Can I link a older 2000stw lamplinc?
I have an old smarthome lamplinc 2000stw.
I would like to link it until my newer modules arrive.
I have tried to automaticly link it but the device did not get recognized.
I coulld add it manually but I am not sure how to get the address of the device.
So first can I llink this older module to ISY994i.
The LampLinc you refer to is a pre-Insteon, X10 compatible device. It does not have an X10 house/unit code until one is assigned to it.
You can't add it to your ISY994i setup as Stu pointed out.
Actually after a Factory Reset. The 2000STW has a default X10 address of A1. You can program a different one into it.
You can send X10 commands from your ISY994i but only in programs.
The optional A10/X10 firmware module allows a few more things to be done.
http://wiki.universal-devices.com/index.php?title=ISY-99i_Series_INSTEON:Enhanced_A10/X10
Edited by Brian H
Thanks all - I need not spend anymore time with this then.
I will wait until my Insteon devices arrive.
