isy994 vs the isy99
ingeborgdot
What will the isy994 give me over the isy99?  Will it make getting into my isy from outside my network easier?  If so, how?  Can someone explain that to me?  Thanks so very much.
The ISY99i is discontinued and because of firmware limitations. It will not support any of the latest Insteon Devices due to older firmware.
The last firmware for the ISY99i is 3.3.10.
I understand that.  Thanks.  Other than firmware is that it?  Will it stop the java issue of not letting me get on some computers because of security issues? What will the updated firmware do in the 994 that can't be done in the 99?  Thanks.
The updated firmware has more features. But it won't make off-site access any easier. What is your specific difficulty with off-site access?
I used to use dyndns but they went to pay instead of free so for the little I used it I didn't want the cost.  I then went to noip but for some reason it does not work properly.  I had to get a new router with AT&T Uverse and that doesn't give me any good options to use noip like the other router I had so that may be the reason more so than noip.  I just am not sure what to do to make it work properly on my other computers that I take on the road.  I did have it set after Michael helped me with just using my ip address but when I was gone it didn't work and came back to find the ip had changed.  That just doesn't cut it.  I just need to find a tutorial or something.
In the short term staying with the 99 is perfectly fine.
As others stated should you need to replace a device it won't work with the 99 as it won't be listed in the device table.
There are still lots of people using a 99 so don't feel alone. It's a solid box so keep using it until you need to migrate to a 994.
As I mentioned, off-site access does not differ between the 99 and the 994. And, as indicated by Teken, newer devices are not supported by the 99. So, you have a reason to stay (with what you have) and a reason to go (for an updated ISY).
In any case, you'll need a service for off-site access (or a costly static IP address). I don't have a recommendation for a free service.
For what it is worth, my latest router is from netgear. It comes with a complimentary static ip service mynetgear.com. So far, so good.
Keep in mind that lack of new device support extends to KeypadLincs.  If using KPLs and one fails the replacement KPLs cannot be used on a 99i.
You do not need to use or pay for the router from AT&T. I use a Netgear router and AT&T is the provider.
Posted (edited)
I would like to say one of the biggest updates in the 994 is having the ability to remote wake up and update a motion sensor.
If you have a few of these devices just having this ability is worth upgrading alone. This feature also works on the hidden door sensor and mini remotes.
NOTE: This feature may not work on all battery devices or previous generation firmware releases.
Edited by Teken
I had same issue with DYNDNS ... So I also started use my home IP ... But same problem my ISP changes my IP now and then and I won't pay for a static IP ...
So I have a device send me a daily email ... Look in the header and you will find your new IP ...
I think you could have the ISY do it , you may have to set the ISY to use your SMTP. I have not checked the header using the UD server, it may still contain your home IP.
Takes a few seconds yo look through the header, BUT saves me a bunch of money over buying a static IP.
Works for me when I'm away from home, might be an idea for you.
Don
Don
Don,
You're so old school I love it . . .
Posted (edited)
Don,
I think the word is "cheap"...  My static IP at home is $4 per month and I know that I can access my home from anywhere, at any time.  That's a small price to pay for peace of mind in my opinion.
Edited by 416to305
 Well you are fortunate !!
My ISP required a commercial account to assign me a static IP. That would have been about $45/month more.
Now if that's peanuts to you, again you are fortunate, but for me on SS retirement that is a significant sum of money.
I did not appreciate your "CHEAP" comment.
If can not be constructive keep your comments to yourself.
Don
Posted (edited)
Don
Don,
Worry not lots of the young folks like to throw good money out the window with out much care or thought about how to solve a problem.
This is something I've seen for ages which I am sure you can relate. We are fast approaching critical mass in automating ever facet of our lives. With out real people thinking about alternate solutions its safe to say the next generation are doomed to fail.
As I stated above, you taking the time to read the e-mail headers is something easy to do, free, and resolves the issue at hand. Kudo's to you in using your noggin in the way that also provides a solution down the road here and somewhere else.
I am not quite at your age group but rest assured *Old School* has led us to the moon and back . . .
Rock On . . .
Edited by Teken
DynDNS is $25/year which includes up to 30 host names.
I can understand a work environment blocking internet traffic, but a hotel? Which hotel did that?
Posted (edited)
I do understand work environments blocking certain, but not all internet sites. I've experienced that. But, which hotels? None that I've ever been to in Santa Barbara, a decidedly college party town. And Laguna Beach, a somewhat wild resort area in spite of being in Orange county.
Edited by stusviews
      38.1k
      380k
