Difference between Insteon keypad dimmer and keypadlinc?
INSTEON 2334-222 Keypad Dimmer Switch
KeypadLinc - INSTEON 2487S 6-Button Scene Control Keypad with On/Off Switch (Dual-Band), White
Besides the number of buttons, what is the difference between the two?
The Keypad Dimmer is a later device which may have some feature differences such as Beep, etc.  Not saying Beep is different, would need to compare the advertised features of both.  The underlying function of a KeypadLinc and Keypad Dimmer are the same.  SmartLabs changes the name of devices rather frequently lately.
There is a 6 and 8 button Keypad Dimmer, just as there is a 6 and 8 button KeypadLinc
Edited by LeeG
The 2334 is for dimmable loads only. The dimmer is available in both 6- ans 8-button configurations. The 2487S is for non-dimmable loads or in situations where you don't want dimming, for example, exterior flood lights. The 2487S can be reconfigured to be an 8-button device.
