MobiLinc Connect from a computer
Wes,  I recently decided to use MobiLinc Connect to access my ISY from my iPhone.  This should mean that I can get rid of DynDns which I've been using to have a static IP address however, do I still need to keep the DynDns so that I can access my ISY from a remote computer or do you provide a means to find my ISY remotely from a computer?
Mitch
Hi Mitch,
Under the initial free for 30 days account access is limited to just the MobiLinc app client. Once you subscribe your ISY to MobiLinc Connect under one of the subscription options, the servers open up access for you to use your PC/MAC and the Admin Console. Instructions for this are provided in MobiLinc, but in short you would use this link to reach your ISY from a PC/MAC:
https://admin.mobilincconnect.com/isy/xxxxxxxxxxxx
Replace the x's with your ISY's UUID (no colons).
When prompted by the Admin Console use your MobiLinc Connect email address as the username and your MobiLinc Connect password as the password.
Wes
Thanks!  I tried it this morning and got this message:
Forbidden
You don't have permission to access /isy/00:21:b9:xx:xx:xx on this server.  ( I replaced my UUID with x's for this post but on the web page, I had them in correctly)
Edited by mitch236
Forbidden
You should try as Wes suggested:
Hi Mitch,
Please remove the colons from your UUID in the web address and try again.
Wes
Perfect!  I need to remember to read more carefully!  Now to get my widget to work!
I've been able to place a widget on my iPhone's Today View, and I have it running the "Then" command but it isn't working.  Anything I need to check?
Is the widget supposed to change colors?  Mine is in a red circle.
Edited by mitch236
Hi Mitch,
Check the program status in the MobiLinc app or in the ISY's Admin Console to verify that the Then part of the program is running when you tap it on the TodayView.
The colors for programs are:
Red = Program is FALSE
Green = Program is TRUE
Wes
