AT&T to end email-to-text ×
4 Tap Test
BamBamF16
Where can I find documentation of the 4-Tap Test and device response?  I've scoured all the manuals for my devices and can't for the life of me find it.  I must be dense or something.
Jeff
The 2413S PLM Quick Start Guide toward the bottom.
EDIT:  also found 4 tap initiate instructions in the 2992-222 Range Extender (was Access Point) Owner's Manual/Quick Start Guide.
Some of the latest Dual Band devices have dropped the description of how to initiate the test.  As far as I have observed these devices do respond to the test when initiated from another device such as the PLM.
The latest revision of the 2457D2 LampLinc. Uses the Set Button Flow Chart sequence to start what is now called the Beacon Test.
I have not see the four Set Button test mentioned in it manual. Though the four button tap may also work and not be documented anymore.
