App Site closes on startup
Clif
When I log into my ISY994i, I get the the interface, then is simply closes the window before I can do anything. I have tried using 3 different browsers, but they all close the window before I can do anything.
What do I need to do to fix this action?
Clif
Are you trying to get to the admin interface or the dashboard? It should be downloading a java web start file to your computer in which you will need to open to access this. Make sure JRE is installed from java.com
Thanks, I have Java 8 Update 25 installed. Yes, I keep trying to to access the admin interface via this URL:
isy.universal-devices.com/994i/
and as soon as I type in admin/admin, it closes the browser.
well, I just tried accessing it by it's local IP address, and it still closes itself. I tried it on my wife's computer, and it works fine. So, I guess something on my laptop is having an issue.
Try reinstalling the Admin Console.
Thanks for all the good advice. I will see if I can clear my java cache today to see if that helps.
You should also check to see if the ISY is being blocked by any in suite fire wall / anti virus. If so please do white list the ISY for access so this isn't an issue.
This may also be a case where a browsers pop up settings have changed or set too high. Another thing to check is to use in private browsing and see if it makes a difference if the above does not work.
      378.6k
