Incorrect set of actions show for a z-wave device in a scene
Hi, relative noob here and have just begun to add a number of devices to control with my ISY994i.  I have the z-wave module (version 4.55), and have enrolled two z-wave devices:  A Honeywell Thermostat (YTH8320ZW1007) and a Schlage door lock (BE469NX).
Both devices are enrolled and can confirm that I can control them via the admin console.  The problem I am having is that for the lock, when I add it to a new scene (with no other devices added), the Set actions show those for the thermostat.
Any ideas why the wires might be crossed?  I am using the Java based admin console.
Help is much appreciated.
I believe ZWave in scenes is still in development and we may see better scene support for ZWave devices in the V5.x firmwares.  That said, what is it you are trying to accomplish by placing a lock in a scene?  I suspect you will need a program to accomplish your goal.
-Xathros
Thanks Xathros,
I agree that I will likely need a program to accomplish what I want, which is to be able to specify an unlock code for a specific user (e.g. housekeeper) that is valid for a specified period of time during the week.  I want to do the same for other users as well, like User X can enter a valid code between 8am and 10am on Wednesdays.
One way that I thought I could accomplish this is to set user passcodes at a certain time, and remove them when the time expired.  The admin console allows me to add/remove codes, and I would like to do that programmatically, but cannot seem to find an effective way of doing that.
I look forward to the 5.X firmwares, but am not aware of their status and their possible ability to enhance working with Z-Wave devices.
Any thoughts?
tmehta
Thanks Jimbo, I've poked around for that thread but haven't been able to locate.  I'd love pointers if you have any.
Currently we are unable to modify user codes under program control.  It can be done via /REST interface calls.
Here is how: http://forum.universal-devices.com/topic/15258-door-lock-syncing/?do=findComment&comment=130600
-Xathros
Messy, but cannot ISY (thru the network module) call its own rest interface under program control to accomplish this?
Actually yes. I do that for my internet access test.
-Xathros
Thanks everyone - I am now able to make REST calls via web browser, which forces me to log in with the browser's dialog box.  Now I am trying to add the calls as network resources, but am struggling to figure out how to add the authentication credentials to the HTTP header.  I feel like I am making progress, and this one piece is the missing link for me I believe.
Thanks for the help!
Ok, answering my own (dumb) question, I was going to encode via base64 myself but turns out when you add an auth header, it actually encodes the user:pass string for you.  Very cool.
Now I am running into a strange error when trying to set the code on the lock:
Sat 02/21/2015 04:32:42 PM : Net-Resource: Failed writing to 192.168.1.129
I am using https on port 443, and issuing the following GET:  /rest/zwave/node/ZW003_1/security/user/3/set/code/00000000
One more thing - could this be related to using a self signed certificate for SSL?  I know when I issue the command via browser I get a warning that I ignore before everything works... Is there an equivalent way of forcing that behavior via HTTP call (either string or header?)?  Again, I am assuming that the issue might be related to the self signed cert.
Good point Jimbo.  I was able to test using http on port 80 with success!  But part of me still feels like encrypted comms over the wire are the way to go.  I may end up trying to install an SSL cert, though not quite sure yet.
Now on to figuring out how the tamper code limit works on this lock...
Thanks for everyone's help!
