Programming Issues
I can't figure this out...
Program 1:
Status  'sensor sensor' is on
Set Scene "Scene 2' On
Set Scene 'Scene 2" Off
Override Program:
If  (and here is my question)
How do I put in here Scene 'Scene 2?"    ???????
Disable Program 1
Enable Program 1
I cannot find an option that lets me put a SCENE into the if statement, I can put individual devices in but how to put a scene in?
Thanks for your help!
Use the same trigger logic that triggers Scene 2.
Or
Put your enable/disable in your first program.
Without any further influence to Scene 2 you should have a locked out logic that may not be resettable.
"And" the state of all devices in the scene to include what the scene does. For example,
       x is On
     and y is 30%
     and z is Off
