Help with KPL button to track modules ON state
Trying to use KPL button for dual use, but I need help getting scan part to work.
I would like a KPL button to indicate that other Insteon modules are in an ON state, and turn them off with the same switch.  Each night, a program shuts down all lights in a delayed order … but if I want to turn the lights off earlier than 11 PM, I have button B on two KPL’s to perform the all lights off manually
Sometimes the kids come in late and turn lights on, like garage or exterior lamps, so in the perfect world, I would like button B to light up again. If button B is pressed, it will run an “all shutdown” again.
As a newbie, my programming is probably not as efficient as it could be, but I would appreciate any help with the scan part
Program turns Lights on a Sunset in delayed manner and turns on KPL button B
        From    Sunset
        To      Sunrise (next day)
        Set Scene 'Lights - Button B' On
        Set 'Family Room Pot Lights' 70%
        Wait  2 minutes
        Set 'Kitchen Sink Light' On
        Wait  3 minutes
        Set 'Living Room Lights' On
        Wait  5 minutes
        Set 'Front Door - Ext Lights' On
               etc
This turns off lights at Bedtime and turns OFF button B
        On Sun, Mon, Tue, Wed, Thu
        Time is 11:00:00PM
        Set 'Family Room Pot Lights' Off
        Wait  3 minutes  (Random)
        Set 'Kitchen Sink Light' Off
        Set 'Living Room Lights' Off
               etc
        Set Scene 'Lights - Button B' Off
Button B turns off all lights before Bedtime timer triggers
        Status  'KPL Front Door - Ext Lights / Front KPL - B' is Off
     Or Status  'KPL Back Door - Garage Light / Rear KPL - B' is Off
        Set Scene 'Kitchen 3 Way' Off
               etc
Test program to scan for lights turned on after bedtime timer has already run
        From    Sunset
    And Status  'KPL Front Door - Ext Lights / Front KPL - B' is Off
    And (
             Status  'Family Room Pot Lights' >= 1%
          Or Status  'Kitchen Sink Light' >= 1%
               etc
        Set Scene 'Buttons B' On
I previously read that post, but my Keypad works for normal scenes ...
What doesn't work is the secondary scan to trigger the keypad back on ... The scan should only run when SunSet is true and keypad is currently in off state
How do i initiate a scan of all modules to determine if they are in an ON state again ... if an ON state is found, re-trigger the keypad to show on ?
Let me ask this question differently .. I built test programs to simplify my question and for a few cycles, it works, but then the modules flashing on / off many times and I get a window pop up on the Console writing data for a long time, so I assume this is a loop ?
How do you stop it .. or at lease get this program to work
First I scan for modules in an ON state provided the SunSet = TRUE and KPL - C is OFF
        From    Sunset
    And Status  'KPL Back Door - Garage Light / Rear KPL - C' is Off
     Or Status  'KPL Front Door - Ext Lights / Front KPL - C' is Off
    And (
             Status  'LampLinc 26.DD.BD' is not Off
          Or Status  'LampLinc 26.EB.83' is not Off
        Set Scene 'Buttons C' On   <<<<<<<<<<<<<<<<<<<<< turn on Button C scene
Next ... with Buttons C turned ON, either Button C will turn all modules off
        Status  'KPL Front Door - Ext Lights / Front KPL - C' is Off         <<<<<<<<<<<< manually turn all modules off
     Or Status  'KPL Back Door - Garage Light / Rear KPL - C' is Off
        Set 'LampLinc 26.DD.BD' Off
        Set 'LampLinc 26.EB.83' Off
If button B is off and you press it do you want it to turn anything on?
If not then I would consider setting B to non toggle off.
Create a scene with B as the controller and everything that you want off as a responder, with the response level set to off/ 0.
Create a scene with only the B buttons as responders "B buttons"
Write a program to monitor, not sure why only at night, this does not seem to need that condition.
If status device x is on
Or status device y is on
Or status device z is on
Then set scene B buttons on.
If you want the night time condition
If from sunset
To sunrise next day
And
(Status device x is on
Or status y is on
Or status z is on )
So if any of the devices are on, the Bs light up. Pressing b then will turn all lights off (so B can probably B toggle, not non toggle off)
If you don't want to make the scene with all responders and B as a controller then you could use a program
If control B1 is off
Or control B 2 is off
Set scene x off
Set scene y off
I'll throw some more ideas out
How about a program to run at 1am to turn everything off.
Maybe a notification. If (time is 11pm to sunrise next day)and garage lights are on then notification "garage lights are on
Automate it: if (time is 11pm to sunrise next day) and status garage lights are on then wait 30 minutes and run your second program then or set scene with all of the devices off.
Check out this tutorial: http://www.adamsj.com/isy/basementA.htm
Beauty of the isy and this forum is the flexibility and ideas to get the function you want.
Eric
