How to change Keypadlinc from 8 to 6 button
Hello, I know how to change a keypadlinc from 6 to 8 buttons by doing a Factory Reset and holding the A/H Buttons, but how do you change it back to a 6 button?  Does anyone know how to do that?
See the KeypadLinc Owner's Manual page 17
Configuring for 6 or 8-Button Operation
Changing to 6-Button Configuration
1) Replace the 8-button plate with the 6-button plate (see Changing to 6 or 8-Button Plate)
2) Gently pull the set button out as far is it will go
3) Wait 10 seconds
4) While simultaneously holding the On and Off buttons, carefully push the set button back in, flush with the trim frame
5) Continue holding the On and Off button until the keypad beeps
Keypad is now in 6 button mode
Changing to 8-Button Configuration
1) Replace the 6-button plate with the 8-button plate (see Changing to 6 or 8-Button Plate)
3) Wait 10 seconds
4) While simultaneously holding the On/Off (upper left-most) button and the H (bottom right-most) button, carefully push
5) Continue holding the On/Off (upper left-most) button and the H (bottom right-most) button until the keypad beeps
Keypad is now in 8 button mode
  • 1 year later...
When Changing from 8 to 6, you must press firmly on the On and Off Buttons so that both left and right sides of the Off and On Buttons are pressed for 3 Seconds.  Alternately, if you still have the 8 buttons on, you would press and hold the On/Off+B+G+H buttons (for 3 seconds) while pressing the set button flush with the frame.
