Java pop up is annoying.
I had this before but don't recall how to stop it.  When I start ISY I get a pop up with the Java screen starting.  At some point in the past someone told me how to stop seeing that.  Any recollection?
Go to the Java in the control panel under the *Security Tab* select *Restore Security Prompts*. Once you do that upon the next login there will be a pop up and at the bottom left will be a check box to let you continue with out being prompted.
Yup!  That worked.....just like it did last time.   Now just to file this note and remember where I keep it!!!
Thanks Teken
Thanks Teken
No worries glad this is resolved.
It should be mentioned a few Java releases have at random times ignored the *do not warn me again* prompt so this is why you need to select default all settings once in awhile.
In the advanced tab there are a few more options also and another which seems to have disappeared which I don't recall off the top of my head.
Thanks Teken
Evernote to the rescue!
-Xathros
