Newbie Question
I purchased the 994i with Zwave inside, no external antenna, what is the range expectation for zwave devices realistically without the external antenna?  I need to connect a zwave device about 20 feet away from the 994i with a plaster wall in between. Is this realistic? Thanks!
While it is entirely device and environment dependent, 20 feet is not typically an issue. However, I've had devices pair and operate without trouble from three floors away and others that barely reach 10 feet.
