Using "WAKEUP" as a trigger event
I have a battery operated water leak detector (Utilitech water sensor) that sends a WAKEUP notice every hour or so.  I would like to use this event in place of the non-existent heartbeat event.
The event I would like to use is this:
Thu 05/14/2015 08:22:34 AM : [ZWAVE-WAKEUP   9] Awake with no pending work, put back to sleep ZW009_1
I can issue a query command that fails at first but then does seem to trigger some kind of event when the device awakes but I am not sure what that event is.  Here is the log for that:
Thu 05/14/2015 09:06:08 AM : [ZWAVE-WAKEUP   9] Query device when awake ZW009_1
Thu 05/14/2015 09:06:08 AM : [     ZW009_1]      ERR   1
Thu 05/14/2015 09:06:23 AM : [ZWAVE-WAKEUP   9] Query device when awake ZW009_1
Thu 05/14/2015 09:22:51 AM : [ZWAVE-WAKEUP   9] Awake with pending work ZW009_1
Thu 05/14/2015 09:22:51 AM : [     ZW009_1]      ERR   0
I'm not sure what if anything is being triggered by the query command, any help would be appreciated.
Dean
I think I found the solution, firing a query command will get a "responding" event when the next time the device wakes up.  I'm using the popular leak detector code on this site and made slight modifications to it.  My heartbeat code is now:
Crawlspace - Variable Control 2 - [iD 0029][Parent 0013]
        Status  'ZW009 Water Sensor Crawlspace' is Responding
        $Leak_Crawlspace  = 1
        Wait  12 hours
        Set 'ZW009 Water Sensor Crawlspace' Query
        Wait  12 hours
        Wait  1 hour
        $Leak_Crawlspace  = 2
My log for the latest wakeup event is:
Thu 05/14/2015 10:23:13 AM : [ZWAVE-WAKEUP   9] Awake with pending work ZW009_1
Thu 05/14/2015 10:23:13 AM : [     ZW009_1]      ERR   0
Thu 05/14/2015 10:23:13 AM : [ZWAVE-WAKEUP   9] Query awakened device ZW009_1
Thu 05/14/2015 10:23:13 AM : [ZWAVE-WAKEUP   9] Put back to sleep ZW009_1
