be to add a statement at the end of your program to turn off the kpl button. If this button is a secondary button, you may need to create a new scene, containing only that button, and turn the scene off by program.
An alternative, depending on your needs, is to create a scene with the ROG keypad controller and chandelier as responder, and modify the program:
CONTROL 'ROG Other....
Set moms bedroom kpl on
Wait 5 minutes
Set new scene off
Nothing
Edited by oberkc
When It try the "brute force" method, the only option I get for KPL A is to chenge its LED level, not turn it OFF.
Smokegrub-
If this is a 6 button KPL, the KPL-A is a secondary button and would need to be controlled by a scene.  Create a new scene and make the KPL-A button a responder.  Then in your program, also turn off that new scene.
-Xathros
Smokegrub-
-Xathros
Xathros:
It is a 6-button KPL. I don't understand what you are suggesting. Keep in mind that I want to delay turning off the chandelier for 5 minutes while leaving the bedroom light on. Then, I want to somehow turn off the ROG Other KPL A. Could I impose on you to be abit more specific as to what the scene includes and how I use it with the exiting program? Thanks.
I briefly mentioned the need for a scene in my original response. Create a new scene. Include in this scene the keypad button, as responder, nothing else. In the program, include a statement to turn off the new scene.
Xathros:
You bet.
Since the secondary buttons on the KPL (A-D) are not directly addressable like a switchlinc or the main On/Off buttons on the KPL, they need to be controlled by a scene.  Create a new scene called ROG_KPL_A and place the KPL-A button in it as a responder.  You don't need to put anything else in this scene.
Then modify you program as follows:
        Wait  5 minutes
        Set 'ROG_KPL_A' Off
        Set 'ROG_KPL_A' Off
Notice the last line in both the Then and Else sections.
That should do it or you.
Hope this helps.
-Xathros
Edited by Xathros
Thanks Lee.  That is what I meant :)
-Xathros
My profound thanks to all of you. Two new programs in place and working perfectly. More importantly, additional programming knowledge acquired.
Excellent.  Glad we could help.
-Xathros
