January 25, 201511 yr Wes, on my AEON MLS Motion Sensors when the battery level is 0% it shows as OFF, when at 100% shows as ON and in between shows correctly. Obviously confusing the MLS sensors with dimmer switches or modules. Thanks
January 26, 201511 yr Hi Andy, Thanks, Can you shoot me two screenshots: - One on The Devices page with row after row of your devices showing the AEON in the middle somewhere. - One on the details page of the AEON in MobiLinc showing the Battery Level row. Please send to support@mobilinc.com Thanks! Wes
January 27, 201511 yr Author I currently don't have a sensor with a 100% or 0% battery capacity (yes, it still works at 0%) in it. I assume you want to see the issue. If not, it's easy to send pictures showing 90% or 87% which is what my two sensors are currently at. Let me know.
January 29, 201511 yr Thanks Andy, I'll try to take a look at it on my side. I'm assuming the middle percentages are all displayed correctly. It's just the initial 100% and 0% values get converted to ON and OFF. Wes
January 29, 201511 yr Author Thanks Andy, I'll try to take a look at it on my side. I'm assuming the middle percentages are all displayed correctly. It's just the initial 100% and 0% values get converted to ON and OFF. Wes Yes, that is correct.
January 29, 201511 yr Hi Andy, FYI: I've found and fixed the issue and will be included in an update I'm submitting to Apple tomorrow. Hopefully for approval next week. Wes
