how to query- for how long a device was in prevous state.
Is there a way to check for how long a device was on before it was switched off?
This will be useful in the following scenario: Turn on bathroom fan when bathroom light is turned off if the light was on for at least a minute or so.
Hi Guy,
There is presently no way to do this. Timers (which can be started, stopped, and read under user control) have been requested along with variables (and I'm hopeful they may make their appearance at about the same time).
As a work-around to address this scenario, you could try:
Program 'Bath Light On Time'
       Status  'Bath Light' is not Off
       Wait  1 minute
       Run Program 'Bath Light Time Flag' (Then Path)
When the bathroom light has been on your required amount of time, a flag is set. If the light is switched off before that amount of time, the program stops and the flag does not get set.
This program serves as a flag.
Program 'Bath Fan Timer'
       Control 'Bath Light' is switched Off
   And Program 'Bath Light Time Flag' is True
       Set 'Bath Fan' On
       Wait  5 minutes
       Set 'Bath Fan' Off
       Run Program 'Bath Light Time Flag' (Else Path)
When the bathroom light is switched off, if the flag is true, this program turns on the fan for a specified amount of time, then turns the fan off, and finally it resets the flag in preparation for the next time.
Thanks Darrell, works like a charm.
