AT&T to end email-to-text ×
No communication out of ISY
JCrank
Hello,
Im having some major communication issues with my system, normally I have no communication issues and nothing has changed with the system or house.  The issues all started last night when my go to bed program ran nothing turned off as it normally does.  I messed around with it for a while restarting the PLM and ISY with no success, after about 30 minutes or so it just all started working again.  My wake up programs ran as expected this morning, but this evening the night time programs did not work.
A little information,
ISY 994i pro
around 50 instion devices of all sorts
PLM shown version 98 in tools>Diag>PLM Status
sticker on PLM shows
The PLM was replaced in March of 2014 at a little over 2 years old do to the normal PLM failure
When I log in to the ISY java console I get lots of failed communication popups once I click through all of those popups I have the red exclimation marks on just about all of my devices.
If I try to control anything from the ISY nothing happens.  Here is the event viewer output of controlling a device from the ISY
Wed 01/21/2015 07:18:49 PM : [INST-TX-I1  ] 02 62 1D C9 C1 0F 11 00
Wed 01/21/2015 07:19:02 PM : [INST-SRX    ] 02 50 1D.C9.C1 2A.1E.46 2B 11 00    LTONRR (00)
Wed 01/21/2015 07:19:02 PM : [Std-Direct Ack] 1D.C9.C1-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 01/21/2015 07:19:02 PM : [D2D EVENT   ] Event [1D C9 C1 1] [ERR] [0] uom=0 prec=-1
Wed 01/21/2015 07:19:02 PM : [  1D C9 C1 1]      ERR   0
If I control a device locally the status updates in the ISY sometimes, event viewer output below
Wed 01/21/2015 07:11:34 PM : [INST-SRX    ] 02 50 1D.C9.C1 00.00.01 CB 11 00    LTONRR (00)
Wed 01/21/2015 07:11:34 PM : [Std-Group   ] 1D.C9.C1-->Group=1, Max Hops=3, Hops Left=2
Wed 01/21/2015 07:11:34 PM : [D2D EVENT   ] Event [1D C9 C1 1] [DON] [0] uom=0 prec=-1
Wed 01/21/2015 07:11:34 PM : [  1D C9 C1 1]      DON   0
Wed 01/21/2015 07:11:34 PM : [INST-SRX    ] 02 50 1D.C9.C1 11.00.01 C7 06 00           (00)
Wed 01/21/2015 07:11:34 PM : [Std-Group   ] 1D.C9.C1-->11.00.01, Max Hops=3, Hops Left=1
Wed 01/21/2015 07:11:34 PM : [INST-INFO   ] Previous message ignored.
Wed 01/21/2015 07:11:34 PM : [X10-RX      ] 02 52 FF 80
Wed 01/21/2015 07:11:34 PM : [         X10]       J/Status Request (10)
When I Go to Tools>Diag>Show PLM Links Table > Start
Sometimes no links show up other tims it shows 250 links sometimes it shows 100 links, very random results
I did a PLM restore which acted like it worked but with no changes
So I'm thinking another bad PLM could it be anything else?
Also all of my device controlled scenes work fine
Sent from my iPad using Tapatalk HD
Scenes are written to the devices. Once the scene is created, the ISY is not needed.
Yeah that's another reason why I'm leaning toward a bad PLM
Do you have any X10 devices?
I see an X10 J Status Request in your second log.
There is also a thread on the Insteon Forums with an X10 J Status request was the problem.
An X10 J Status request is all 1 data bits. There could be a noise maker causing what is decoded as an X10 J Status request. I believe the PLM does not send data if it thinks there is a valid message on the power lines.
