Set mutually-exclusive buttons - can't undo it!
I set the buttons on a KeypadLinc to mutually-exclusive.
How do I undo this?!
"Reset" does not change it.
It seems to have automatically included the main switch on the KeypadLinc, as well as created two scenes called "Mutually Exclusive Buttons 1" and "Mutually Exclusive Buttons 2". However, these scenes don't appear in the tree - just when you click on the "mutually exclusive buttons" button.
Turns out I didn't.
Sorry, I hadn't checked the manual. Though I've found the manual fairly worthless, there's actually a clear description of this there. It certainly isn't obvious.
Select any button on a SwitchLinc, then press the Mutually Exclusive button. A list of buttons (the main button and the smaller buttons) will pop-up along with Mutually Exclusive Buttons 1 and Mutually Exclusive Buttons 2.
The latter are apparently some special kind of "scene" but won't appear in the main list of scenes. These scenes only apply to this specific SwitchLinc.
You have to drag the names of the buttons you want mutually exclusive into the 1 or 2 scene. (I assume for an 8-button SwitchLinc there would be 1, 2, and 3?)
