Cant remove device
I am in the middle of a transition from a Vera 3 to an ISY994
I removed a Evolve LSM-AS Zwave Dimmer and LTM accessory switch from the vera 3 and Included them on the ISY994 before I understood that the current Zwave code does not support 2 way comms.
they now show up on the ISY as ZW008 Binary Switch, ZW008 multilevel switch and a ZW008 Remote.
The ISY says they all work, but changing their states does not result in lights on or off.
I have tried REMOVING them from add/remove zwave device with the ISY right next to them - No Joy, ISY never see's the command to remove
If I delete them from the ISY,  will they still be stuck in the Zwave dongle, or is there a way to make them go away before I replace the switches with something that works ??
Any info appreciated
...Barry
Don't use the ISY delete. Use the Z-Wave Exclude.
Try an include, then an exclude if the include works.
Update  the main switch added and removed,  the slave which is a remote switch (no physical connection to the main will not exclude
The ISY shows it as fully functional
..Barry
Re-add the main switch. Re-add the slave if possible. Try removing the slave first.
That doesn't aid the situation as the slave switch cant link to the main switch.
The main switch has un-linked, but I still have the 3 devices for the slave.
Any other options to try ??
...Barry
Solved
The LTM-5 remote switch requires you to "double tap" the on paddle twice within 200 milliseconds (not easy to do) to do a network remove
..Barry
