LampLinc with Xmas lights
I have one LampLinc module connected to a string of Christmas lights inside my house.  The LampLinc turns the lights on as expected but when a OFF command is sent; the lights only dim to ~10% but the ISY shows the module as off.  Is this a problem with the LampLinc or the Christmas lights?
The LampLinc has a minimum load requirement. If you're using LEDs, that load may be less than the minimum required. Use a triple-tap and plug in a night light to increase the load.
