Adding New ZW devices to ISY994i ZW/PRO
Hello I just replaced an ISYY99i with an ISY994i ZW/PRO and all went well when I transferred the 99i configuration. The next step was to add a ZWave switch to the mix and then add it to a  Mini controller button scene. All went well and the switch and its load responded as expected until I tried to link it to a controller button. I can turn the load on and off from the button scene in the admin console but when I try to control the switch with the remote switch it doesn't work. I have several other insteon devices configured the same way on the remote and they all work fine so the remote is working fine and the devices turn on and off as they should in the toggle device configuration. The Zwave signal seems to be making it to the Zwave switch as it responds to the admin console direct commands from the scene with no problem. Also the switch on the remote  changes the on/off state in the admin console but the load/switch does not turn on. If I run a scene test it turns the load on and off but with a long hesitation and throws this error--
Mini4D-ZW Power Plug Test
Failed ZW 002 On-Off Power Switch (ZW002_1
Ignore Mini4 - D (26 8B 55 3)
Mini4D-ZW Power Plug Test Results
Thu 01/22/2015 19:13:45 : [ZWAVE-TX ZW002_1] [0109001302023104]...
There are many more lines of code which I can post here if necessary. Any help appreciated.
Z-Wave scenes are not yet supported in the ISY. You can add a Z-Wave device to a scene but the whole Insteon Controller/Responder relationship doesn't apply to Z-Wave. To add to the problem, you are trying to mix an Insteon device in a scene with a Z-Wave device (mixed mode). We don't know how or if this will eventually be implemented in the ISY, it may not be possible. To do what you want you need to write a program.
if
button on remote is pressed
then
turn z-wave device xxx ON
Edited by andyf0
