Using the 8 button keypad to monitor the garage door open status?
Blackbird
That's correct. I forgot about that glitch :oops:
Replace the magnetic contact switch. In the interim, create a scene where the button is a controller and the relay is a responder.
Create another scene that contains only the button.
Write a program that turns the button scene On if the sensor is open, otherwise (else) turns the button scene off.
Edited by stusviews
I am using the garage door in a scene with the keypad and reversed the trigger and it works great.  I do however receive a 3am notification saying the door is open so I simply scheduled the notifications for every time except a 10 minute window around 3am.
Edited by Blackbird
Well I spoke too soon. For some reason I received an email notificaton at 3:05am exactly the time I scheduled it for. Why is it doing this and how can I prevent that one notification
The best solution is to replace the magnetic switch as mentioned previously, then uncheck Trigger Reverse in the IOLinc options dialog.  If you don't want to replace the switch, then I believe there was a program based solution offered previously as well for reversing the KPL Button state on any IOLinc status change.
You could create a new "AlmostEverything" scene and include everything except the IOLink then edit the 3am query to use your new scene instead.
I would certainly think it possible to exclude a certain time period in a program to send notifications, yes. Is it possible you have an error in your program?
So in other words bypass the 3am querry for the keypad?
No, for the IOLinc.
Edited by Xathros
Below is my program.  I now get an email at 305 am instead of 3
        Status  'Overhead garage door-Sensor' is On
    And From     3:05:00AM
        To       2:55:00AM (next day)
        Send Notification to 'email' content 'Garage Overhead Door sensor Open'
No, for the IOLinc.
ok and how important is that nightly query and am I at risk of anything if I bypass it?
On the surface, your program looks like it should work.  However, consider the triggers of your program: Change in status, time is 0255, and time is 0315.  At each trigger point, it will evaluate the total condition and respond.  So...at 0305, if the status of the sensor is true, it will send a message.
You may need to take an alternate approach.  Try a couple of programs:
if
status of sensor is true
then
run next program (if path)
else
nothing
Next program (disabled):
if
time is from 0305
to 0255 (next day)
then
send notification
else
nothing
I understand you may be able to safely remove the query program, but it serves a useful function, so I would do so only as last resort.  The query program can be helpful in keeping devices synced with ISY in the event of comm problems.
if
then
else
nothing
if
time is from 0305
to 0255 (next day)
then
send notification
else
nothing
So the first program will only run my original program is the status of the io link is true? And keep my original program disabled?
Not quite.  While the "next" program may be similar to your original, it is not the same.  Delete the original program (or modify to match the "next" program.)
How is it different?
Compare the condition of your program:
    And From     3:05:00AM
with that of the "next" program:
time is from 0305
to 0255 (next day)
    And From     3:05:00AM
time is from 0305
to 0255 (next day)
So instead of selecting "From" I need to select "Time is"?
No.  My syntax was, unfortunately, approximate.  Sorry.
The difference is that your program condition is unrelated to syntax.  Your program has two triggers:
1) status ..... is ON
2) time is from ... to
My "next" program has only one trigger
1) time is from .... to
Edited by oberkc
Ok how about this?
Title of this program is "Overhead Garage door notification 1 of 2" and it is enabled
        Status  'Overhead garage door-Sensor' is On                 On means the door is opened
        Run Program 'Overhead Garage door Open Notification 2 of 2' (If)
Title of this program is "Overhead Garage door Open Notification 2 of 2"  and it is disabled
        From     3:05:00AM
Edited by Blackbird
It is all about triggers.  The first program will trigger (self initiate) upon ANY CHANGE OF STATE of the sensor.  The next program will filter those, however, eliminating any not between the specified time period.  The second program will NOT trigger at 0255 or 0305, however, since it is disabled.  It is this last point that marks the difference between the approach I suggested and your original program.  Your program was triggering at the two points in time defining your time range.  Once triggered (at 0305, for example), it was, I suggest, evaluating true, and sending your dreaded notification.
You may also want to consider CONTROL, rather than STATUS, of your sensor node as a program condition.  Since the query returns an ON/OPEN when, in fact, the door is closed, the first time after the query that the door is truly opened, there will be no change in status.  Using CONTROL condition should help solve that problem.
Having said this, I believe you are still relying on a trigger reverse setting of the IOLinc, no?  This may get reset from time-to-time, such as power outages.  Once reset, sensor ON will equal door closed.
Writing a program to overcome an easily correctable hardware problem seems to be overkill and a band-aid. Change the magnetic switch.
This one is top-of-the-line: http://www.smarthome.com/seco-larm-sm-226l-3-magnetic-garage-door-contact-switch.html
This on is bottom dollar: http://www.smarthome.com/seco-larm-sm-200q-wh-surface-mount-magnetic-contact-switch-normally-closed.html
      380k
